4.56 or 4.88 Gears?
#1777306
03/11/15 08:15 PM
03/11/15 08:15 PM
Posts: 1,292 Tucson AZ,
MadMopars
Tucson AZ,
I'm trying to decide if I should go with 4.56 or 4.88 gears and would like some input. Current details as follows. Eventually I will probably throw more motor at it though... 69 Dart 440 w/ 10.5:1 compression 906 Heads w/2.14 1.81 Valves M1 Single Plane Intake or M1 Tunnel Ram Hughes 246/252 555/572 Solid Cam 4 Speed Dana 60 30/13.50/15 E.T Streets This is a track car that will be driven on the street, however I am more concerned with track performance than how streetable it is. Any input is appreciated. Thanks guys!
Re: 4.56 or 4.88 Gears?
[Re: MadMopars]
#1777308
03/11/15 08:20 PM
03/11/15 08:20 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
4.56
I am building a GTX with same 30 inch tall tires. I am going with 4.56 with a Dana 60 but will install a Gear Vendor OD.
My race car used to be driven on the street with 30 inch tires and 4.56 gears. Car went high 10's with a 440 and 906 heads before I rebuilt the car to go faster.
For my stuff no way would I consider 4.88 with this type of combo. Nothing to gain in my opinion..........
[Re: pittsburghracer]
#1777309
03/11/15 08:21 PM
03/11/15 08:21 PM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: MadMopars]
#1777313
03/11/15 08:49 PM
03/11/15 08:49 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Being a stick car you will save about 7% on the RPM due to no conv slippage... what did you calculate for your engine rpm when you were building it
[Re: W.I.N. Racing]
#1777314
03/11/15 08:49 PM
03/11/15 08:49 PM
Quicktree
lol I was thinking the same thing, you will not like a 456 on the street and you wont be giving up much if any.
#1777317
03/11/15 11:02 PM
03/11/15 11:02 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
What size tire do you plan on using ? Ron
I use a 30 x 9 Hoosier radial slick and I have 4.30's. I drive it on the street with them and race on them and its an auto car. It works nice for me as I shift about 6200 and trap about 6400 but I do have some converter slippage with an auto. Ron
[Re: MadMopars]
#1777319
03/12/15 12:22 AM
03/12/15 12:22 AM
MadMopars
Tucson AZ,
I assembled the motor for this car over 10 years ago. It is much milder than what I would build today but I'm going to run it for now and change things around further down the road. I have not made a pass in the car yet Using the Direct Connection formula I'm thinking 4.56 is the way go. As much as I'd like to use the 4.10's I already have, I can't believe they are the right gear to use in my application. At least not for the goals I have with the car. I have seen E.T. gains in my low compression GTX build each time I've put in a lower gear from 4.30's to 4.56 to 4.88's FWIW. Thoughts on the D.C. formula?
[Re: MadMopars]
#1777320
03/12/15 12:33 AM
03/12/15 12:33 AM
Posts: 5,163 CT
GTX MATT
CT
4.56, unless you're running 1/8th mile you will be out of steam before you trap. I'm running 4 speed 4.56 with 29.5 tires on the street, its great.
[Re: Thumperdart]
#1777323
03/12/15 02:53 AM
03/12/15 02:53 AM
MadMopars
Tucson AZ,
This and you will be glad you did.
Anyone have details on tire size and trap RPM with 4.10's? Ever tried a lower gear for comparison? I have the 4.10's already, I'm just not sold on them...
BTW, I edited my last post...
