Who's running a 3.73 gear? #1779222
03/13/15 10:59 PM
03/13/15 10:59 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
Thinking of this gear to replace a noisy 3.91 in a 742 case I have. Right now I'm running a 489 case with 3.55 it's fine on the expressway with my 28" drag radials but a bit soft off the line. In the future I will replace the 360 with a 426" sb so the torque will be way up and HP should be about 100 more. Who makes the 3.73, I am looking for a hi quality set, the 742 has new bearings and clutch pack, also will add hi strength axles at the same time.
Re: Who's running a 3.73 gear? [Re: ademon] #1779223
03/13/15 11:07 PM
03/13/15 11:07 PM
Central NC
gch Offline
gch  Offline
Central NC
I have a 3.73 in my Polara.I believe I got it from Mancini.I can't remember if it was a Strange/U.S. Gear or a house brand.It has been quiet and trouble free.
Re: Who's running a 3.73 gear? [Re: gch] #1779224
03/13/15 11:25 PM
03/13/15 11:25 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Talk to Dr Diff on the board.Many many members have dealt with him and he is top notch.Ill be getting dana parts from him soon. Rocky
Chrysler Firepower
Re: Who's running a 3.73 gear? [Re: therocks] #1779225
03/14/15 12:16 AM
03/14/15 12:16 AM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
Got mine from Dr Diff; I think it was a yukon gear but don't quote me on that. He supplied me with the yoke, and solid pinion spacer and shims I needed too for the swap. Have not had any issues which includes a trip to the track and some 12.20 passes.
Re: Who's running a 3.73 gear? [Re: parksr5] #1779226
03/14/15 01:30 PM
03/14/15 01:30 PM
MD
p d'ro Offline
p d'ro  Offline
MD
How is around town and highway driveability? A friend is putting 3:55 in his car once his 383 gets stroked and should have over 400hp. I wonder of 3:73 may work. 15" 60 series tires. 727 in a 69 satellite?
Re: Who's running a 3.73 gear? [Re: p d'ro] #1779227
03/14/15 01:50 PM
03/14/15 01:50 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
I have 3.73's with 33-inch tires on my Factory AMC V8 CJ5 Jeep and it seems just about the Best gear for driving around town, off-road and even on the Freeway. 4.10 was too much, and 3.55 was not enough.
Re: Who's running a 3.73 gear? [Re: D_C] #1779228
03/14/15 06:52 PM
03/14/15 06:52 PM
Central NC
gch Offline
gch  Offline
Central NC
It all depends on tire height and expected sustained rpm.How long you will be at the rpm as well.
I have 28" tires and it takes an hour to get to the nearest 1/4 mile.I liked the cruising with 3.55's better and will likely switch back after one attempt at the track with the lower gears to see if it betters the 12.54 best with 3.55's.
A tourqey motor will do better with taller gears.Higher rpm where the cam makes power later will benefit from the lower gear.There is always a trade off with driveability with lower gears unless you have an overdrive tranny.
Re: Who's running a 3.73 gear? [Re: gch] #1779229
03/14/15 11:06 PM
03/14/15 11:06 PM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
This is a very "subjective" question but I will tell you that after driving 140 each way last summer with 3.54 gear, I began shopping for an overdrive! I had what is considered a "quiet" exhaust, B body with all kinds of sound deadener. Noise and vibration drove me bonkers!
But I am an old man...
Re: Who's running a 3.73 gear? [Re: Hemi ragtop] #1779230
03/15/15 01:40 AM
03/15/15 01:40 AM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
Thanks guys, i don't usually go on long highway drives most are 30 minutes. maybe 3 or 4 drives an hour long a year. Probably 60/40 hwy/city. Not sure i will always have the 28" rear tire but guessing with that stroker staying with that size DR will be best.
Re: Who's running a 3.73 gear? [Re: ademon] #1779231
03/15/15 01:42 AM
03/15/15 01:42 AM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
I think the size looks good and fills the wheel well correctly. but some times i think its a tad to big
Re: Who's running a 3.73 gear? [Re: ademon] #1779232
03/15/15 09:31 AM
03/15/15 09:31 AM
Central NC
gch Offline
gch  Offline
Central NC
Looks like it means business.
Re: Who's running a 3.73 gear? [Re: gch] #1779233
03/15/15 10:20 AM
03/15/15 10:20 AM
MD
p d'ro Offline
p d'ro  Offline
MD
i agree. Very nice car...
Re: Who's running a 3.73 gear? [Re: p d'ro] #1779234
03/15/15 04:30 PM
03/15/15 04:30 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I have a 3.73 gear set for a Dana 60 and I also have a Dana 60-2 that is narrowed to fit my D100 and also fits an A-body (same width). If it were my car I would go Dana and skip right past the 8.75"
The Dana 60-2 is going in my truck with 4.10 gears, a PowerLock carrier, 35 spline stock axles
and 34" diameter 305/75R16 tires. Should be a nice upgrade
The wheel/tire in the picture is a 245/75R16 and only 30" in diameter, so the tire width will go from 9.5" to 12". This is of course to improve the towing capacity of the truck...that is what I tell my wife anyway
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
