Re: Holly power valve
[Re: attaboy]
#1794394
04/01/15 06:48 PM
04/01/15 06:48 PM
Posts: 5,164 CT
GTX MATT
CT
How old is the carb? Is it now rich at idle? The newer Holley's wont blow the PV on a backfire.
If you take it out the rubber diaphragm on it would be ruptured. You may have another issue which caused the backfire.
[Re: attaboy]
#1794396
04/01/15 08:57 PM
04/01/15 08:57 PM
Posts: 5,164 CT
GTX MATT
CT
Yeah easy to check, being that new it should have the blow out protection, although I believe I've heard people claim it will still pop them, I've never had an issue.
Check your air bleeds for crud too. This a points car, or electronic ignition? Has it sat all winter? You'll know more when you get the primary bowl/metering block off.
[Re: GTX MATT]
#1794398
04/01/15 11:26 PM
04/01/15 11:26 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Something to think about!
[Re: 451Mopar]
#1794400
04/02/15 03:54 AM
04/02/15 03:54 AM
Posts: 221 New Mexico, USA
attaboy
New Mexico, USA
Hey 451 Guy. Spoken like a true Fool Injection guy.
