Trans fluid seeping around front band adjuster thread ?
#1795964
04/03/15 09:48 PM
04/03/15 09:48 PM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
On my 727 trans, I have trans fluid that seeps out the threads of the front band adjuster. It seeps out the threads and thru the adjuster nut, then runs down the case.
I want to put some liquid Teflon tape on the threads. I don't remember if anything will fall out of place, if I pull the adjuster out of the case to spray it clean. So that I can put some liquid Teflon tape on the threads.
I am going to be doing this tomorrow morning. I have to pull the seat , shifter and part of the aluminum floor to get at it. Any insight would be helpful.
Thanks...
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: Trans fluid seeping around front band adjuster thread ?
[Re: ajcasini]
#1795966
04/03/15 10:39 PM
04/03/15 10:39 PM
Dartsport540
Ringtown, Pa.
Can I get away with turning the adjuster out about 2 turns, spray it up with brake clean spray on the outside of the case and threads. Put some liquid Teflon on the threads and screw it back in.
Just wondering how far I can screw the adjuster out before the band strut falls out. I don't need the extra work.
[Re: Dartsport540]
#1795968
04/03/15 11:14 PM
04/03/15 11:14 PM
Dartsport540
Ringtown, Pa.
Thanks, I will let you know how it works tomorrow, when I am all done. Should be good. I hate drips on the trailer floor.
[Re: ajcasini]
#1795971
04/04/15 04:44 PM
04/04/15 04:44 PM
Posts: 125 kalispell montana
jwilson 61
kalispell montana
You don't have to pull the Front Pump, Just the valve body if the strut and anchor fall out
70 cuda 440 6bbl Auto with a dana 60 68 road runner QQ1 383 auto 1970 6 barrel 4 speed Superbird FY1 number matching 15 Challenger 6.4 SRT pearl White 6 Speed 72 Cuda 440 5 speed 71 Road Runner 440 4 speed
[Re: J_BODY]
#1795972
04/04/15 06:54 PM
04/04/15 06:54 PM
Posts: 25,877 Rio Linda, CA
John_Kunkel
Rio Linda, CA
see it all the time at work. Loosen the nut, run the adjuster out a couple turns, lil dab of gray rtv, adjust back it the same amount you turned it out, tighten the lock nut..... A=OK!
That's what I'd do or install a 1/2" Stat-O-Seal.
[Re: John_Kunkel]
#1795973
04/04/15 10:01 PM
04/04/15 10:01 PM
Dartsport540
Ringtown, Pa.
I pulled the seat and aluminum floor today. Removed lock nut, backed out adjuster some, sprayed with brake cleaner. Put a little gray silicone around threads, screwed back in , and tightened the lock nut. I put it all back together, and let it dry while I did some other work. It should be good. I loaded it in the trailer before I left. I will see if it is dry next weekend. Test and tune next weekend.. Thanks..
