Re: 2007 SRT10 engine hot rod wiring loom/ECU ?
[Re: OzHemi]
#1787653
03/25/15 04:03 AM
03/25/15 04:03 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
For an '07 SRT10 viper truck engine and automatic transmission (was out of a crew cab truck) does anyone do a hot rod loom and reflash,etc the computer for them?
Might have a project coming up swapping an engine and trans into something.
(I could probably wire a loom myself, but for sake of time, may just go premade if they are out there..)
V10 Torana? Did you finally find a Valiant?
[Re: OzHemi]
#1787655
03/25/15 02:24 PM
03/25/15 02:24 PM
Posts: 1,037 Texas, Dallas
G_T
Texas, Dallas
hotwireauto sells them... they say 96 and up. I was looking for one as well, but cant see drop $1,100 on it and still have to modify it. Sensors on the viper engines changes and moved around to different locations depending on the generation (eg. early Gens didn't have a knock sensor, newer do).
As it is - I plan to modify/update my stock one.
But - what ever you do/find - please post an update. I'd love a plug and play unit vs. modifying.
*update* I just searched, looks like bouchillon performance has a harness for a Gen 3 Viper engine... I may have to look into that - no idea if it would even fit the bill.
1970 Charger - V10, 6spd, Alterkation, Street Lynx 4 Link, Moser Dana 60, Wilwood 14" disks, Forgeline 18" Wheels (Rear:335's), ISIS Multiplexing Wiring http://www.v10mopar.com
2012 Charger SRT8
[Re: OzHemi]
#1787659
03/26/15 01:31 AM
03/26/15 01:31 AM
G_T
Texas, Dallas
And they are all Gen 3. Note that the Auto and Stick V10's will have differences in the harness as well as the ECU. Oh and I forgot to mention you can send your ECU to B&G for reprogramming (like to remove the SKIM security crap). Im sure there are other vendors that could do it as well. There are other bizarre things when dealing with the swap - post away and hopefully I can share my mistakes/lessons. Good luck!
2012 Charger SRT8
[Re: Cudajon]
#1819050
05/05/15 12:42 AM
05/05/15 12:42 AM
G_T
Texas, Dallas
Good luck Oz. I just received my reprogrammed ECU from Arrington Performance (Who merged with the company I mentioned above). The removed the emissions stuff, Rear O2 sensors, modified RPM settings, added Stage II tune, 93+ octane, etc. Had it back in under a week. see: www.shophemi.com 866.844.1245 *INSURE* your PCM... They are no longer made and if lost or damaged you'll be out some serious coin. On the wire harness, hotwireauto definitely does it. I spoke to them quite a bit but just could not stomach $1,100 for something i could do myself. I just finished my temp engine harness and went thru all the functionality testing. Once i put the intake back on I'll fire the engine to make sure it works. It was simple, but took a *lot* of time, might be worth paying someone to do it. I spent about 40 hrs on it in total. Get the FSM!!! Btw, if you go with hotwireauto you will have to send in your old harness - and you *have* to take of the intake manifold off to remove it...(Wire harness runs beneath intake and the coil packs are hidden there as well).
2012 Charger SRT8
[Re: OzHemi]
#1819124
05/05/15 02:17 AM
05/05/15 02:17 AM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Thanks for all the updated info ! I made my own LS1 loom when I build my Torana, but it was pretty simple (to me at least) and an LS tune is pretty easy to have done at least. I started with a factory F body loom and the FSM and went from there. I might tackle the Viper loom, I suppose I will look it all over once it gets here, and order up a FSM from the sounds of it too! Thanks again for the ideas/info so far and I will be sure and update things as I go along once it lands here.
[Re: OzHemi]
#1836386
05/29/15 01:18 AM
05/29/15 01:18 AM
G_T
Texas, Dallas
Good deal. I just did a first-fire on my V10 Charger last weekend with my wire harness and the reprogrammed PCM from Arrington... Fired right up -sounded *sweet* for about 2 seconds then shut down. Tried it again and same thing... Looks like they forgot to disable the SKIM as i requested... PCM is on its way back to them to take a look... My project is on hold until this is sorted out But... I can not complain as they did say they would take care of it... I'll let you know how it turns out.
2012 Charger SRT8
