new acc e body carpet. . how far foward?...w/pics..... #1788366
03/25/15 09:44 PM
03/25/15 09:44 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
I have the back carpet laid in. Its bout as good as its gonna get
The front..... how faw foward does it go? I really like to have the foot pad as close to where its should go. Any one have a nice pic showing the pad In Relation to the gas pedal?
Will any of the carpet up on the firewall area need trimed like on the sides?
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: new acc e body carpet. . how far foward? [Re: toplescuda] #1788367
03/25/15 10:10 PM
03/25/15 10:10 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I don't have a picture, but I bought one last year, pedal ended up placed well, on the front corner of the plastic piece. I had to trim the front a bit to fit smooth under the heater box. Lay it in place and pull it as far forward as the transmission hump will let you.
EDIT: Sorry nevermind, just realized you said E body.
Re: new acc e body carpet. . how far foward? [Re: toplescuda] #1788368
03/25/15 10:23 PM
03/25/15 10:23 PM
Georgia
Steve Bryant Offline
Georgia
Just finished this a couple of weeks ago. This is ACC loop carpet with padding in a 1970 Barracuda.
I am NOT an expert at laying down auto carpet and I did not look at many photos to see how high it is supposed to go but this is where the carpet naturally wanted to go based on the shape ACC put into it.
I trimmed a little along the top so the carpet ended at the firewall insulation. Since I used Dynomat, I let the carpet stay a little long in order to hide the shiny aluminum backing.
I can take as many photos as you like so please let me know if you want to see a different area.
-Steve
Re: new acc e body carpet. . how far foward? [Re: toplescuda] #1788369
03/26/15 02:28 AM
03/26/15 02:28 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Here's an E body factory vintage photo, doesn't get anymore correct than this
Mike
Re: new acc e body carpet. . how far foward? [Re: DAYCLONA] #1788370
03/26/15 09:19 AM
03/26/15 09:19 AM
Georgia
Georgia
Hey mine looks pretty good then!
I need to run a vacuum across it though.
-Steve
Re: new acc e body carpet. . how far foward? [Re: Steve Bryant] #1788371
03/26/15 09:48 AM
03/26/15 09:48 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Does the gas pedal unbolt and bolted back down onto the carpet? Cut to fit around it. I got it as far up as it will go before interference. But my pad needs to go 4-5 more inches to be under the gas pedal
1971 charger
Re: new acc e body carpet. . how far foward? [Re: toplescuda] #1788372
03/26/15 11:04 AM
03/26/15 11:04 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
You can see that there is a seam in the heel pad that runs side to side. That seam goes where the floor pan transitions from a flat surface to the angled surface.
Here is a picture of how the carpet gets cut for the gas pedal.
http://mmcdetroit.com/ICCA/References/Interior/image_05.html
Also, there was just a slit cut in the carpet for the high beam switch. There was no grommet around it to finish off the hole.
http://mmcdetroit.com/ICCA/References/Interior/image_01.html
Re: new acc e body carpet. . how far foward? [Re: DAYCLONA] #1788373
03/26/15 11:05 AM
03/26/15 11:05 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
I like how the pad is turned wronge on the acc carpet. Based on looking at the orignal pic
1971 charger
Re: new acc e body carpet. . how far foward? [Re: toplescuda] #1788374
03/28/15 09:37 AM
03/28/15 09:37 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
I was looking at it yesterday. I have the back layed in the front I got shoved as far foward as I can with out having to trim of the frontend. My pad is no where neer where it needs to be I still like at least 5 inches to even get the front of pad where the floorpan kicks up
Is anyone else carpet (acc) like that?
And it looks like if I moved it as far foward as pad needs to be. That it will just barely cover the rear carpet
1971 charger
Re: new acc e body carpet. . how far foward? [Re: toplescuda] #1788375
03/28/15 09:44 AM
03/28/15 09:44 AM
Georgia
Georgia
It is possible you got carpet for a Challenger and you have a Barracuda?
Re: new acc e body carpet. . how far foward? [Re: Steve Bryant] #1788376
03/28/15 09:51 AM
03/28/15 09:51 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
I order for a challenger and its going in a challenger
1971 charger
Re: new acc e body carpet. . how far foward? [Re: toplescuda] #1788377
03/28/15 10:22 AM
03/28/15 10:22 AM
Georgia
Georgia
Yes, that is what I am saying.
I think the rear Cuda floor pans are shorter. If they accidentally sent you Cuda carpet I think it would be too short.
Sorry, for the previous comment being backwards. I am still half asleep.
-Steve
Re: new acc e body carpet. . how far foward? [Re: Steve Bryant] #1788378
03/28/15 12:35 PM
03/28/15 12:35 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
The rear looks like it comes pleanty foward (there is only 2 inches from cuda to challenger) but I looks to me like the pad is way the heck off
1971 charger
Re: new acc e body carpet. . how far foward? [Re: toplescuda] #1788379
03/28/15 02:00 PM
03/28/15 02:00 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Maybe you can post some pics?, is there a possibility that you "think" you've purchased an ACC carpet, and another brand was substituted?, this is common amongst some vendors, just because they advertise ACC, doesn't mean your going to get ACC, unless you specifically ask for it...
FWIW, I have 4 Ebody ACC carpets in my personal cars, auto and 4spd, cut pile and 80/20 loop, the oldest ACC carpet is 30+ years old, the newest about 2-3 yrs old, they all have perfect fit, the heel pad is exactly where it should be, the only complaint I have with one carpet is the 80/20 Grandma loop carpet turned from black to a faded purple (but I'm aware that was an issues up to about 7 yrs or so that has been corrected)
Mike
Re: new acc e body carpet. . how far foward? [Re: DAYCLONA] #1788380
03/28/15 06:17 PM
03/28/15 06:17 PM
BDW Online content
BDW  Online Content
Re: new acc e body carpet. . how far foward? [Re: BDW] #1788381
03/28/15 09:45 PM
03/28/15 09:45 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Dayclona knows best
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Wilson... your in the wrong carpet "thread" with your response (pun also intended)
Re: new acc e body carpet. . how far foward? [Re: DAYCLONA] #1788382
03/28/15 11:54 PM
03/28/15 11:54 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Box says acc on it. Cant post pics till wed. My first day off
1971 charger
Re: new acc e body carpet. . how far foward?...w/pics..... [Re: toplescuda] #1788383
04/04/15 09:18 PM
04/04/15 09:18 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Still havent had time to mess with it. But I did take some pics
As can see I got it foward bout as far as can go and the pad is no where it needs to be
Pad is not correct either
1971 charger
Re: new acc e body carpet. . how far foward?...w/pics..... [Re: toplescuda] #1788384
04/04/15 09:21 PM
04/04/15 09:21 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
1971 charger
Re: new acc e body carpet. . how far foward?...w/pics..... [Re: toplescuda] #1788385
04/04/15 09:22 PM
04/04/15 09:22 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
2
1971 charger
