Re: First Gen Cummins Wiring Harness
[Re: 73ChargerSE]
#1796442
04/05/15 08:42 AM
04/05/15 08:42 AM
Posts: 5,818 ohio
ruderunner
ohio
You need to know if the truck is early or late 91. Early is non intercooled, late is intercooled. They are different harnesses and they don't swap. Nor do they swap with 90 or 92. Used is the only way to get them. Or better yet repair yours and find out what went wrong. Any used harness is likely to need repairs anyway.
Angry white pureblood male
[Re: savoy64]
#1796444
04/05/15 11:47 AM
04/05/15 11:47 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
Check with Ellis's in Aurora Utah 435-526-3211
Does your have the electronic speedo and cruse control? My 92 does. If so you need the harness or swap to a mechanical speedo and a different cruse setup.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
