440 Crankshaft #1781020
03/16/15 12:41 AM
03/16/15 12:41 AM
B.C. Canada
hankcrank Offline OP
B.C. Canada
Are 440 forged cranks from 1967 to 1971 all the same and the use of different harmonic dampers are the difference because of the use 6 pack rods and pistons?
Re: 440 Crankshaft [Re: hankcrank] #1781021
03/16/15 09:01 AM
03/16/15 09:01 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Yes all forged cranks from 67 to 71 used the standard balancer except the 6 pack.
Re: 440 Crankshaft [Re: B G Racing] #1781022
03/16/15 01:58 PM
03/16/15 01:58 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Except all those with 6 pack RODS, not necessarily a 3 2-barrel engine, just to clarify...
I think anything with HP after '69.
Joe
Re: 440 Crankshaft [Re: hankcrank] #1781023
03/16/15 04:14 PM
03/16/15 04:14 PM
I've seen two different looking crankshafts in the RB motors from 1966 to 1973, the early ones have a forging mark on all the rod throws going up from the mains, the later ones are missing those on the two center rod throws There both forged steel
Re: 440 Crankshaft [Re: jlatessa] #1781024
03/17/15 11:40 AM
03/17/15 11:40 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
The 6-pack style rods were in the 3X2 carb engines and in heavy duty truck and motor homes engines.
Re: 440 Crankshaft [Re: B G Racing] #1781025
03/17/15 11:47 AM
03/17/15 11:47 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Didn't most or all the HP 440s in 71 get the bigger rods? Both of the 440s in my 4bbl 71 GTXs had the bigger ones and external balancing.
Master, again and still
Re: 440 Crankshaft [Re: DaveRS23] #1781026
03/17/15 12:36 PM
03/17/15 12:36 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
HPs in 1970 and up had the big rods and external balancing,
if I remember right??
Joe
Re: 440 Crankshaft [Re: jlatessa] #1781027
03/17/15 02:57 PM
03/17/15 02:57 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
'72-up 440's with the big rods (except the few '72 6-packs) didn't need external balance due to the reduced piston weight.
Re: 440 Crankshaft [Re: DaveRS23] #1781028
03/18/15 01:54 PM
03/18/15 01:54 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
For 70 and 71 the 440 HP 4bbl engine had the "6pk" rods too , and were external balanced . ALL of them ...
1969 6pk engines had LY rods originally.
