Re: 69 b body sending unit fuel in tank question [Re: mikemee1331] #1789020
03/28/15 03:33 PM
03/28/15 03:33 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
That works for me having bought the Spectra unit myself to replace a junk Chinese Stainless unit. I had hoped that Dixie's group buy had worked out and seeing that these Spectra units were Mexico made had to figure they came from the same factory he was trying to deal with. I look forward to more feedback on the Spectras-
Re: 69 b body sending unit fuel in tank question [Re: Pynzo] #1789021
03/28/15 11:30 PM
03/28/15 11:30 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Looking at a '70 Charger/Coronet FSM, it lists a tester, C-3826 for the gauges, with low medium and high settings. The section on Fuel Tank Sending Units has a figure of 73 ohms empty,+or- 12 ohms. Full setting 9.6ohms +or-1 ohm.
What are the values of the L,M, and H settings for the tester?
The tester uses E 1/2 F. The tester had the following OHM readings. E or L 77 ohms. 1/2 or M 24 ohms, F or H 11 ohms. On the tester it self the acceptable gauge range listed was E 0 to -3/32, 1/2 + or - 1/16 and F 0 to + 3/32.
Re: 69 b body sending unit fuel in tank question [Re: NITROUSN] #1789022
03/29/15 10:35 AM
03/29/15 10:35 AM
bethlehem pa
mikemee1331 Offline OP
bethlehem pa
NITRO - I copied this info over to the other thread
https://board.moparts.org/ubbthreads/newr...part=1&vc=1
