66 Coronet Tire Size #1780180
03/14/15 10:14 PM
03/14/15 10:14 PM
Huntington, Indiana
DartDad Offline OP
DartDad  Offline OP
Huntington, Indiana
I have a set of 15x7 wheels with a 4 1/4" back spacing. What's the best tire choice for my 66 Coronet?
Re: 66 Coronet Tire Size [Re: DartDad] #1780181
03/14/15 10:46 PM
03/14/15 10:46 PM
places
79powerwagon Offline
places
I don't remember the back spacing, but I ran 235 60 15's easily on my 64 Fury wagon and my 66 Charger. The Charger could have taken more, the Fury was pretty much maxed out.
Re: 66 Coronet Tire Size [Re: DartDad] #1780182
03/15/15 02:44 AM
03/15/15 02:44 AM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I managed to stuff 255/45/18's with 5.5" backspace in my 66 Coronet. 10" tread width is the max for sure with no mods imo.
Re: 66 Coronet Tire Size [Re: Lefty] #1780183
03/15/15 11:12 AM
03/15/15 11:12 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I have that size rim on my 67 Coronet 500 and the biggest tire I managed to put in it was M/T ET Street Radial P255/60/R15.
Re: 66 Coronet Tire Size [Re: Lefty] #1780184
03/15/15 11:16 AM
03/15/15 11:16 AM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
I have an 8 x 15 wheel with 275/60/15 with no mods in the rear. To do this, I carefully measured and ended up with 5.25" backspacing? if memory serves. I can JUST get the tire on/ off. I am convinced that this is the maximum size you can fit without moving springs etc.
Re: 66 Coronet Tire Size [Re: Hemi ragtop] #1780185
03/15/15 12:32 PM
03/15/15 12:32 PM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
275/60-15. Biggest that will fit. May or may not have to roll or trim the lip. Will still rub ever so slightly with multiple people and sharp uphill turns. (On the inside of fender) (With that 15x7 rim size, and 4 1/4 BS)
Re: 66 Coronet Tire Size [Re: Jeff_383] #1780186
03/15/15 01:40 PM
03/15/15 01:40 PM
Huntington, Indiana
DartDad Offline OP
DartDad  Offline OP
Huntington, Indiana
Thanks for the replys but how tall can I go on the front without rubbing? It has been converted to disc brakes.
Re: 66 Coronet Tire Size [Re: DartDad] #1780187
03/15/15 02:51 PM
03/15/15 02:51 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
One thing that makes a small difference is if you still have the '66 housing and not the wider '68-up unit.
I had a 275-60-15, 15x7" rim with 4.25BS, on a '67 Belvedere with a '69 housing. It fit, barely, with rolled fender lips.
Since a 275 tire is really too big for a 7" wheel, I plan to change to a 255-70-15 with the same wheel and use the original '67 housing.
Most 275-60-15 tires are 28" tall. I don't recall and height issues, that's why I'm going with a taller 70 series tire so I can get the highway RPMs down.
If you go with a 275-60-15, don't use a 7" wheel, use a 8" rim with 5.5"BS like Hemi ragtop did.
Re: 66 Coronet Tire Size [Re: B5 Bee] #1780188
03/15/15 02:58 PM
03/15/15 02:58 PM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
I know its not ideal, but I've had a 275/60 on a 7" rim for 10 years and never had an issue with uneven wear, traction at track, or anything else. I have a 27 inch tall tire in front with no where close to rubbing. (205/75-15) Right now i have a 255/70 tire out back (because i had them already) and its 29.1" tall.
Re: 66 Coronet Tire Size [Re: Jeff_383] #1780189
03/15/15 09:40 PM
03/15/15 09:40 PM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
I use a M/T ET Street radial 255/60 on an 8" steel wheel with 4.5 backspace. It fits in there nicely and no rubbing. You really need a 5+" backspace like the others have mentioned here to make a bigger tire work without more mods. I believe the Dodge is even tighter up in the wheel well than the Plymouth.
Re: 66 Coronet Tire Size [Re: DartDad] #1780190
03/16/15 05:48 PM
03/16/15 05:48 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
My rears are 255/60-15 on 15x7 3.75" BS. They will rub the wheel lip. Fronts are 205/70-15.
Re: 66 Coronet Tire Size [Re: Belvedere1] #1780191
03/17/15 01:48 PM
03/17/15 01:48 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
That's what I started with on my 67 Coronet 500 and around corners it would rub the wheel well molding. I was not going to trim the molding so I went with the 7" 4 1/4 backspace - that solved the problem.
Re: 66 Coronet Tire Size [Re: dynorad] #2781997
06/06/20 08:31 AM
06/06/20 08:31 AM
Peru
rgarciasm Offline
rgarciasm  Offline
Peru
Dynorad, congrats on you car. It looks awesome. Could you share what brand your wheels are and their specs please? (Front and rear). Thanks
66 Dodge Coronet 500, 440 ci
