1994 Dodge Cummins problem #1801468
04/12/15 02:10 AM
04/12/15 02:10 AM
Logansport, Indiana
Budman Offline OP
Budman  Offline OP
Logansport, Indiana
My Dad has a 94 2500 Cummins Truck. He went to pick up a car for me in N.C. and his truck is acting up. He says that its acting like a plugged fuel filter. He stopped and changed the filter and said the old one looked fine. No power after driving it for a few minutes. If it sets an hour it will drive ok alot farther.
He checked codes and it has code "12", "Battery has been disconnected in last 50 cycles.
AND
Code "34" Open or short in the Speed Control Solenoid Circuits or Speed Control Switch Voltage to High or Low.
any help would be very appreciated
thanks
All MOPARS & nothig else.
Re: 1994 Dodge Cummins problem [Re: Budman] #1801672
04/12/15 01:47 PM
04/12/15 01:47 PM
N
NITROUSN Offline
NITROUSN  Offline
N
He might have a tank full of crap choking off the suction side.
Re: 1994 Dodge Cummins problem [Re: Budman] #1801710
04/12/15 02:31 PM
04/12/15 02:31 PM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
check the fuel shutoff solenoid. I had a problem just like this on my 1997 and it was this solenoid not staying open after the truck started. It has two modes of operation ... 1) when you hit the starter, it gets full power to yank it open. 2) when you release the starter, the soleniod gets 1/2 power just to hold it open. On my truck, the rubber boot around the solenoid plunger was falling apart and little bits were jammed between the plunger rod and the solenoid body. At start, the solenoid yanked open but at run, it didn't let enough fuel by and there was no power. Google on "larry b starter contacts" and follow the redirect. look for the Dodge fuel solenoids page for replacement parts.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: 1994 Dodge Cummins problem [Re: Budman] #1801711
04/12/15 02:33 PM
04/12/15 02:33 PM
Re: 1994 Dodge Cummins problem [Re: Budman] #1801747
04/12/15 03:30 PM
04/12/15 03:30 PM
Logansport, Indiana
Budman Offline OP
Budman  Offline OP
Logansport, Indiana
Thanks for ur replies
He is leaving it at a Dodge Dealership and getting a rental car to get home.
Re: 1994 Dodge Cummins problem [Re: Budman] #1801769
04/12/15 04:15 PM
04/12/15 04:15 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
We used to see alot of problems from the low pressure fuel pump causing a lack of power. Mopar came out with a kit where we would remove the electric low pressure pump from the side of the block and install the low pressure pump in the tank. The kit came with the in-tank pump and the wireing. Many times if the low pump was causing low pressure feed to the injector pump we would see them come back within a week or so needing the injector pump also since lack of fuel to the injector pump can hurt the injector pump. Good luck with it , Ron
Re: 1994 Dodge Cummins problem [Re: 383man] #1801771
04/12/15 04:20 PM
04/12/15 04:20 PM
Catskill, NY
teflon Offline
teflon  Offline
Catskill, NY
Ron, no electric fuel pump on 94's, that was 1998 1/2 and up. 94's had a mechanical lift pump on the drivers side on the block.
Re: 1994 Dodge Cummins problem [Re: Budman] #1801784
04/12/15 04:49 PM
04/12/15 04:49 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
My '95 did that a few years ago. I replaced all the common stuff (fuel switch, fuel pump, sending unit, fuel filter, fuel hoses).
The problem was caused by the injector pump.
Re: 1994 Dodge Cummins problem [Re: DoctorDiff] #1801895
04/12/15 08:02 PM
04/12/15 08:02 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Same thing happened to my '96, injection pump. I hope it's something simpler, cheaper.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 1994 Dodge Cummins problem [Re: 3hundred] #1802087
04/12/15 11:44 PM
04/12/15 11:44 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
My 95 did the same thing last year. I taught myself about the solenoid. Easiest way to test is to just unbolt it. You won't be able to turn the engine off w/o opening the hood and pulling the fuel shut off lever. I found that the snap ring that held the rod to the solenoid was worn , It slipped off and jammed the linkage. Still started and shut off but had no power. I flipped the snap ring 180 degrees and put it back together. Still running fine.
Doug
Re: 1994 Dodge Cummins problem [Re: teflon] #1802127
04/13/15 12:31 AM
04/13/15 12:31 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yea I forgot as I just got so used to the ones I was working on having the electric pump most of the time. I dont remember if we had a kit to eliminate the mech pump as it is better to have the pump in the tank pushing the fuel up. On the electric ones it gave you a fuel pump block that went where the electric pump on the block was as this block they gave you let you just hook the fuel lines together where the electic pump was. There may have been a kit to eliminate the mechanical pumps but I cant remember. I just remember it seemed almost anytime I had a bad low pressure pump it would end up needing an injector pump. I would always start by checking the fuel filter first of course. Ron
Re: 1994 Dodge Cummins problem [Re: Budman] #1802342
04/13/15 01:10 PM
04/13/15 01:10 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
What about the fuel pre-heater? I thought there was a filter screen in there as well. Or has he bypassed it already?
Re: 1994 Dodge Cummins problem [Re: Budman] #1805217
04/16/15 09:13 PM
04/16/15 09:13 PM
Ok - so what did the dealership say?
