Many running 572-13 heads?? #1782611
03/18/15 09:40 AM
03/18/15 09:40 AM
Queensland
N
NOM36 Offline OP
NOM36  Offline OP
N
Queensland
Recently put together a 572 running the Indy 572-13 heads and was wondering what those using the heads found to be their best timing and what your setup was with them.
I am running 14:1 on alcohol. Hoping to run into the 8s at 3100lbs on 10.5 with stock suspension.
Re: Many running 572-13 heads?? [Re: NOM36] #1782612
03/18/15 11:07 AM
03/18/15 11:07 AM
gregsdart Offline
gregsdart  Offline
The heads will make the power , if the motor is built right and the car can hook. Start at 34 degrees and see how it goes. I run 34 with a 440-1 head, which has basically the same chamber shape, and I have 15/1 compression and 528 cubes. A 572-13 head is basically a 440-1 casting changed from 15 degree valve angles to 13 degrees, and the exhaust is moved to make rom for a bigger intake valve.
Re: Many running 572-13 heads?? [Re: NOM36] #1782613
03/18/15 05:53 PM
03/18/15 05:53 PM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
We've used them since 2001 on a 4.5 bore 528 and then a 572. Made about 850ish hp with the 572, ran a 3900lb car in the mid 9's, 140 + Bullet cam (Indy cm3) and 1.6 arms. Very reliable eventually, haven't had it apart for 2 seasons
Re: Many running 572-13 heads?? [Re: NOM36] #1782614
03/19/15 11:48 AM
03/19/15 11:48 AM
Western Kentucky
Muscles Offline
Muscles  Offline
Western Kentucky
I run these heads and I'm very pleased with how they perform. My combination is a 4.5" bore 540, it runs 5.50's - low sixtys in a 2975 lb car with a bracket race tuneup, terminator, 31 degrees of timing, loose converter and is killer consistent.
Re: Many running 572-13 heads?? [Re: Muscles] #1782615
03/19/15 02:01 PM
03/19/15 02:01 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
Talk to the pullers, they like the wedge motors over the hemis, and lot's of them run the 572-13 heads.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: Many running 572-13 heads?? [Re: Slingshot383] #1782616
03/19/15 10:50 PM
03/19/15 10:50 PM
Queensland
N
NOM36 Offline OP
NOM36  Offline OP
N
Queensland
Good to hear. Car was running with the 572 Indy crate engine a few years ago, but I think they had a smaller cam back then maybe the CM2 or R2 as it was making around 830hp (think thats what was stated when the engine was bought). Ran 9.2 at 149mph back then and neded some work on the front of the track.
I have just reused the heads and have a cam similar to the CM3.
Hopefully get some track time next weekend.
Re: Many running 572-13 heads?? [Re: NOM36] #1782617
03/20/15 02:45 AM
03/20/15 02:45 AM
Scatchamatoon
Saskabusa Offline
Saskabusa  Offline
Scatchamatoon
I have a 572" motor with these heads. 32 degrees timing. Motor is 12.5 to 1 on gasoline.
Pushes my 3900# Charger to 10.3@130mph
1974 Roadrunner
1967 Charger
Re: Many running 572-13 heads?? [Re: Saskabusa] #1782618
03/20/15 07:06 PM
03/20/15 07:06 PM
Newfoundland,Canada
avenger572 Offline
avenger572  Offline
Newfoundland,Canada
9.21@148 with 605 and 3400 lbs
Re: Many running 572-13 heads?? [Re: NOM36] #1782619
03/26/15 07:50 AM
03/26/15 07:50 AM
Down under
O
OUTLAW565 Offline
OUTLAW565  Offline
O
Down under
Adam, you need a forward facing scoop with a tray.
Re: Many running 572-13 heads?? [Re: Saskabusa] #1782620
03/26/15 12:24 PM
03/26/15 12:24 PM
an8sec70cuda Offline
Pushes my 3900# Charger to [Email]10.3@130mph[/Email]
I'd like to hear more about this combo. Not a good example to show off the 572-13's capability.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Many running 572-13 heads?? [Re: an8sec70cuda] #1782621
03/26/15 08:01 PM
03/26/15 08:01 PM
Scatchamatoon
Saskabusa Offline
Saskabusa  Offline
Scatchamatoon
The motor
Indy Maxx aluminum block
3x intake
pro Systems 1250 dominator
12.3 to 1 compression
Weisco pistons
TTI headers 2 18" stepped
full 3 1/2" exhaust
It had a custom cam in it ground by some one I never heard of. I just installed a LSM cam in it this winter.
The car
1967 Charger
All steel full interior with a mild steel cage.
mini tubbed with ladder bars.
The best ever out of it is a 10.05 at 134mph.
When I bracket race I usually dial it in at 10.2- 10.3 range depending on the day.
this is all with the trans brake set at 3000.
It's not really set to kill but be consistent.
I need to get the chassis certified for this season so I can run it in the nines.
Once that is done I will set it up more aggressively.
The track I race at has a physical elevation of 1600' and is not know for having great DA.
1974 Roadrunner
1967 Charger
Re: Many running 572-13 heads?? [Re: Saskabusa] #1782622
03/27/15 10:44 AM
03/27/15 10:44 AM
The motor
3x intake
Weisco pistons
The car
1967 Charger
OK...so it's a fairly mild setup w/ not so good air. Still seems down on power, but maybe the cam change will help since the original cam was somewhat of an unknown. I'd bet it would run better w/ the 440-3 intake instead of the big 3X.
Has a lot of potential, just needs some tuning.
CHIP
Re: Many running 572-13 heads?? [Re: an8sec70cuda] #1782623
03/27/15 05:56 PM
03/27/15 05:56 PM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
We picked up going from the normal 4500 indy manifold to the 3X manifold, this was on a 528 motor too. Went from hi 10.20's to 10.00s never ran a 9. Maybe had something to do with the pro systems carb too.
Re: Many running 572-13 heads?? [Re: NOM36] #1782624
03/27/15 06:15 PM
03/27/15 06:15 PM
Dana Point, CA
Fast Yeti Offline
Fast Yeti  Offline
Dana Point, CA
I have 572-13 heads on a 604". 13.5:1 . The car weighs about 3025 race ready. I have the 440-3x intake and a QFX 1250 dominator. My timing is at 36. I have run abest of 8.96. With some more tuning Damon seems to feel the car should run 8.80s.
Re: Many running 572-13 heads?? [Re: Fast Yeti] #1782625
03/28/15 12:51 AM
03/28/15 12:51 AM
Scatchamatoon
Saskabusa Offline
Saskabusa  Offline
Scatchamatoon
What size and type of headers are you guys running?
I have the TTi 2 1/8' stepped to 2 1/4" with a 3 1/2" collector.
I wonder if they are the best choice?
1974 Roadrunner
1967 Charger
Re: Many running 572-13 heads?? [Re: Saskabusa] #1782626
03/28/15 03:01 AM
03/28/15 03:01 AM
Dana Point, CA
Fast Yeti Offline
Fast Yeti  Offline
Dana Point, CA
I also have TTI 21/8-21/4 step headers with a 4" collector. I found that my car likes a collector extension. My collector extension is approx 18".
Re: Many running 572-13 heads?? [Re: NOM36] #1782627
03/28/15 10:38 AM
03/28/15 10:38 AM
Jerry Kathe Offline
Jerry Kathe  Offline
Many many varibles....but - I tried alcohol for a little while with the 572/13 combo and the timing didn't seem to care between 29 and 34....more or less and you seen a change. I went back to gas and it is very critical - 31º no more no less. Thats with 116 octane and a agressive cam at 15.2 static.
Personally I dont think those heads are big enough for that cubic inch and alky. I found that even with gas that you need to focus on building torque rather than trying to spin it up. Been messing with the same combo since 1999.....I think I have peaked it out
Re: Many running 572-13 heads?? [Re: Fast Yeti] #1782628
03/28/15 10:41 AM
03/28/15 10:41 AM
Queensland
N
NOM36 Offline OP
NOM36  Offline OP
N
Queensland
Had a run today. Ran a best of 9.45 at 140mph backing off (still broke out) had run 145 earlier. Was only shifting at 6200.
Starts to haul when it hit 6 and also needs some chassis work, but shows some potential.
Re: Many running 572-13 heads?? [Re: NOM36] #1782629
03/29/15 11:54 AM
03/29/15 11:54 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Cool car
Re: Many running 572-13 heads?? [Re: HardcoreB] #1782630
03/29/15 12:58 PM
03/29/15 12:58 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Has anyone run -1's and then swapped to 572-13? My -1 car has been 9.12@147.7. It has box stock 750 Eddy's, foot brake, 10.5X29, 3340lb's. Doesn't appear that there is much improvement if any? Any thoughts?
Doug
