Holly power valve #1794393
04/01/15 06:38 PM
04/01/15 06:38 PM
New Mexico, USA
attaboy Offline OP
attaboy  Offline OP
New Mexico, USA
My 71 Charger w/440 & 750 Holly carb seemed to backfire when I started it the other day. Since then the regular 1000 rpm idle reading dropped to 800 rpm. The idle is much rougher. There isn't as much as before. Do these sound like the symptoms of a bad power valve? What does a blown one look like?
Re: Holly power valve [Re: attaboy] #1794394
04/01/15 06:48 PM
04/01/15 06:48 PM
CT
GTX MATT Online content
GTX MATT  Online Content
CT
How old is the carb? Is it now rich at idle? The newer Holley's wont blow the PV on a backfire.
If you take it out the rubber diaphragm on it would be ruptured. You may have another issue which caused the backfire.
Re: Holly power valve [Re: GTX MATT] #1794395
04/01/15 08:38 PM
04/01/15 08:38 PM
New Mexico, USA
attaboy Offline OP
attaboy  Offline OP
New Mexico, USA
I'd guess that it's maybe 5 years old or so. May be something else, I don't know. Never did that before. I'm guessing a backfire. There was a "pop" when I stared it. Never made that sound before so I'm guessing a backfire. Whatever it was, the always consistent 1000 rpm idle went to 700 rpm. That's the new "norm". Doesn't idle the same either. The idle is much rougher. Checked plug wires, etc. They look good. I'm going to let it warm up and then spray some break cleaner all around the intake to see if there is a vacuum leak there causing the symptoms.
Sounds like the power valve is a pretty easy to check. Should be easy to spot if it's bad. I have never seen a bad one so I wasn't sure what to look for. Now I know so I'll check.
Re: Holly power valve [Re: attaboy] #1794396
04/01/15 08:57 PM
04/01/15 08:57 PM
CT
CT
Yeah easy to check, being that new it should have the blow out protection, although I believe I've heard people claim it will still pop them, I've never had an issue.
Check your air bleeds for crud too. This a points car, or electronic ignition? Has it sat all winter? You'll know more when you get the primary bowl/metering block off.
Re: Holly power valve [Re: attaboy] #1794397
04/01/15 09:25 PM
04/01/15 09:25 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Being a "Holly" carb it may need some water to grow.
Re: Holly power valve [Re: GTX MATT] #1794398
04/01/15 11:26 PM
04/01/15 11:26 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Something to think about!
Re: Holly power valve [Re: attaboy] #1794399
04/02/15 12:02 AM
04/02/15 12:02 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Sounds like the PV to me. PVs are cheap and easy to change. Throw a new one in and see if it fixes the problem. If not then start doing the other trouble shooting stuff suggested.
Re: Holly power valve [Re: 451Mopar] #1794400
04/02/15 03:54 AM
04/02/15 03:54 AM
New Mexico, USA
attaboy Offline OP
attaboy  Offline OP
New Mexico, USA
Hey 451 Guy. Spoken like a true Fool Injection guy.
Re: Holly power valve [Re: GTX MATT] #1794401
04/02/15 03:59 AM
04/02/15 03:59 AM
New Mexico, USA
attaboy Offline OP
attaboy  Offline OP
New Mexico, USA
It's been converted to electronic ignition. I usually drive it several times in the winter if the weather is nice. This is the first time it ever made that "pop" sound on startup.
Re: Holly power valve [Re: attaboy] #1794402
04/02/15 02:09 PM
04/02/15 02:09 PM
dogdays Offline
dogdays  Offline
IF you can run your idle mixture screws all the way in and the engine still runs, it's most likely the power valve.
They are so inexpensive that I'd replace it just on principle, if the fuel bowl is coming off.
R.
