Page 3 of 7 1 2 3 4 5 6 7
Re: The turbo Cuda build has begun [Re: cudaman1967] #180203
01/05/09 06:05 PM
01/05/09 06:05 PM
St.Clair Shores MI.
tilt Offline
tilt  Offline
St.Clair Shores MI.
60mm, 50mm
reason i asked is that they looked smallish in the pic.
My wbO2 is 18" from the turbo.This is a 5 wire for BS3.
68 CORONET R/T BEST MACHINE BUILT EFI'd TWIN TURBO(UP and RUNNING !!) 03 Mach1
Re: The turbo Cuda build has begun [Re: cudaman1967] #180204
01/09/09 10:38 PM
01/09/09 10:38 PM
Jarrettsville, MD
cudaman1967 Offline OP
Jarrettsville, MD
8 days and the car is home
Cudaman1967 1967 Barracuda Turbo Outlaw 8.50
Re: The turbo Cuda build has begun [Re: cudaman1967] #180205
01/09/09 10:39 PM
01/09/09 10:39 PM
Jarrettsville, MD
Jarrettsville, MD
another
Re: The turbo Cuda build has begun [Re: cudaman1967] #180206
01/09/09 10:40 PM
01/09/09 10:40 PM
Jarrettsville, MD
Jarrettsville, MD
3
Re: The turbo Cuda build has begun [Re: cudaman1967] #180207
01/09/09 10:42 PM
01/09/09 10:42 PM
Jarrettsville, MD
Jarrettsville, MD
Re: The turbo Cuda build has begun [Re: cudaman1967] #180208
01/09/09 10:46 PM
01/09/09 10:46 PM
Jarrettsville, MD
Jarrettsville, MD
Re: The turbo Cuda build has begun [Re: cudaman1967] #180209
01/09/09 11:19 PM
01/09/09 11:19 PM
Chicago, IL
blownEFI Offline
blownEFI  Offline
Chicago, IL
Is it ok to have the fuel pressure regulator on the firewall like that? I thought there was a rule saying so many inches away from the firewall.
"These go to eleven", Nigel Tufnel
Re: The turbo Cuda build has begun [Re: blownEFI] #180210
01/10/09 12:39 AM
01/10/09 12:39 AM
Jarrettsville, MD
Jarrettsville, MD
this is my old motor and regulator. All that is changing
Re: The turbo Cuda build has begun [Re: cudaman1967] #180211
01/19/09 10:18 AM
01/19/09 10:18 AM
Jarrettsville, MD
Jarrettsville, MD
Anybody on here using a water/meth injection with there turbo or high compression motor? If so what kind
Re: The turbo Cuda build has begun [Re: cudaman1967] #180212
01/19/09 10:57 AM
01/19/09 10:57 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Cudaman,
There are 2 water injections that work very well.
One the Supercahrger Store sells, the other Steve at New Era Racecraft sells.
I dont know the name of the one from The Supercharger store but Jay Leno put it on that crazy twin turbo thing he built, and www.alcoholinjectionsystems.com is the other
Re: The turbo Cuda build has begun [Re: cudaman1967] #180213
01/19/09 11:07 AM
01/19/09 11:07 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i have a snow kit.the only glitch was the activation with the capalary tube being pinched,[my fault]no real results to confirm but feel it works.
Re: The turbo Cuda build has begun [Re: blownzoom440] #180214
01/20/09 07:57 PM
01/20/09 07:57 PM
SO CAL
BB70DUSTER Offline
BB70DUSTER  Offline
SO CAL
how much power can that turbo support?
Re: The turbo Cuda build has begun [Re: BB70DUSTER] #180215
01/29/09 07:57 PM
01/29/09 07:57 PM
Jarrettsville, MD
Jarrettsville, MD
Carb went to CSU today!! Kevin is doing a dominator for me.
Re: The turbo Cuda build has begun [Re: BB70DUSTER] #180216
01/29/09 08:49 PM
01/29/09 08:49 PM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
Around 1200ish....
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: The turbo Cuda build has begun [Re: topfueldart] #180217
01/29/09 09:46 PM
01/29/09 09:46 PM
Jarrettsville, MD
Jarrettsville, MD
HP is relative to alot of things size of manifold, head flows, cam etc... They say good to 1500 hp but reality is like 1200 like topfuedart says.
I am looking to push around 900hp. Not looking to shock the world. Have run 9.40's to 9.50's for years NA. So would like to get it into the 8's now with the turbo and drive it and have fun
Re: The turbo Cuda build has begun [Re: cudaman1967] #180218
02/07/09 07:34 PM
02/07/09 07:34 PM
Jarrettsville, MD
Jarrettsville, MD
Rolled it off the lift today. All the lines are run, components are mounted. Time to break everything down and get headers coated and exhaust and put the new motor in. Shortblock is done just need top end off this motor to complete.
Re: The turbo Cuda build has begun [Re: cudaman1967] #180219
02/07/09 08:18 PM
02/07/09 08:18 PM
Orlando Florida
blown572dart Offline
Orlando Florida
Look like a lot of work
Re: The turbo Cuda build has begun [Re: blown572dart] #180220
02/07/09 08:32 PM
02/07/09 08:32 PM
St.Clair Shores MI.
tilt Offline
tilt  Offline
St.Clair Shores MI.
try alkycontrol for the water/meth kit.
I think there site is www.alkycontrol.com
Re: The turbo Cuda build has begun [Re: tilt] #180221
02/07/09 08:38 PM
02/07/09 08:38 PM
Jarrettsville, MD
Jarrettsville, MD
Tilt been talking to him by email the last few days. Seems to know his stuff. Prices arent to bad either.
Hows your car coming?
Re: The turbo Cuda build has begun [Re: cudaman1967] #180222
02/07/09 09:28 PM
02/07/09 09:28 PM
Motor City
Shaker223 Offline
Shaker223  Offline
Motor City
I use devils own for my meth kit.
http://www.alcohol-injection.com/water-injection-kits-1/universal-19/universal-stage-1-8.html
