Hydraulic clutch setup? #1777423
03/11/15 10:04 PM
03/11/15 10:04 PM
Stratford,Ct
7sec.cuda Offline OP
Stratford,Ct
I'm looking to install a hydraulic clutch setup (complete setup) in my 1965 plymouth belvedere with a 440 4 speed can anybody point me in the right direction or where and how to even start this project thanks Bob
Re: Hydraulic clutch setup? [Re: 7sec.cuda] #1777424
03/11/15 10:56 PM
03/11/15 10:56 PM
Aurora, CO
jbeintherockies Offline
Aurora, CO
Someone I know went with the McCleod hydraulic throw-out bearing assembly and said "it is veeery nice".
http://www.mcleodracing.com/index.php/hydraulics.html
Re: Hydraulic clutch setup? [Re: 7sec.cuda] #1777425
03/11/15 10:59 PM
03/11/15 10:59 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Our experiences with aftermarket hydraulic clutch setups have not been good. We have removed a lot of them due to multiple failures during the first 1-3 years. Maybe the offerings out there have improved but I am a show me type.
Re: Hydraulic clutch setup? [Re: TJP] #1777426
03/12/15 10:40 AM
03/12/15 10:40 AM
Texas
shart70rt Offline
shart70rt  Offline
Texas
I bought one from Jamie Passion, but have not installed it. Complete kit.
Stephen
70 Go Mango Charger RT
White Vinyl Top
18 Spline 4 speed
Lakewood Scatter Shield/ Centerforce DF Clutch, Hydraulic bearing
505 Stroker, dual 600's, hyd roller cam - 525 hp, 640 torque
Re: Hydraulic clutch setup? [Re: shart70rt] #1777427
03/12/15 11:40 AM
03/12/15 11:40 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
7 years ago, goldduster318 PM'd me this about his home brew hydraulic clutch conversion:
Anyways, for parts...it uses a wilwood 3/4" bore master cylinder with integrated resivaur (WIL-260-1304 from summit), a wilwood pull style slave cylinder WIL-260-1333. You'll also need to order another 5/16-24 spherical rod end to use with the master cylinder. To connect the two i used some standard brake tubing, and a front drum brake hose that i had taken off my car...although you could use some braided steel line (likely -3). Once you get that, you'll need a bracket to bolt the slave to the side cover of the transmission. I used the lower row of bolts and an 80's dodge truck motor mount that was cut in half. I've been thinking about changing it to bolt to the transmission cross member because the setup i have now seems to have caused a leak. Then, you'll need to drill a new hole in the clutch fork closer to the transmission than the original hole. I'd say its about 1/2 way between the original hole and the bellhousing.
to mount the slave cylinder, i had to relocate my voltage regulator to a slightly different spot (mine is now above the pinch weld in the engine bay, instead of next to the master cylinder). Then you'll need to mount the master cylinder at the same height as the master cylinder for the brakes. I drilled the holes tight and just hammered in some proper length bolts from the other side for studs. You'll need to remove your pedal assembly and drill a hole in it at the same relative place on the clutch pedal as it is for the brake pedal. Then you just have to install the spherical rod end, adjust it so you have a small amount of freeplay before it works, bleed the system, and you're done.
hope that helps you. My engine is out so its difficult for me to get really descriptive pictures
Re: Hydraulic clutch setup? [Re: DaytonaTurbo] #1777428
03/12/15 12:38 PM
03/12/15 12:38 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
speedway has units made for circle track racers and hot rodders---some on firewall and some mount to floorboard....
Re: Hydraulic clutch setup? [Re: savoy64] #1777429
03/12/15 10:02 PM
03/12/15 10:02 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
Call Gray at American Powertrain. I can post some pics of my Dart install if you want.
383, Hemi 4-Speed, AlterKtion, D60
Re: Hydraulic clutch setup? [Re: Crazy68Dart] #1777430
03/13/15 12:10 AM
03/13/15 12:10 AM
IN
ahy Offline
ahy  Offline
IN
I run a Keisler setup (now Silver Sport) on a BB equipped "E". Hydraulic TO bearing type. It is the earlier version and slow to bleed but has been trouble free for 10+ years and 12k+ miles once bled.
Re: Hydraulic clutch setup? [Re: ahy] #1777431
03/13/15 04:07 PM
03/13/15 04:07 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't be the exception.
Re: Hydraulic clutch setup? [Re: 7sec.cuda] #1777432
03/14/15 12:54 AM
03/14/15 12:54 AM
You have a PM
