Is this 8 3/4 housing junk? #1796928
04/05/15 05:10 PM
04/05/15 05:10 PM
Indiana
68_661charger Offline OP
Indiana
There is a gouge or casting flaw or ? On the top end of the axel tube outside past where the inner seal sits. I have used this rear in a 70 Charger before swapping in a Dana and there were no noticeable problems. Junk?
Re: Is this 8 3/4 housing junk? [Re: 68_661charger] #1796929
04/05/15 05:22 PM
04/05/15 05:22 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Man, did you drag that thing out of Davey Jones' locker or what?
It almost looks like a groove worn in my the U bolt, but the U bolt ought to sit further inboard. If it doesn't leak I'd probably run it.
Don't be the exception.
Re: Is this 8 3/4 housing junk? [Re: Supercuda] #1796930
04/05/15 06:26 PM
04/05/15 06:26 PM
Indiana
Indiana
Agreed. Looks rough on that end only the rest of the housing is very smooth like they should be. I don't remember seeing one with a pit like this.
Re: Is this 8 3/4 housing junk? [Re: 68_661charger] #1796931
04/05/15 06:37 PM
04/05/15 06:37 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Maybe time for a cut-off wheel, another 8 3/4 with usable ends, and a welder...
Re: Is this 8 3/4 housing junk? [Re: RSNOMO] #1796932
04/05/15 06:51 PM
04/05/15 06:51 PM
Indiana
Indiana
Yeah I was just curious. I don't need it, every holiday my dad just asks about the cast-offs I've left in his shed.
Re: Is this 8 3/4 housing junk? [Re: 68_661charger] #1796933
04/05/15 07:10 PM
04/05/15 07:10 PM
Tucson AZ,
MadMopars Online content
MadMopars  Online Content
Tucson AZ,
I just used one with a similar mark on it for narrowing my Dana... Is that rust or grease on yours? Maybe it exaggerates the depth just a bit?
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: Is this 8 3/4 housing junk? [Re: MadMopars] #1796934
04/05/15 07:53 PM
04/05/15 07:53 PM
Indiana
Indiana
It's greasy and dirty and the pit is deep but is slightly more offensive on camera with the flash. I suppose it could be filled in with weld.
Re: Is this 8 3/4 housing junk? [Re: 68_661charger] #1796935
04/05/15 08:23 PM
04/05/15 08:23 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I wouldn't worry about it. Even if it were a pin hole there the chance of a leak would be very minimal if any. Looks to be on top of the housing and there would not be much lube in that area to throw around.
Re: Is this 8 3/4 housing junk? [Re: MoparforLife] #1796936
04/06/15 01:17 AM
04/06/15 01:17 AM
dulcich Offline
dulcich  Offline
You can grind clean, MIG, rough grind and finish it off with a file and you wouldn't be able to see where it was chafed. If you have the tools it would take less than ten minutes.
Re: Is this 8 3/4 housing junk? [Re: dulcich] #1796937
04/06/15 12:56 PM
04/06/15 12:56 PM
Powell, Ohio ( Originally Pitt...
1970Dart3406 Offline
You shouldn't use it. I can take it off your hands though
Re: Is this 8 3/4 housing junk? [Re: 68_661charger] #1797228
04/07/15 11:43 AM
04/07/15 11:43 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Have you considered cleaning it?
- Stu Harmon
