Carb adaptor thickness ? #1777298
03/11/15 07:59 PM
03/11/15 07:59 PM
Mentor,Oh.
fattire Offline OP
fattire  Offline OP
Mentor,Oh.
What the thinnest adaptor you would use or does it matter hood clearance is an issue? Going to a Dom from a Demon.
Re: Carb adaptor thickness ? [Re: fattire] #1777299
03/11/15 08:25 PM
03/11/15 08:25 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
2 inch. The thin ones are useless.
Re: Carb adaptor thickness ? [Re: markz528] #1777300
03/11/15 10:55 PM
03/11/15 10:55 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use a 1" as its all I can fit under my hood. But I dont use it for performance as I use a phenolic spacer to help fight eng heat in the carb and its a big help. Since mine is a street car I really need it. Ron
Re: Carb adaptor thickness ? [Re: 383man] #1777301
03/11/15 11:02 PM
03/11/15 11:02 PM
Mentor,Oh.
fattire Offline OP
fattire  Offline OP
Mentor,Oh.
Yes not using the spacer for any performance gains just want to be able to get the gains from the Dom.
Re: Carb adaptor thickness ? [Re: fattire] #1777302
03/11/15 11:16 PM
03/11/15 11:16 PM
AndyF Offline
AndyF  Offline
What engine combo? If it is a big block you can buy a Mopar M1 4500 intake fairly cheap and they work great.
Re: Carb adaptor thickness ? [Re: fattire] #1777303
03/12/15 01:21 AM
03/12/15 01:21 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I think the shorter one is an issue myself and run the 2 in. plus a half in. 4 hole wooden spacer to help with heat and make it taller to lengthen the runners and improve the signal.
Re: Carb adaptor thickness ? [Re: Thumperdart] #1777304
03/12/15 10:11 AM
03/12/15 10:11 AM
Mentor,Oh.
fattire Offline OP
fattire  Offline OP
Mentor,Oh.
That's the info I needed Thumper thanks, I'm running a Victor now Andy and like it probably not a lot of difference between them.
Re: Carb adaptor thickness ? [Re: markz528] #1777305
03/12/15 11:02 AM
03/12/15 11:02 AM
an8sec70cuda Offline
CHIP
'06 GMC 2500HD LBZ Duramax
