Very happy with 440Source Stealth heads #1781735
03/17/15 11:02 AM
03/17/15 11:02 AM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Actually, all of their products in general.
I know they sometimes get a bad rap so I wanted to discuss my experiences.
Had their water pump and housing on the 906 headed 440 along with their upper pully, alternator bracket and oil pan/pickup. Everything fit perfectly and worked perfectly the first time with NO modifications and NO leaks. The engine stays at 190-195 degrees even after beating the snot out of it!
I did the Stealth head swap this weekend and it was VERY easy. NO pushrod clearance issues etc. like others have mentioned. These castings are less than a year old, though, so that may explain some of it. Very nice castings. We had a shop look them over and install new valve locks and springs just because.
I do plan on beating/driving this thing all over this summer to events and the dragstrip so if I have ANY problems I'll post them here.
Overall I'm impressed with their quality and fit/finish. I'm just happy to have a place that has good quality stuff that gets parts sent out in a timely manner! Makes the hobby much more enjoyable.
This winter I plan on slipping a new 512" stroker kit in the shortblock.
Re: Very happy with 440Source Stealth heads [Re: GY3] #1781736
03/17/15 11:48 AM
03/17/15 11:48 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I have not had any problems with any of the parts I have got from them.
Re: Very happy with 440Source Stealth heads [Re: GY3] #1781737
03/17/15 12:40 PM
03/17/15 12:40 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
I bought a 512" stroker kit from them recently and had my machine shop check it out. They said there was nothing wrong with any of the parts and that the balance job was not absolutely perfect but not worth redoing. Everything else I got from them including a passenger drop water pump looks good. I just need to start bolting things together.
Re: Very happy with 440Source Stealth heads [Re: CTD5.9] #1781738
03/17/15 01:49 PM
03/17/15 01:49 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
They said there was nothing wrong with any of the parts and that the balance job was not absolutely perfect but not worth redoing. /quote]
Yup - that's 'Source. Great Value . Not necesarilly the best quality as delivered.
Re: Very happy with 440Source Stealth heads [Re: moper] #1781739
03/17/15 02:40 PM
03/17/15 02:40 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I'm running Source stealth heads, Source head bolts, Source water pump & housing. All items bolted right on and have worked without issue through plenty of abuse. I'm thankful for 440-source.
Re: Very happy with 440Source Stealth heads [Re: moper] #1781740
03/17/15 03:15 PM
03/17/15 03:15 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Reminds me of the old saying: "Good enough for government work..."
Re: Very happy with 440Source Stealth heads [Re: GY3] #1781741
03/17/15 03:28 PM
03/17/15 03:28 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
My junk 498 440source ran 8.60's -8.90's for 276 passes in my Daytona. It is still going strong on the street for a friend of mine. If I ever get a chance to throw together their 512 assembly I have sitting here I can't wait to see what it will do
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Very happy with 440Source Stealth heads [Re: GY3] #1781742
03/17/15 05:59 PM
03/17/15 05:59 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
No problems with my Stealth heads.
Nautilus Racing-
Re: Very happy with 440Source Stealth heads [Re: Chris2581] #1781743
03/17/15 06:52 PM
03/17/15 06:52 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
yep their stuff is ok by me , 2 sets of heads , waterpump and housing.
sometimes I think people are missing what they offer , stock and mild performance . Not all out race . Their price reflects this .
if I get to a stroker it will most likely be theirs .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Very happy with 440Source Stealth heads [Re: tex013] #1781744
03/17/15 07:29 PM
03/17/15 07:29 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Tex
Exactly! My car is dual purpose as well and has to be stone reliable!
Re: Very happy with 440Source Stealth heads [Re: GY3] #1781745
03/17/15 11:13 PM
03/17/15 11:13 PM
State, country, etc.
gss Offline
gss  Offline
So, what does your seat-of-the-pants dyno tell you after swapping heads?
Re: Very happy with 440Source Stealth heads [Re: gss] #1781746
03/17/15 11:17 PM
03/17/15 11:17 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Wasn't able to really get on it hard. Took it around the block and it was getting dark. The couple of blips I did get in, though, felt impressive!
Re: Very happy with 440Source Stealth heads [Re: gss] #1781747
03/17/15 11:20 PM
03/17/15 11:20 PM
Out of the State of Confusion
blue_stocker Offline
Easy on the 'government work' comment Brad. I was a machine tool rebuilder for almost 27 years and everything we did was spot on and better than most 'outside' jobbers. We didn't kill ourselves but we weren't slackers either and we did earn our keep until the POS politicians killed our DOD jobs in the 90s.
Re: Very happy with 440Source Stealth heads [Re: blue_stocker] #1781748
03/17/15 11:25 PM
03/17/15 11:25 PM
Q
Quicktree Offline
Quicktree  Offline
Q
either that or your jobs were shipped over seas....
Re: Very happy with 440Source Stealth heads [Re: Quicktree] #1781749
03/17/15 11:48 PM
03/17/15 11:48 PM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
I'm happy with mine too.
Dan at Performance Only (RIP) told me he was very impressed with their quality while doing my build.
Miss you Dan .
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Very happy with 440Source Stealth heads [Re: Copper Dart] #1781750
03/17/15 11:55 PM
03/17/15 11:55 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use their 440Source 4.15 stoker kit in my 440 and its been working good for about 4 years. All the parts were decent as I only did some minor touch up on some and just had to fit the pistons pins which were a tad tight. I am very pleased with it. Its nice to see people post their positive results with the 440Source parts since some of the unhappy ones post about them. Ron
Re: Very happy with 440Source Stealth heads [Re: BradH] #1781751
03/17/15 11:56 PM
03/17/15 11:56 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The only way a machine shop will know if the crank is balanced correctly is to set everything up in the balancer and give it a spin (that is the hard, time consuming part of a balance job, drilling a tad more or a couple spot welds takes very little time), if your machine shop did all that and could not spend a few minutes more to correct the balance issue I would be looking for a new machine shop. I had a used rotating assembly checked to see if it was internal or external balance (and done correctly the first time), the guy I bought it from was not sure, they knocked $10 off a normal balance job and said it was because they still had to do the same set up and checking everything. Am I crazy or missing something?
Re: Very happy with 440Source Stealth heads [Re: HotRodDave] #1781752
03/18/15 12:05 AM
03/18/15 12:05 AM
PA.
"Little"John
"Little"John
PA.
Some shops will NEVER say another shop did a good job.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Very happy with 440Source Stealth heads [Re: GY3] #1781753
03/18/15 01:14 AM
03/18/15 01:14 AM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
Is this with 3/8" pushrods? Did you use the same length as you used with your 906 heads?
Re: Very happy with 440Source Stealth heads [Re: 67Satty] #1781754
03/18/15 01:05 PM
03/18/15 01:05 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Stock pushrods.
Yes, all the rocker gear/pushrods were the same as what I was using with the 906's.
I plan on upgrading to adjustable rockers (have some Crane iron rockers) and changing pushrods when I do the bottom end and install a solid lifter cam.
