Page 1 of 3 1 2 3
Who needs a big block ? #1778352
03/13/15 12:06 AM
03/13/15 12:06 AM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
One question has been haunting me for sometime now.....
Who needs a big block when your small block stroker makes 660 + ponies ?
Does a big block will make you go faster in the same body with more torque ?
I see here big block builds hoping to get 600-650 hp and go fast....faster than my 606 hp small block ? should I go big block to get better et's ?
I'm confused.....................
Dan
best 60ft 1.30
best 1/8 mile so far 6.40 sec
Re: Who needs a big block ? [Re: Wedgeman] #1778353
03/13/15 12:17 AM
03/13/15 12:17 AM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Dan
best 60ft 1.30
Torque buddy....its all about the torque. I can leave at 2k, shift at 6400 and run 9.70's on pump gas....A small block will do that as well, but at a little higher rpm, and it needs a lighter car and probably more maintenance in the long run....In the end, the cost is about the same as the small block really should have an after market block at that hp level....Why not a +500 small block? If your spending money....why not a little more.
Re: Who needs a big block ? [Re: Dragula] #1778354
03/13/15 01:28 AM
03/13/15 01:28 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
I'm a big block guy, all day long.
But, my 62 Valiant doesn't lend itself to a BBM installation easily, so I was forced to build a 428 small block street engine 615HP, 540 TQ, and a 10.49 best without much tuning so far.
I've had plenty of 440s, built cheaper, that ran about the same NA.
The difference is, I can put two kits on the 440 and run 8's.
Not gonna get there with the small block!!!!
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Who needs a big block ? [Re: Wedgeman] #1778355
03/13/15 02:07 AM
03/13/15 02:07 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Dan
best 60ft 1.30
You consider running a 640 with that 130 60 foot fast? Maybe you should consider a big block and run some better times after all you said race car
Re: Who needs a big block ? [Re: MoparBilly] #1778356
03/14/15 10:20 PM
03/14/15 10:20 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I'd believe that theory..... but I've seen what the Belvedere runs....
It's fun to have a lil block again!
Re: Who needs a big block ? [Re: J_BODY] #1778357
03/15/15 12:06 AM
03/15/15 12:06 AM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
friends have small blocks. all i hear from them is i'll show you a fast small block. and they are fast no doubt.
it depends to me what you want in the end. i my self think a 500" big block can be built with normal parts new or used till you bust the block.
the fast small blocks tend to be more non normal stuff. big heads have one off valve trane and headers.at higher rpms.
but those 4" crank motors make great power. and leave hard.
it is up to you what ever you want i my self think a big block stroked will make power cheaper. but i may be wrong and it depends how much power you want.
Re: Who needs a big block ? [Re: dmking] #1778358
03/15/15 12:14 AM
03/15/15 12:14 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
No you're absolutely right.... the engine in my Mirada was a prime example. Mild port Stage VI, 4500 M1 intake with Ebay dominator (old carb shop piece... I should have kept it!), stock block, stock LY rods (Moparbilly beta tested LY's to the 8's on spray so I wasn't worried about mine ), stock crank welded and cut to 4.15, stock main caps with ARP studs, off the shelf Ross pistons, UD640 mech cam, no hardblock, freshened 4 times and was pretty much used up at the last one.... ran 9.93's on a string the last time I ran the car in 2012. Wore out bullet is STILL in the car two owners later..... but it was a yawner shifting at 5800, trapping at a little over 6k.
I don't have the receipts anymore, but it wasn't as "cheap" as moparbilly stated, but it worked.... for a long time.
......but the small block has brought back the "fun" for me!
Re: Who needs a big block ? [Re: J_BODY] #1778359
03/15/15 01:12 AM
03/15/15 01:12 AM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
I understand that a big block will make as much pôwer as a stroked small block, only cheaper....
My Indy headed small block cost me over 12k, and I've gone 10.30 in a 3100lbs car, normally aspirated without nitrous.....
From there I'm left with either take as much weight off, or go big block to run high nines.
If every 100lbs lost is 0.1 sec faster, I put the same engine in a 2500lbs car, I should run 9.7 or so....again without nitrous......
After all that thinking, do you really need a big block to go fast ?
Give me your thoughts
Dan
Re: Who needs a big block ? [Re: Wedgeman] #1778360
03/15/15 01:23 AM
03/15/15 01:23 AM
gregsdart Offline
gregsdart  Offline
A 400 block, built with B1 heads and a 4.15 stroke or close to that can make 850 hp . If you need more, up to 1050 hp with the right combo with B1 heads. For a somewhat streetable combo, it will be tough to beat 604 cubes, about as big as a BB can go. There are some good heads for small blocks, but they just can't be built big enough
Re: Who needs a big block ? [Re: Wedgeman] #1778361
03/15/15 01:42 AM
03/15/15 01:42 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Dan
I was running 8.90s in my car with a 405ci.. a mild
engine but I did rev it... but I didnt do anything
on that engine.. nothing went wrong.. I opened it
up a couple of times just to look.. that was in a 2405#
car with me... I could have made a lot more power
but I didnt feel like working on it(just needed a cam)
EDIT
that was N/A
Re: Who needs a big block ? [Re: Wedgeman] #1778362
03/15/15 01:51 AM
03/15/15 01:51 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Our stock block 340 based 4" stroke W5 mill went 9.8's and that was still at a conservative shift point.... my dad shifted it at less than 6K and usually ran 10 ohs. Car was nowhere close to legal for 9's. I really believe if he'd "let her eat".... it would have gone deeper than that.
we're currently running a fairly mild W8 4" stroke combo and went 9.64 last weekend with the shift light set at 6600. We're just starting to have fun! I've always loved small blocks and as I stated earlier.... we B havin FUN!
Re: Who needs a big block ? [Re: J_BODY] #1778363
03/15/15 03:01 AM
03/15/15 03:01 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I also notice some of these smallblock strokers are bigblock (400 plus) cubes and are a lighter eng. So as Bill Jenkins proved when his lighter smallblock Vega ran right with the hemi's its all about HP to weight. I agree that alot of times the bigblock can be cheaper to build to get the torque. I dont think a smallblock of the same cubes as my bigblock would ran as fast in my heavy B-body and to me a 63 Sport Fury from the Max Wedge era just looks right with a bigblock. But I am very impresed how strong these smallblock stroker Mopars are running. Ron
Re: Who needs a big block ? [Re: J_BODY] #1778364
03/15/15 03:20 AM
03/15/15 03:20 AM
Arizona
Chris'sBarracuda Offline
Arizona
Is that the Motor that went "BOOM" @ Speedworld.??
Chris..
Re: Who needs a big block ? [Re: MoparBilly] #1778365
03/15/15 10:29 AM
03/15/15 10:29 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Why not ? Mine went 5.60 w a 150 tune,that's 8.80s.I shift at 7000 and it's w 20yr old indy heads.A stock 340 block IMO is also ALOT stronger then 440 blocks as they have a tendency to blow near the pan rail or split from what I've seen of the 3 blown 440 blocks in low hp mopars.
A 400 block and B1s would be a good one I think,but NOT a 440 block.
Re: Who needs a big block ? [Re: Wedgeman] #1778366
03/15/15 11:05 AM
03/15/15 11:05 AM
gregsdart Offline
gregsdart  Offline
In the end, it boils down to preference. A maxed out small block with tunnelram, best block and heads, 400+ cubes, will no doubt be fast, a big block will be faster, simply because it can be built bigger, and has a bigger bore. So it boils down to budget and preference. A good reference point would be a comp class, or sprint cars, how much power do they make? At what cost? There is something attractive about either engine family. Personally, I am a bigblock guy, ever since I walked away (unintentionally)from a stop light in third gear in a 383 four speed car in 1970. That amazed me, and set my preference pretty much in stone. But that is me. Somebody out there no doubt had a high winding small block, kicked butt on a few BB cars, and fell in love with it, cementing his preference.
Re: Who needs a big block ? [Re: Chris'sBarracuda] #1778367
03/15/15 12:04 PM
03/15/15 12:04 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Chris..
same short block.... different set of heads. #3 rod let go.... It was also #3 intake runner on the leaky heads that kept introducing water to that cylinder. Believe the rod got damaged and it wasn't caught until it was too late.
Re: Who needs a big block ? [Re: J_BODY] #1778368
03/15/15 12:14 PM
03/15/15 12:14 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
It's all about one thing for me, cost!
I raced 340's for years, nothing expensive, only ran high 11's.
When I bought my first backhalved roller in 2003 I found a 451 short block for 2 grand from a well known racer, added $1200 Eddy heads, M1 intake and the old 590 purpleshaft cam which was $169 and came with lifters! I went easy 10.20's and 2 yrs later was running easy 9.80's at low RPM.
I love small blocks but I won't get back into them until I have extra cash as I know I'd have to spend alot more on it to run that quick in a pump gas street car.
My current Duster will never see a track but I found a great deal on a stroker kit so it is 500 inches with Eddy heads, I have very little money in it, can blow the tires off with ease, and I can run 3.55 gears and a tight converter because of all the torque.
Re: Who needs a big block ? [Re: ProSport] #1778369
03/15/15 01:17 PM
03/15/15 01:17 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Sounds like a fun car and that's what it's all about. I'm a SB guy and a semi-reformed rpm junkie, but I really would like to have a 500incher in a mid 60's B body.
Yeah, it's got a smallblock.
Re: Who needs a big block ? [Re: 340B5] #1778370
03/15/15 01:30 PM
03/15/15 01:30 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Finally it all comes down to
a money-power ratio ! loll
Re: Who needs a big block ? [Re: ProSport] #1778371
03/15/15 01:34 PM
03/15/15 01:34 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I love my small blocks. I went 9.90 na at 3300 lbs with a stock block 4 inch crank and Indy 360-1. That was 12.5 to 1 motor so I ran it mixed pump and race fuel. Now I upgraded to a R block and go 9.43 na at 3195 on pump gas. I add a single stage plate to her and she will run 8.56@162. I only shift it at 7000 so I dont think its a high manteince motor, same valve springs last four year and still pull the same.
I loved racing 10.0 index with it two years ago, I would shift it at 5500. Think it would have lived a long time running that class but I built it to go faster.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Page 1 of 3 1 2 3
