over size wheels on 72-93 trucks let's see em #1781679
03/17/15 02:20 AM
03/17/15 02:20 AM
Midland,Tx
wyldebill Offline OP
Midland,Tx
I am looking at upgrading the wheel/tire package on my 81 extended cab. This will be lowered. What works for you? 16,17,18,20 or a combination?
Re: over size wheels on 72-93 trucks let's see em [Re: wyldebill] #1781680
03/17/15 02:51 AM
03/17/15 02:51 AM
Walnut Creek, CA
blown340 Offline
blown340  Offline
Walnut Creek, CA
Well here's some 16.5's! Probably not what you were looking for though.
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
Re: over size wheels on 72-93 trucks let's see em [Re: wyldebill] #1781681
03/17/15 10:58 AM
03/17/15 10:58 AM
Central TX
roe Offline
roe  Offline
Central TX
Here is a pic of my roller painted junk with junkyard $300 rim/tire combo. Couldnt find 4 of the 20" steelies that I wanted, so I got these.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: over size wheels on 72-93 trucks let's see em [Re: roe] #1781682
03/17/15 09:58 PM
03/17/15 09:58 PM
Friendly, WV
wedgeheaded Offline
wedgeheaded  Offline
Friendly, WV
That's a pretty impressive finish for a roller. I've seen a few that were. Well done. You may have over paid for the wheels. Just kidding.
Re: over size wheels on 72-93 trucks let's see em [Re: wedgeheaded] #1781683
03/17/15 10:27 PM
03/17/15 10:27 PM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
heres mine 18's front 20's rear. may order 20's for the front once its lowered. not the short tires are to prepare to lower it
Re: over size wheels on 72-93 trucks let's see em [Re: 72d100] #1781684
03/19/15 12:57 AM
03/19/15 12:57 AM
Midland,Tx
Midland,Tx
I can't believe that these are the only trucks here running a larger wheel package than stock
Re: over size wheels on 72-93 trucks let's see em [Re: wyldebill] #1781685
03/19/15 01:04 AM
03/19/15 01:04 AM
Huntsville, AL
V
venom107 Offline
venom107  Offline
V
Huntsville, AL
18s front and rear
Re: over size wheels on 72-93 trucks let's see em [Re: wedgeheaded] #1781686
03/19/15 02:17 AM
03/19/15 02:17 AM
Central TX
roe Offline
roe  Offline
Central TX
Thanks for the compliment.
I really like the look of the Torque Thrust style wheels on the green truck. I've been trying to figure out a way to wrangle up some for my Sig car, probably in a 20". Stepsides are always cool.
Re: over size wheels on 72-93 trucks let's see em [Re: roe] #1781687
03/20/15 12:12 AM
03/20/15 12:12 AM
ID/MT
Cheeto Offline
Cheeto  Offline
ID/MT
I have 18s all around on mine but no pics on this computer. Maybe somebody else can provide one.
Cheeto
It's not perfect.
It's not correct.
It's not yours!
Re: over size wheels on 72-93 trucks let's see em [Re: wyldebill] #1781688
03/20/15 11:30 PM
03/20/15 11:30 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
A bit off topic but...
What's your bolt pattern?
I have a 76 3/4 ton and was wondering if there even is an alternative to the 8 lug, 16.5s it currently has.
If there is nothing, I will be looking for the largest tire I can find.
Is there a wider stock rim for these?
I'm liking the one pictured by blown340 above.
I have mechanical Aptitude.
I can screw up anything.
Re: over size wheels on 72-93 trucks let's see em [Re: bboogieart] #1781689
03/21/15 12:59 PM
03/21/15 12:59 PM
Midland,Tx
Midland,Tx
Mine is a half ton,so it's 4.5. My 3/4 ton has the 8 x 6.5. It has later model 16 inch dodge wheels on It.
Re: over size wheels on 72-93 trucks let's see em [Re: bboogieart] #1781690
03/21/15 01:23 PM
03/21/15 01:23 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
BBoogie there are (were, anyways) many options for the eight lugs, at least in steel, all the way from 15" up in the aftermarket. Wheel choice would be sort of regulated by your intended use of the truck, to a degree.
As far as larger 16.5 wheels, there are 16.5x 9.75 factory style floating around, often found on the rear of camper specials. On a '74 W200 I had in a previous life I ran these all the way around, with a 12.00 tire. 16.5 are getting harder to find I hear, and would probably go to a 17.
I think this may be a byproduct of the diesel truck trend ... and then of course there are the later model factory wheels, which will need a spacer/adapter, because of the back spacing changes on newer stuff.
I recommend hub centric, it has worked flawlessly on mine. No wobbles, shakes, loose lugs, etc.
It takes gasoline to interest me.
Re: over size wheels on 72-93 trucks let's see em [Re: VL21] #1781691
03/21/15 06:57 PM
03/21/15 06:57 PM
Central TX
roe Offline
roe  Offline
Central TX
Here's a link to the spacers that I used. They are bolt centric, and I have had zero issues, wobbles, loosening etc...since I installed them.
https://board.moparts.org/ubbthreads/show...rue#Post8354175
Re: over size wheels on 72-93 trucks let's see em [Re: roe] #1781692
03/22/15 04:09 PM
03/22/15 04:09 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
I agree, I probably over thought things, I did ponder a long time before ordering parts.
But, in the long run, I thought that having all the loads/stress placed on what ever was holding the wheel on needed to be spread over more surface than the strength of five 1/2" wheel studs, so now the load/stress is spread on the piloted hub (like factory) and on the piloted hub hole in the factory wheel, which I had and wanted.
I understand that virtually ALL the aftermarket wheels sold are not piloted on the hub ... so, moot point, I guess.
Re: over size wheels on 72-93 trucks let's see em [Re: VL21] #1781693
03/22/15 04:17 PM
03/22/15 04:17 PM
Central TX
roe Offline
roe  Offline
Central TX
Was just offering up another alternative. I do really like the look of your wheel/tire combo on your truck though. Nice choice.
Re: over size wheels on 72-93 trucks let's see em [Re: roe] #1781694
03/23/15 03:59 AM
03/23/15 03:59 AM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
same hub centric billet spacers on my father's 1990 ramchrger with 2008 hemi ram 17's and chrome clads;
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: over size wheels on 72-93 trucks let's see em [Re: VL21] #1781695
03/25/15 12:26 AM
03/25/15 12:26 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Thanks much.
I'm wanting to stay with steel wheels and my center caps if I can.
No need for chrome on this one. Gonna have to start checking the bone yards this summer. Definitely gonna stay with a hub centric wheel. I occasionally haul some heavy loads. The list keeps getting longer.
Lets see... Hmmm, I've got most of the sheet metal, a 360 and 4 bbl, fresh exhaust pipes to put on. Now for an NV-4500, or an A833-od, or a 518 od, maybe even that bow tie conversion, Some trick treads, tunes yeah tunes, gettin' tired of the motor song.
What I want is something like a 17 or a 16 as I hear the 16.5's are getting scarce. Guess I should check with the tire store too and see for sure what he can get.
Re: over size wheels on 72-93 trucks let's see em [Re: bboogieart] #1781696
03/31/15 05:01 AM
03/31/15 05:01 AM
ID/MT
Cheeto Offline
Cheeto  Offline
ID/MT
255/45-18 all around.
Cheeto
It's not perfect.
It's not correct.
It's not yours!
