No Spark #1801763
04/12/15 04:04 PM
04/12/15 04:04 PM
Logansport, Indiana
Budman Offline OP
Budman  Offline OP
Logansport, Indiana
working on my 74 Challenger 318 auto
Car started all winter but last weekend it wouldn't start. No Spark. Tried it after a couple days and it fired right up. Yesterday I backed it outside and it died. Again no spark. I have replaced the Coil, Ballast Resistor, Electronic Control Module, and coil wire. I have power to all 4 corners of Ballast Resistor and power at both sides of coil. I have power at the coil even while cranking. The only other ting I can think would be the pick up in distributor.
Any ideas would be appreciated
All MOPARS & nothig else.
Re: No Spark [Re: Budman] #1801803
04/12/15 05:32 PM
04/12/15 05:32 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
pick up coil in distributor......
Tony
70 AARCuda Vitamin C
Re: No Spark [Re: Budman] #1801808
04/12/15 05:37 PM
04/12/15 05:37 PM
md
mopars4ever Offline
mopars4ever  Offline
md
yup, what he said
Re: No Spark [Re: Budman] #1801849
04/12/15 07:11 PM
04/12/15 07:11 PM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
Check your bulkhead connector mine did the same thing and the connector was loose.
Re: No Spark [Re: Budman] #1801936
04/12/15 09:10 PM
04/12/15 09:10 PM
Logansport, Indiana
Budman Offline OP
Budman  Offline OP
Logansport, Indiana
Ive checked Bulkhead Connector so I guess I will change pick-up. Hope this will do it. Thanks
Re: No Spark [Re: Budman] #1802022
04/12/15 10:26 PM
04/12/15 10:26 PM
(1) pull the yellow wire off of the starter relay (2) seperate the zigzag dist pickup 2 wire connector at the dist. (3) pull secondary coil wire out of dist & hold it 1/4" from ground (5) A helper holds the key to "start" (6) you drag the male terminal on the body half of the zig zag connector across the intake (ground) to make/break continuity to ground (7) see if the coil secondary wire produces sparks. If it sparks & If you dont have a part time continuity problem from a bad connection/wire then all that is left is the pickup. ohm it (spec might be in the archives & 350-500 ohms comes to mind) & plug the yellow wire back in & crank the eng & see if you have ~1volt AC at the dist half of the zig zag pickup connector, meter on low volts AC scale. check reluctor gap/looseness of plate pivot pin. holler back
Re: No Spark [Re: Budman] #1802030
04/12/15 10:33 PM
04/12/15 10:33 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I think it needs 8 new spark plugs, idling is hard on them.
