critique my setup #178171
12/29/08 06:25 PM
12/29/08 06:25 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
440
.030 over
speed pro pistons with 2 valve reliefs
Scat H beam rods
440 source heads
Lunati Voodoo cam (Hydraulic Flat Tappet, Advertised Duration 242/ 252, Lift .533/ .552)
Edelbrock torker II intake
Holley 750 DP
727 w/5000 stall convertor
Dana 60 w/4.56
29.5 tall tire.
Hope to shift at 6100-6200 and go thru at 6400-6500
hoping to get into the high 10s, car weighs 3200 w/me
Re: Criqtue my setup [Re: DusterKid] #178172
12/29/08 06:29 PM
12/29/08 06:29 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
You're probably going to turn too many RPM for a typical aggressive hydraulic to keep control of the valve train. Pitch the hydraulic cam and put a properly sized solid in there.
Re: Criqtue my setup [Re: BradH] #178173
12/29/08 09:31 PM
12/29/08 09:31 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
The old Mopar .590 cam always worked good for a car like that.But you could get a more modern design solid with similar specs.
Re: Criqtue my setup [Re: Dunnuck Racing] #178174
12/29/08 09:48 PM
12/29/08 09:48 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
850 carb
1.39 9.85 - 137 mph
Re: Criqtue my setup [Re: Ari440] #178175
12/29/08 10:05 PM
12/29/08 10:05 PM
long island new york
K
kingdust Offline
kingdust  Offline
K
i would go solid also,victor intake 1" hvh spacer,HP850 carb. whats up Ari!
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
Re: Criqtue my setup [Re: kingdust] #178176
12/29/08 10:09 PM
12/29/08 10:09 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
1.39 9.85 - 137 mph
Re: Criqtue my setup [Re: Ari440] #178177
12/29/08 11:35 PM
12/29/08 11:35 PM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
.030" 440
stock rod
11.5:1 trw
Mildly ported 915's with 2.14/1.81
MP 590/312 solid
m1 4150
1" hvh spacer
750 chokeless race holley
4200 coan
transbrake
456 dana
13x31 et drag
ss springs
3335 lbs with driver
Best et 10.644
best 60 ft 1.401
Very do-able. step up to a solid cam though.
Re: critique my setup [Re: DusterKid] #178178
12/30/08 03:07 AM
12/30/08 03:07 AM
I have a very similar motor, 440+.030 Speed Pro six pak pistons with 9.46 to 1 comp. ratio, LY rods,stock stroke Mopar OEM steel crankshaft, ported 906 heads with 2:14 intake valves, 1.81 exhaust, flow 270 CFM at .600 lift at 28 inches on a Superflow 600 bench(not as good as a set of heads as yours are), RAS 1.6 ductile iron rockers, Comp Cams Extreme Energy Hi Lift hyd. cam, 285 advertised int., 297 adv. EX with .545 lift w/1.5 rockers advertised. the intake is a Eddy Performer RPM with a Holley 950 HP.The motor made 512 HP and 544 FT. lbs on pump gas, it ran a best so far of 11:41 at around 118. mph in my 3400 lb. Duster(with me in it) with the exhaust and air cleaner on, 4;30 gears and 30 inch tall 13.50x30x15 M/T ET Street tires, 10 inch Contintental converter. I didn't get a chance to tune the motor as the oil pump bypass plug and valve came out on the second run I have had a bunch of 440 motors in different race and street cars, all of them liked bigger carbs and none of them like the Torker 2 intake manifold. See if you can get a M1 single plane intake or a Eddy Performer RPM intake and look around for a 850 DP or a 950 HP, both will work better at the track than the 750 will Or better yet use what you have now and go see how fast you can make it run with those parts and then see if you need to try and step it up with other parts experience is one of the best teachers out there, and you can have some fun learning along the way
Re: critique my setup [Re: Cab_Burge] #178179
12/30/08 10:56 AM
12/30/08 10:56 AM
MR_P_BODY Offline
MR_P_BODY  Offline
True but it can be costly also
Re: critique my setup [Re: MR_P_BODY] #178180
12/30/08 09:01 PM
12/30/08 09:01 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Not bad but I'd opt for another intake manifold like hte M1 or a ported Street Dominator.
I ran 6.90's in the 1/8th with a 451" low deck Duster running a very similar Lunati 240/250@.050 .520/.547 I shifted about 6300 with 3.91 gears.....those lunati Race Hydraulics have nice lobes, If it's similar ot the old one I doubt you'd really be giving up much to a solid with mild heads even with the steep-ish gears
WIZE
In Car:
Re: critique my setup [Re: DusterKid] #178181
12/31/08 12:11 AM
12/31/08 12:11 AM
Central NC
gch Offline
gch  Offline
Central NC
.030 over
Scat H beam rods
440 source heads
Holley 750 DP
Dana 60 w/4.56
29.5 tall tire.
I am assuming this is a strip only deal but is that converter stall a bit too high for this cam?Seems like it would be on the converter too much.
Re: critique my setup [Re: gch] #178182
12/31/08 10:33 AM
12/31/08 10:33 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
too much converter, like mentioned bigger carb and probably more cam. 557 or 590 solid would get you there.
Re: critique my setup [Re: Mr.Yuck] #178183
01/01/09 12:39 AM
01/01/09 12:39 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Ron
