Page 1 of 3 1 2 3
4.56 or 4.88 Gears? #1777306
03/11/15 08:15 PM
03/11/15 08:15 PM
Tucson AZ,
MadMopars Offline OP
Tucson AZ,
I'm trying to decide if I should go with 4.56 or 4.88 gears and would like some input. Current details as follows. Eventually I will probably throw more motor at it though...
69 Dart
440 w/ 10.5:1 compression
906 Heads w/2.14 1.81 Valves
M1 Single Plane Intake or M1 Tunnel Ram
Hughes 246/252 555/572 Solid Cam
4 Speed
Dana 60
30/13.50/15 E.T Streets
This is a track car that will be driven on the street, however I am more concerned with track performance than how streetable it is.
Any input is appreciated. Thanks guys!
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: 4.56 or 4.88 Gears? [Re: MadMopars] #1777307
03/11/15 08:19 PM
03/11/15 08:19 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
4.10
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 4.56 or 4.88 Gears? [Re: MadMopars] #1777308
03/11/15 08:20 PM
03/11/15 08:20 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
4.56
I am building a GTX with same 30 inch tall tires. I am going with 4.56 with a Dana 60 but will install a Gear Vendor OD.
My race car used to be driven on the street with 30 inch tires and 4.56 gears. Car went high 10's with a 440 and 906 heads before I rebuilt the car to go faster.
For my stuff no way would I consider 4.88 with this type of combo. Nothing to gain in my opinion..........
Re: 4.56 or 4.88 Gears? [Re: pittsburghracer] #1777309
03/11/15 08:21 PM
03/11/15 08:21 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: 4.56 or 4.88 Gears? [Re: MadMopars] #1777310
03/11/15 08:22 PM
03/11/15 08:22 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
That cam is kind of small. I think you'll run out of rpm if you go with 4.88's. I run 4.56's with a 29" slick and trap right around 6450 rpm. I don't think that cam will rev that high and produce power. Just my
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: 4.56 or 4.88 Gears? [Re: MadMopars] #1777311
03/11/15 08:35 PM
03/11/15 08:35 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
69 Dart
4 Speed
Dana 60
What kind of R`s are you hitting through the eyes now? What is the peak RPM ?
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: 4.56 or 4.88 Gears? [Re: chryco] #1777312
03/11/15 08:44 PM
03/11/15 08:44 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
What is the 1st gear ratio of the 4 speed? I normally would run less gear with an automatic. But this isn't a automatic. My bet it might like the 4.88. I'd ask here:
https://www.facebook.com/pages/United-Manual-Transmission-Racers/350986960125
Doug
Re: 4.56 or 4.88 Gears? [Re: MadMopars] #1777313
03/11/15 08:49 PM
03/11/15 08:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Being a stick car you will save about 7% on the RPM
due to no conv slippage... what did you calculate for
your engine rpm when you were building it
Re: 4.56 or 4.88 Gears? [Re: W.I.N. Racing] #1777314
03/11/15 08:49 PM
03/11/15 08:49 PM
Q
Quicktree Offline
Quicktree  Offline
Q
lol I was thinking the same thing, you will not like a 456 on the street and you wont be giving up much if any.
Re: 4.56 or 4.88 Gears? [Re: Quicktree] #1777315
03/11/15 10:52 PM
03/11/15 10:52 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
What size tire do you plan on using ? Ron
Re: 4.56 or 4.88 Gears? [Re: 383man] #1777316
03/11/15 10:54 PM
03/11/15 10:54 PM
PA.
"Little"John
"Little"John
PA.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 4.56 or 4.88 Gears? [Re: pittsburghracer] #1777317
03/11/15 11:02 PM
03/11/15 11:02 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use a 30 x 9 Hoosier radial slick and I have 4.30's. I drive it on the street with them and race on them and its an auto car. It works nice for me as I shift about 6200 and trap about 6400 but I do have some converter slippage with an auto. Ron
Re: 4.56 or 4.88 Gears? [Re: MadMopars] #1777318
03/11/15 11:05 PM
03/11/15 11:05 PM
What altitude is the track you want to race it at? If below 2500 Ft (Wildhorse in Phoenix)try the 4.56, if above 2500 ft. altitude go with the 4.89 Are you going to race it in the summer there in Tuscon? If so go with the 4:89 ratio due to the severe D.A. changes in the summer in AZ
Re: 4.56 or 4.88 Gears? [Re: MadMopars] #1777319
03/12/15 12:22 AM
03/12/15 12:22 AM
Tucson AZ,
Tucson AZ,
I assembled the motor for this car over 10 years ago. It is much milder than what I would build today but I'm going to run it for now and change things around further down the road. I have not made a pass in the car yet
Using the Direct Connection formula I'm thinking 4.56 is the way go. As much as I'd like to use the 4.10's I already have, I can't believe they are the right gear to use in my application. At least not for the goals I have with the car.
I have seen E.T. gains in my low compression GTX build each time I've put in a lower gear from 4.30's to 4.56 to 4.88's FWIW.
Thoughts on the D.C. formula?
Re: 4.56 or 4.88 Gears? [Re: MadMopars] #1777320
03/12/15 12:33 AM
03/12/15 12:33 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
4.56, unless you're running 1/8th mile you will be out of steam before you trap.
I'm running 4 speed 4.56 with 29.5 tires on the street, its great.
Re: 4.56 or 4.88 Gears? [Re: MadMopars] #1777321
03/12/15 02:30 AM
03/12/15 02:30 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
4:88 but we run 1/8 mile down here. 31 inch tire, 6000 at the stripe.
Re: 4.56 or 4.88 Gears? [Re: pittsburghracer] #1777322
03/12/15 02:35 AM
03/12/15 02:35 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
This and you will be glad you did.
Re: 4.56 or 4.88 Gears? [Re: Thumperdart] #1777323
03/12/15 02:53 AM
03/12/15 02:53 AM
Tucson AZ,
Tucson AZ,
Anyone have details on tire size and trap RPM with 4.10's? Ever tried a lower gear for comparison? I have the 4.10's already, I'm just not sold on them...
BTW, I edited my last post...
Re: 4.56 or 4.88 Gears? [Re: MadMopars] #1777324
03/12/15 03:04 AM
03/12/15 03:04 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I ran the 30 in et streets and my trap speed was 133 and 9.95 on the et traping at 6800 iirc.
Re: 4.56 or 4.88 Gears? [Re: Thumperdart] #1777325
03/12/15 03:16 AM
03/12/15 03:16 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
if he has a 23 spline 4 spd 1st gear is like 267 I think 18 spline is 268 can't remember. But op said he wants to run more track time than street. If he is running 1/8th mile only, he will be banging alot of gear quick, but he could use a better cam or retard it 2 degrees. My vote would be 456 or even 488's. Since he has the 410's now,I'd try them first, that is what T&T is about. But leave the cam straight up.
I run 513 this time out with a 2 spd myself. 1/8th mile only. 456 wasnt even close with my combo. but my engine builds big power after 6k.
You will get lots of opinions here. With certain combo's from certain people.You will like the M1 tunnel ram. It does make good power on a 440. If you are looking for 1/2 tenths stepping up will help.Just remember that you have to make it hook up and 4 speeds are hard on parts.
Page 1 of 3 1 2 3
