Motorhome 440 - Specs? #1781930
03/17/15 03:03 PM
03/17/15 03:03 PM
Farmington Hills, MI
BPBP440 Offline OP
BPBP440  Offline OP
I am looking at a 40,000 mile 440 out of a motorhome. According to seller, distributor pad is hard to read, but looks like T440. Casting is 4006630-440-7.
Does anyone know what this engine would be: CR, cast or forged crank, etc?
Thanks,
Re: Motorhome 440 - Specs? [Re: BPBP440] #1781931
03/17/15 03:58 PM
03/17/15 03:58 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
That number is late 75-79, Other then that I am not sure about the stamped pad. What does the balancer look like? thin will be forged crank
Re: Motorhome 440 - Specs? [Re: BPBP440] #1781932
03/17/15 04:54 PM
03/17/15 04:54 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
CR will be around 7.5 may have the overweight rods and forged crank but is probably cast and LY rods. You will need a magnifying glass to see lobes on the cam. Heads are probably a large plug 213 casting.
All the motor home engines I have dismantled looked super clean inside with little wear, they don't normally do a lot of short trips, they get warmed up quick and stay warm for long trips, also the miles never seem to rack up much, 40,000 is normal.
Re: Motorhome 440 - Specs? [Re: CTD5.9] #1781933
03/17/15 04:56 PM
03/17/15 04:56 PM
BPBP440 Offline OP
BPBP440  Offline OP
So the seller says it is a forged crank. It also looks like a double roller chain in one of these pics.
Re: Motorhome 440 - Specs? [Re: BPBP440] #1781934
03/17/15 05:06 PM
03/17/15 05:06 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Sure looks like a forged crank to me. Can't really tell on the timing chain?
Like Dave said, the compression will be real low and you should put higher compression pistons it if you want any kind of performance.
The 2 360 motor home engines I rebuilt had really wore out heads on them and cracked exhaust manifolds from the heat they endure. Granted these were SB and I imagine a 440 won't work as hard.
When I was driving my parents 73 360 equipped motorhome, I would have killed for a 440.
Got a picture of the top with a piston at TDC?
Re: Motorhome 440 - Specs? [Re: BPBP440] #1781935
03/17/15 05:14 PM
03/17/15 05:14 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Yep, forged crank
Most I have seen were cast in a 440 and forged in the 413 but it is not %100.
Re: Motorhome 440 - Specs? [Re: Challenger 1] #1781936
03/17/15 05:17 PM
03/17/15 05:17 PM
BPBP440 Offline OP
BPBP440  Offline OP
No picture at TDC. I asked the seller if he had measured it. Pretty soon he'll tell me to take a hike!
The motor does look really clean. May be a good starting point for a mild build.
Re: Motorhome 440 - Specs? [Re: BPBP440] #1781937
03/17/15 05:21 PM
03/17/15 05:21 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
..I ran one for fun... .533 Mopar Hyd ... Cheap 1.5 roller rockers..TM 7 intake...750 DP.. 906 ported heads...ran 12.17 in a 3300 lb Dart with driver on 87 pump gas...LOL
Re: Motorhome 440 - Specs? [Re: Chassisman] #1781938
03/17/15 06:00 PM
03/17/15 06:00 PM
BPBP440 Offline OP
BPBP440  Offline OP
What?! With stock pistons/compression? Put a modest top end on it and away you went? Nice.
Re: Motorhome 440 - Specs? [Re: BPBP440] #1781939
03/17/15 06:47 PM
03/17/15 06:47 PM
Chattanooga, TN
KDY Offline
KDY  Offline
Chattanooga, TN
I've been 7.66 @ 87 mph in the 1/8th in a 3800lb truck with a stock bore and stroke cast crank motorhome 440. KB184 pistons (9.2:1 compression), MP stage 5 iron heads (flow 265/187 @ .500), Comp 274 cam, Holley street dominator and a 650dp carb. 727 with a 8" converter (flash 3500) and a Dana 60 with 4.10s.
Motorhome 440s make for excellent mild builds imho
Re: Motorhome 440 - Specs? [Re: KDY] #1781940
03/17/15 06:58 PM
03/17/15 06:58 PM
BPBP440 Offline OP
BPBP440  Offline OP
Well alright. You guys are selling me on this real good.
Re: Motorhome 440 - Specs? [Re: BPBP440] #1781941
03/17/15 07:12 PM
03/17/15 07:12 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Me too. Well, a 77 from a tuna boat car, essentially the same thing. UNTOUCHED shortblock. UNTOUCHED (OE rebuild) 915 heads, MP .509 cam, Holley SD intake, MP elec dizzy, Holley 850, 10" converter, 3.91's, 28" tall dirt track tire, same weight: 12.20's. Later with the mp .557 cam, heads ported using MP templates, and a glass hood w/sealed 6-bbl scoop, went a best of 11.64 @ 115. BEAT THE SNOT of that motor, never broke in 3+ years, HUNDREDS of street and track passes, all on 87 octane. Tired race gas once and it actually slowed down!
Re: Motorhome 440 - Specs? [Re: cudadoug] #1781942
03/17/15 07:19 PM
03/17/15 07:19 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I have a '75 440 truck motor. Low compression but the Holley Street Dominator, .484 MP cam and 906 heads really woke it up! It was really nice internally with no wear so I did a ring and bearing job on it.
Second round is Stealth heads and this winter I'll do a higher compression 512 stroker kit.
Even with the low compression, it's a torque monster!
Re: Motorhome 440 - Specs? [Re: BPBP440] #1781943
03/17/15 07:35 PM
03/17/15 07:35 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
yup...never even tore into the short block....906 were stock except i used mopar templates.... we threw some big valve 915's on it...went 12.0X all day long shifting at 5200-5400 launching at 3000 rpm... 14.5 x 32 tires with 4.56 gears...it would also float the lifters ....but that was built in rev limiter in high gear...LOL
Re: Motorhome 440 - Specs? [Re: BPBP440] #1781944
03/18/15 12:52 PM
03/18/15 12:52 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
I think someone has been in that engine before, I don't think I've seen a motorhome 440 with a double roller chain ...
Re: Motorhome 440 - Specs? [Re: JohnRR] #1781945
03/18/15 04:16 PM
03/18/15 04:16 PM
Georgia
Steve Bryant Offline
Georgia
My 440 came from a Motorhome and it also had a forged crank and the heady rods. I paid $300 for it two years ago and it cleaned up with only a .30 bore.
Mine did NOT come with a double-roller chain.
Re: Motorhome 440 - Specs? [Re: GY3] #1781946
03/18/15 07:10 PM
03/18/15 07:10 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
You guys are giving me more hope about my torque cam and Eddy head swap on the 72 smog motor.
- Stu Harmon
Re: Motorhome 440 - Specs? [Re: feets] #1781947
03/18/15 07:26 PM
03/18/15 07:26 PM
Georgia
Georgia
My compression is 9.1:1 with an Eddie 800 and a fairly tame cam; .462 and .470 lift with 110 lobe separation.
Here is my Dyno:
https://www.youtube.com/watch?v=jQzcBniEGkA
Re: Motorhome 440 - Specs? [Re: feets] #1781948
03/18/15 08:00 PM
03/18/15 08:00 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Smoggers can do ok for what they are but if you ever drive one with an honest 10:1 you will know it.
Re: Motorhome 440 - Specs? [Re: DaytonaTurbo] #1781949
03/19/15 10:25 AM
03/19/15 10:25 AM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
My cars got a motor home block. They make a great builder. I bought one that I thought I might be able to run but it was rusty in one cylinder from being left out in the rain. my builder took it to .040 with no problem.
I’m listening.
