Sooooo what is this for a cam some sort of rv grind..? has cd15011 which I'm assuming is the part # as well as 1-4 and 779 stamped on the front of the front journal
This is a cam that came out of a 360 I'm freshening up . It looks to be in great shape as does the rest of the motor so I'm going re-ring and bearing it ( I could reuse the what came out as it looks like a pretty good rebuild, but I have new stuff I can use)........ This 360 will probably end up in a pickup or van .
Looks like a stock type rebuild with 10/10 crank and 030 cast pistons but someone did go through the trouble of balancing it...
