Re: Barton/T&D Hemi rockers
[Re: rowin4]
#1787535
03/25/15 12:06 AM
03/25/15 12:06 AM
Posts: 2,665 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Depends on your application. Stock type rockers (even if you use roller rocker arms) are stone simple, will never tear up and make enough power for most everybody. The Ray Barton rocker system will give you capability to do things I don't do, like running a 9500 RPM Super Stocker. It is top quality, like everything Ray does, but too complicated for my application. I don't have a 9500 RPM car. It uses spray bar oiling. I like the stock way. If you need 1000 HP, go for it.
2011 Drag Pak Challenger
[Re: prochargedhemi]
#1787538
03/25/15 12:09 PM
03/25/15 12:09 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I went with StageV because when I was pricing the T&D's, I was getting quoted almost $5K because I am not a racer with an account with most vendors. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: chryco]
#1787544
03/26/15 02:51 AM
03/26/15 02:51 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
I installed one set. It was an odd combo, not least for the .12" thick head gaskets and I had to move things around to make them fit decently. I also converted them to pushrod oiling.
Plynouth VIP '67 TT IC EFI
