carb linkage question #1785909
03/22/15 08:35 PM
03/22/15 08:35 PM
Albuquerque, new mexico
moparvinson Offline OP
switching intake and carb. on my sons 1974 charger with 318 from 2bbl to edelbrock performer and holley 650. do I need all new brackets and throttle cable? Thank you very much for any help.
Re: carb linkage question [Re: moparvinson] #1785910
03/22/15 09:36 PM
03/22/15 09:36 PM
P
Porter67 Offline
Porter67  Offline
P
Hit and miss but id say probably. But if you really need a 4 bbl cable bracket pm me if you dont have one, ive many I will never use.
Re: carb linkage question [Re: moparvinson] #1785911
03/22/15 10:29 PM
03/22/15 10:29 PM
yes on the throttle bracket and maybe on the throttle cable. set the carb on the intake then set em on a bench next to the car & visual compare the fore/aft distances between old/new horizontle throttle pin on the two carb(s) and extend the current throttle cable out forward & see if visual comparison if it looks like the cable end will reach the pin location on the new carb with the ferrule located on the current bracket
Re: carb linkage question [Re: moparvinson] #1785912
03/23/15 04:01 PM
03/23/15 04:01 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Since the 4-barrel throttle lever sits further forward than the 2-barrel, both the cable and the TP linkage have to extend further forward and the carb will need the correct Mopar throttle lever extension.
Re: carb linkage question [Re: John_Kunkel] #1785913
03/23/15 10:53 PM
03/23/15 10:53 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
If it's an auto you will also need the longer rod for the kickdown assembly.
...FAFO...
