Stealth head plug choice?
#1800250
04/10/15 01:42 PM
04/10/15 01:42 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
I've looked at their site and I can't find anywhere that it mentions it, but do Stealth heads require a longer or shorter plug than stock? I've always run Autolite 85's in big blocks, will they work? Thanks.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
Re: Stealth head plug choice?
[Re: OhioMopar]
#1800331
04/10/15 03:02 PM
04/10/15 03:02 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
They use a long reach plug just like Eddys.I have an NGK number here I run but Im at 12.5 compression.Rocky
Chrysler Firepower
[Re: OhioMopar]
#1800397
04/10/15 04:31 PM
04/10/15 04:31 PM
therocks
Niles , Ohio
Last NGK race plugs I bought at Advance cost me under 15 bucks for 8 I do get a shop discount.Rocky
Chrysler Firepower
[Re: lewtot184]
#1802244
04/13/15 08:50 AM
04/13/15 08:50 AM
OhioMopar
Mt.Gilead, Ohio
if your autolite guy try 3924 or 3926(hotter). So 65's are the wrong heat range?
[Re: CR8CRSHR]
#1802245
04/13/15 08:52 AM
04/13/15 08:52 AM
OhioMopar
Mt.Gilead, Ohio
Why not just grab the correct set from 440 Source. They sell them as well and are the correct ones for their heads.... So, order plugs from Nevada when I can pick them up on the way hom3 from work? Seems a bit counterproductive. I did find they had a listing for plugs, but they are under a Source part number, not a Champion #.
[Re: OhioMopar]
#1802266
04/13/15 10:13 AM
04/13/15 10:13 AM
Posts: 3,916 usa
lewtot184
usa
if your autolite guy try 3924 or 3926(hotter). So 65's are the wrong heat range? have no idea what a "65" is. i use the 3924 and 3926 in my edelbrock heads. easy to find and work fine.
[Re: OhioMopar]
#1802436
04/13/15 03:03 PM
04/13/15 03:03 PM
OhioMopar
Mt.Gilead, Ohio
Autolite 65. It's the one I've always used in small blocks. I'll look up the 3924/3926. Thanks.
[Re: OhioMopar]
#1802464
04/13/15 03:47 PM
04/13/15 03:47 PM
Posts: 2,530 Nunya CA
CR8CRSHR
Nunya CA
Why not just grab the correct set from 440 Source. They sell them as well and are the correct ones for their heads.... So, order plugs from Nevada when I can pick them up on the way hom3 from work? Seems a bit counterproductive. I did find they had a listing for plugs, but they are under a Source part number, not a Champion #. The plugs they sell are the Champion plugs. I get your point but for me when I purchased my heads I threw a set in with the purchase along with the 10 degree locks for the spring retainers. Everything in one check out basket if you catch my drift...cr8crshr/Bill
[Re: lewtot184]
#1802471
04/13/15 04:03 PM
04/13/15 04:03 PM
Posts: 3,916 usa
lewtot184
usa
if your autolite guy try 3924 or 3926(hotter). So 65's are the wrong heat range? have no idea what a "65" is. i use the 3924 and 3926 in my edelbrock heads. easy to find and work fine. ok. all i do is big block stuff. a 65 is probably a 13/16" hex and the 3924 is a 5/8" hex. the 5/8" will probably be easier to work with.
