Page 1 of 4 1 2 3 4
Rebuilt Engine - Brass flakes in oil #1779981
03/14/15 07:28 PM
03/14/15 07:28 PM
San Diego
Instigate Offline OP
San Diego
89 D150 LA318 Roller TBI /a999 2wd 1/2ton
So I got my engine rebuilt and I've only put 44 miles on it so far. I changed the oil and it was dark, not pitch black but it was time. Anyways I noticed it had fine brass colored metal in the oil and cut the filter open to see the brass specs. The only thing I can think of that is brass is the bearing for the dist intermediate shaft. So I pulled the dist and shaft to take a look at the bearing. It has some wear on it for sure. I'm not sure if this is normal. Do they wear into each other and eventually stop giving off metal? Or did the machine shop mess something up? Any thoughts? Things I could check? Thanks.
Re: Rebuilt Engine - Brass flakes in oil [Re: Instigate] #1779982
03/14/15 07:29 PM
03/14/15 07:29 PM
San Diego
San Diego
FIlter
Re: Rebuilt Engine - Brass flakes in oil [Re: Instigate] #1779983
03/14/15 07:37 PM
03/14/15 07:37 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Damn .... that is some HUGE brass deposits ... how tight is the D shaft? ... pic of that D shaft itself ?
Re: Rebuilt Engine - Brass flakes in oil [Re: dOoC] #1779984
03/14/15 07:49 PM
03/14/15 07:49 PM
USA
K
krw71ragtop Offline
krw71ragtop  Offline
K
USA
Is it a new bushing and if so did you burnish the bore to the correct diameter?
Re: Rebuilt Engine - Brass flakes in oil [Re: krw71ragtop] #1779985
03/14/15 08:05 PM
03/14/15 08:05 PM
San Diego
San Diego
That was done by the machine shop. So I'm thinking they did not do it correctly. Here is a picture of the brass bushing before I ran the engine. That's the priming rod in the hole in the picture.
Re: Rebuilt Engine - Brass flakes in oil [Re: dOoC] #1779986
03/14/15 08:07 PM
03/14/15 08:07 PM
San Diego
San Diego
No very. It drops right in with no resistance. Here is a picture of the shaft when I took it out just now.
Re: Rebuilt Engine - Brass flakes in oil [Re: Instigate] #1779987
03/14/15 09:11 PM
03/14/15 09:11 PM
dulcich Offline
dulcich  Offline
Ate the crank bearings. Time for another full go-around.
Re: Rebuilt Engine - Brass flakes in oil [Re: dulcich] #1779988
03/14/15 09:14 PM
03/14/15 09:14 PM
San Diego
San Diego
Oh fun.
Re: Rebuilt Engine - Brass flakes in oil [Re: Instigate] #1779989
03/14/15 10:05 PM
03/14/15 10:05 PM
USA
K
krw71ragtop Offline
krw71ragtop  Offline
K
USA
Take the oil pan off and unbolt one of the main caps and look at the bearing. Or have your engine builder do it. Was the engine broke in properly ?
Re: Rebuilt Engine - Brass flakes in oil [Re: krw71ragtop] #1779990
03/14/15 10:30 PM
03/14/15 10:30 PM
San Diego
San Diego
It's under warranty. I'm going to leave that to the machine shop. Yes, it was broken in properly.
Re: Rebuilt Engine - Brass flakes in oil [Re: dulcich] #1779991
03/14/15 11:59 PM
03/14/15 11:59 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
HMM it ATE something and the above would be a good guess, WAY too much metal in that filter,
Re: Rebuilt Engine - Brass flakes in oil [Re: TJP] #1779992
03/15/15 12:57 AM
03/15/15 12:57 AM
I ain't sayin the shavings are from the bushing but dont it look in the pic like it ain't all the way down (seated)? As said with that amount of glitter it has to come apart. Holler with any news
Re: Rebuilt Engine - Brass flakes in oil [Re: Instigate] #1779993
03/15/15 01:02 AM
03/15/15 01:02 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
FIlter
@ the filter pic. Never seen anything like it!
It's Swifty! Swifty, you toad sucker!
Re: Rebuilt Engine - Brass flakes in oil [Re: zrxkawboy] #1779994
03/15/15 02:42 AM
03/15/15 02:42 AM
NoVa
E
ebodyseast Offline
ebodyseast  Offline
E
NoVa
Maybe you'll find these old threads of interest...
moparts
Re: Rebuilt Engine - Brass flakes in oil [Re: ebodyseast] #1779995
03/15/15 02:43 AM
03/15/15 02:43 AM
NoVa
E
ebodyseast Offline
ebodyseast  Offline
E
NoVa
another... moparts
Re: Rebuilt Engine - Brass flakes in oil [Re: zrxkawboy] #1779996
03/15/15 02:44 AM
03/15/15 02:44 AM
Milwaukee, WI
moparjimbo Offline
moparjimbo  Offline
Milwaukee, WI
That is indeed an insane amount of metal in the filter - really really insane for 44 miles so what like an hour of run time????
I agree I almost have to say the worst it has to be bearing material.. I cannot see that amount of debris coming from the distributor bushing. I would drop the pan you will probably find even more and bigger chunks in the pan and pickup, and if you pull main and or rod bearings you will find damaged ones I bet...
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire
1973 Challenger - 572 Indy Hemi 860HP
1975 Trailduster Convertible, 440
1967 Plymouth Fury Police Pursuit 2DR 505 Stroker
2004 Neon SRT4 modded
www.milwaukeemopar.com
Re: Rebuilt Engine - Brass flakes in oil [Re: moparjimbo] #1779997
03/15/15 03:58 AM
03/15/15 03:58 AM
San Diego
San Diego
So what would cause a main or rod bearing to fail so soon? Is it likely that it was the machine shops fault? Bear in mind, they gave me the engine back with the rocker shafts backwards and rocker arms in the wrong places. Had two freeze plugs leak badly and need to be replaced. And they didn't bother to chase any threads from what I could see.
/I'm going to call the machine shop on Monday to tell them they need to take care of this.
Re: Rebuilt Engine - Brass flakes in oil [Re: Instigate] #1779998
03/15/15 08:30 AM
03/15/15 08:30 AM
Cleveland Ohio
sportfury70 Offline
sportfury70  Offline
Cleveland Ohio
In the picture where looking down @ the bushing, it looks like it is worn on the face. The intermediate shafts looks shiny under gear as if the two were rubbing together. May be just the picture though.
Re: Rebuilt Engine - Brass flakes in oil [Re: Instigate] #1779999
03/15/15 10:20 AM
03/15/15 10:20 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
That's not the bushing that's the bearings for sure. Don't run it no more. It has to came apart. Sorry.
Re: Rebuilt Engine - Brass flakes in oil [Re: Challenger 1] #1780000
03/15/15 11:18 AM
03/15/15 11:18 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Could have wiped the cam and the resulting metal shavings took out the crank bearings. As mentioned, that engine is toast and needs a full boat tear down.
Page 1 of 4 1 2 3 4
