ONE PIECE INTAKE MANIFOLD VALLEY PAN...... #1777613
03/12/15 01:35 AM
03/12/15 01:35 AM
State of confusion
Thumperdart Offline OP
State of confusion
Anyone make one that fits rpm heads for the bb? Car started runnin funky so I pulled the plugs and all of the drivers side were oily and a couple on the pass also so I pulled the intake and all of the runners were wet with oil some worse than others.
Re: ONE PIECE INTAKE MANIFOLD VALLEY PAN...... [Re: Thumperdart] #1777614
03/12/15 03:24 AM
03/12/15 03:24 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
I installed a 440 source one piece on 2 engines and they sealed ok, but I thought they were to thin. Still no leaks tho
Re: ONE PIECE INTAKE MANIFOLD VALLEY PAN...... [Re: Mopar-Al] #1777615
03/12/15 03:43 AM
03/12/15 03:43 AM
State of confusion
State of confusion
Can it be installed with the heads on?
Re: ONE PIECE INTAKE MANIFOLD VALLEY PAN...... [Re: Thumperdart] #1777616
03/12/15 09:03 AM
03/12/15 09:03 AM
cleveland ohio
MartyQ Offline
MartyQ  Offline
cleveland ohio
http://www.manciniracing.com/hubvapl2pimo.html Used this one on 440with rpm heads - worked fine and can be installed with heads on.
Re: ONE PIECE INTAKE MANIFOLD VALLEY PAN...... [Re: MartyQ] #1777617
03/12/15 04:04 PM
03/12/15 04:04 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
I tried that pan, it leaked at the center joint. Never could get it to seal. Don't waist your money on that one.
Re: ONE PIECE INTAKE MANIFOLD VALLEY PAN...... [Re: Dabee] #1777618
03/12/15 04:53 PM
03/12/15 04:53 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
440Source can't be installed with heads on. It has a bent lip on each side which goes under the heads and its necessary for rigidity because its so thin.
An Indy one should work. They fit under the Indy heads because they're taller at the top rail but it should fit any head that has a stock height top rail (hope you know what I'm talking about!)
Re: ONE PIECE INTAKE MANIFOLD VALLEY PAN...... [Re: Stanton] #1777619
03/12/15 07:15 PM
03/12/15 07:15 PM
Q
Quicktree Offline
Quicktree  Offline
Q
better be checking the ring seal
Re: ONE PIECE INTAKE MANIFOLD VALLEY PAN...... [Re: Thumperdart] #1777620
03/12/15 07:23 PM
03/12/15 07:23 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Why not find some 1/8" or 3/16" aluminum plate, cut to fit the block & heads then weld it to the intake?
Re: ONE PIECE INTAKE MANIFOLD VALLEY PAN...... [Re: roadhazard] #1777621
03/12/15 10:39 PM
03/12/15 10:39 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
I could never keep the 440 Source one sealed.
Went back to old school bathtub.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: ONE PIECE INTAKE MANIFOLD VALLEY PAN...... [Re: Dabee] #1777622
03/12/15 10:50 PM
03/12/15 10:50 PM
Ft. Wayne, IN.
Q
QTR MILR Offline
QTR MILR  Offline
Q
Ft. Wayne, IN.
I had the same problem.... Tried to seal it several times and gave up and went back to the stock valley pan...
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
Re: ONE PIECE INTAKE MANIFOLD VALLEY PAN...... [Re: Dabee] #1777623
03/13/15 12:51 AM
03/13/15 12:51 AM
mississippi
bentwheel43 Offline
bentwheel43  Offline
mississippi
I never could get that 2 piece pan to seal.
Section 8 Racing We are nuts about racing.
Re: ONE PIECE INTAKE MANIFOLD VALLEY PAN...... [Re: Quicktree] #1777624
03/13/15 12:54 AM
03/13/15 12:54 AM
State of confusion
State of confusion
Motor seems fine but what is not fine is building engines while drinking vodka and using the wrong sealer around the ports but we'll soon see and I went with the stock valley pan.
Re: ONE PIECE INTAKE MANIFOLD VALLEY PAN...... [Re: Thumperdart] #1777625
03/13/15 01:06 AM
03/13/15 01:06 AM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
Which one did you use with the vodka and which one is the "right" one? Just curious as I dealt with a similar issue recently.
Re: ONE PIECE INTAKE MANIFOLD VALLEY PAN...... [Re: Belvedere1] #1777626
03/13/15 01:52 AM
03/13/15 01:52 AM
baldwinsville new york
a493demon Offline
a493demon  Offline
my engine with b-1 heads had a sheet alum. one and i know a guy that does cast alum. so i made a template and he cast one for me .
Re: ONE PIECE INTAKE MANIFOLD VALLEY PAN...... [Re: a493demon] #1777627
03/13/15 12:09 PM
03/13/15 12:09 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
It would be nice if they made something like this for standard port heads. This one took a lot of work to make it fit correctly on my stage VI heads but now that it fit good it sure is nice.
67' charger 499 RB 10.57 at 127
Re: ONE PIECE INTAKE MANIFOLD VALLEY PAN...... [Re: Belvedere1] #1777628
03/13/15 01:47 PM
03/13/15 01:47 PM
State of confusion
State of confusion
I used the valley pan, stock gaskets on both sides and aviation sealant which hardens.While the manifold is off I did more porting and port alignment to make it that much better then off to Vegas.
Re: ONE PIECE INTAKE MANIFOLD VALLEY PAN...... [Re: Thumperdart] #1777629
03/13/15 06:38 PM
03/13/15 06:38 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
made this, fits with heads on & when bolted up with some 3bond doesn't leak a bit.
Re: ONE PIECE INTAKE MANIFOLD VALLEY PAN...... [Re: rebel] #1777630
03/13/15 07:35 PM
03/13/15 07:35 PM
a493demon Offline
a493demon  Offline
^^^ that's what I had .
This is what I had made in cast alum.
Re: ONE PIECE INTAKE MANIFOLD VALLEY PAN...... [Re: a493demon] #1777631
03/13/15 07:36 PM
03/13/15 07:36 PM
a493demon Offline
a493demon  Offline
under side
Re: ONE PIECE INTAKE MANIFOLD VALLEY PAN...... [Re: rebel] #1777632
03/13/15 09:57 PM
03/13/15 09:57 PM
State of confusion
State of confusion
What heads are those cos I thaught very few fit rpm heads.
