Re: carb linkage question
[Re: moparvinson]
#1785911
03/22/15 10:29 PM
03/22/15 10:29 PM
RapidRobert
yes on the throttle bracket and maybe on the throttle cable. set the carb on the intake then set em on a bench next to the car & visual compare the fore/aft distances between old/new horizontle throttle pin on the two carb(s) and extend the current throttle cable out forward & see if visual comparison if it looks like the cable end will reach the pin location on the new carb with the ferrule located on the current bracket
[Re: moparvinson]
#1785912
03/23/15 04:01 PM
03/23/15 04:01 PM
Posts: 25,791 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Since the 4-barrel throttle lever sits further forward than the 2-barrel, both the cable and the TP linkage have to extend further forward and the carb will need the correct Mopar throttle lever extension.
