Anyone interested in a 2.5lb battery to start their car
#1785067
03/21/15 07:37 PM
03/21/15 07:37 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
These things are a 20 amp hour batter and 410 CCA, friggin amazing and they will start a 520 cubic inch airplane engine! http://www.aerovoltz.com/av12.htmlNow we will see the comments! Its not much bigger than a rock star drink!
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
Re: Anyone interested in a 2.5lb battery to start their car
[Re: Monte_Smith]
#1785069
03/21/15 08:10 PM
03/21/15 08:10 PM
astjp2
Utah and Alaska
The big battery weighs 3 pounds, we use them in aircraft, if I can save 30 lbs in the front of my hemi compared to a conventional battery, I think I need to do all I can to make up the weight from my heavy world block. Tim
[Re: astjp2]
#1785070
03/21/15 08:33 PM
03/21/15 08:33 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Crazy times we live in. Not to run a car but who in their right mind thought we would have small packs like this starting diesel engines. http://www.amazon.com/Antigravity-Batter...CC6VA8MD97377X3
[Re: cudaman1969]
#1785072
03/22/15 02:04 AM
03/22/15 02:04 AM
Posts: 1,841 South Bend
John Brown
South Bend
I was happy with my 11 pound battery till I started reading this thread. Oh well, guess I'll upgrade when this one dies.
[Re: John Brown]
#1785073
03/23/15 01:11 AM
03/23/15 01:11 AM
astjp2
Utah and Alaska
I am surprised that more people didn't chime in on this topic, maybe I need to include a fiberglass hold down or something to see if people are really serious about losing weight. Tim
[Re: astjp2]
#1785076
03/23/15 06:55 AM
03/23/15 06:55 AM
Posts: 10,037 MN
JERICOGTX
MN
For those running these batteries, are you mounting them in the trunk yet, or up front?
Jeff
69 GTX
68 Road Runner
[Re: JERICOGTX]
#1785079
03/23/15 10:22 AM
03/23/15 10:22 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Jeff
We had our Lithium in the trunk, had no issues. We recently moved it into the pass compartment because we needed nose weight and moved everything we could forward
Monte
[Re: cudadoug]
#1785083
03/23/15 06:14 PM
03/23/15 06:14 PM
Posts: 1,019 Finland
mafo
Finland
I m very interested and would like to try one of those, but I m not running a alternator ,how big battery do I need? fuel pump, msd, water pump and and no towing
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: JERICOGTX]
#1785086
03/23/15 07:44 PM
03/23/15 07:44 PM
Posts: 7,495 Minnesota
Hemi_Joel
Minnesota
Jeff
I would think if I was running a 3 pound battery, I would put it as close to the starter as I could. At that weight, the position is not so critical, and you could save more weight, cost, and voltage loss with a short cable right to the starter.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
