Re: over size wheels on 72-93 trucks let's see em
[Re: wyldebill]
#1781681
03/17/15 10:58 AM
03/17/15 10:58 AM
Posts: 3,344 Central TX
roe
Central TX
Here is a pic of my roller painted junk with junkyard $300 rim/tire combo. Couldnt find 4 of the 20" steelies that I wanted, so I got these.
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: roe]
#1781682
03/17/15 09:58 PM
03/17/15 09:58 PM
Posts: 1,581 Friendly, WV
wedgeheaded
Friendly, WV
That's a pretty impressive finish for a roller. I've seen a few that were. Well done. You may have over paid for the wheels. Just kidding.
[Re: wedgeheaded]
#1781686
03/19/15 02:17 AM
03/19/15 02:17 AM
roe
Central TX
Thanks for the compliment.
I really like the look of the Torque Thrust style wheels on the green truck. I've been trying to figure out a way to wrangle up some for my Sig car, probably in a 20". Stepsides are always cool.
[Re: bboogieart]
#1781690
03/21/15 01:23 PM
03/21/15 01:23 PM
Posts: 1,357 central Florida
VL21
central Florida
BBoogie there are (were, anyways) many options for the eight lugs, at least in steel, all the way from 15" up in the aftermarket. Wheel choice would be sort of regulated by your intended use of the truck, to a degree. As far as larger 16.5 wheels, there are 16.5x 9.75 factory style floating around, often found on the rear of camper specials. On a '74 W200 I had in a previous life I ran these all the way around, with a 12.00 tire. 16.5 are getting harder to find I hear, and would probably go to a 17. I think this may be a byproduct of the diesel truck trend ... and then of course there are the later model factory wheels, which will need a spacer/adapter, because of the back spacing changes on newer stuff. I recommend hub centric, it has worked flawlessly on mine. No wobbles, shakes, loose lugs, etc.
It takes gasoline to interest me.
[Re: VL21]
#1781691
03/21/15 06:57 PM
03/21/15 06:57 PM
roe
Central TX
Here's a link to the spacers that I used. They are bolt centric, and I have had zero issues, wobbles, loosening etc...since I installed them. https://board.moparts.org/ubbthreads/show...rue#Post8354175
[Re: roe]
#1781692
03/22/15 04:09 PM
03/22/15 04:09 PM
VL21
central Florida
I agree, I probably over thought things, I did ponder a long time before ordering parts.
But, in the long run, I thought that having all the loads/stress placed on what ever was holding the wheel on needed to be spread over more surface than the strength of five 1/2" wheel studs, so now the load/stress is spread on the piloted hub (like factory) and on the piloted hub hole in the factory wheel, which I had and wanted.
I understand that virtually ALL the aftermarket wheels sold are not piloted on the hub ... so, moot point, I guess.
[Re: roe]
#1781694
03/23/15 03:59 AM
03/23/15 03:59 AM
Posts: 733 jacksonville,FLORIDA
slammedR/T
same hub centric billet spacers on my father's 1990 ramchrger with 2008 hemi ram 17's and chrome clads;
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: VL21]
#1781695
03/25/15 12:26 AM
03/25/15 12:26 AM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Thanks much. I'm wanting to stay with steel wheels and my center caps if I can. No need for chrome on this one. Gonna have to start checking the bone yards this summer. Definitely gonna stay with a hub centric wheel. I occasionally haul some heavy loads. The list keeps getting longer. Lets see... Hmmm, I've got most of the sheet metal, a 360 and 4 bbl, fresh exhaust pipes to put on. Now for an NV-4500, or an A833-od, or a 518 od, maybe even that bow tie conversion, Some trick treads, tunes yeah tunes, gettin' tired of the motor song. What I want is something like a 17 or a 16 as I hear the 16.5's are getting scarce. Guess I should check with the tire store too and see for sure what he can get.
I have mechanical Aptitude. I can screw up anything.
