fuel cell vent line fumes
#1776848
03/11/15 01:19 AM
03/11/15 01:19 AM
Posts: 768 Fla
birdboy
Fla
jazz fuel cell, vent line goes out through floor. if left in trailer or in my shop over night heavy fumes smell present. any ideas? thanks
the more I deal with people the more I like my dog
Re: fuel cell vent line fumes
[Re: Aspen7695]
#1776850
03/11/15 01:47 AM
03/11/15 01:47 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Put a shut off valve in the vent tube and shut it off when you are not at the track. It will keep the system sealed and not as much gas will evaporate.
Raul
And if the tank heats up it will pressurize it and turn it into a ball... he can put a charcoal canister on the vent line.. but every once in a while he will have to blow it out with air to purge the vapors
[Re: birdboy]
#1776851
03/11/15 02:17 AM
03/11/15 02:17 AM
MR_P_BODY
Just go to the junk yard and get 2 older charcoal canisters(a lot of yards throw them in a pile) and leave one in the trailer and one in the shop.. run a rubber hose to your vent line.. just plug it on when you park in the trailer or shop
[Re: birdboy]
#1776853
03/12/15 07:22 PM
03/12/15 07:22 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
What kind of gas?? I know out west here that pump gas will actually have the odor leach through steel braided lines. Has nothing to do with the vent at all. Not sure you have the same issues in FL but it was a big issue in Cali with pump gas
[Re: rapom]
#1776854
03/12/15 08:02 PM
03/12/15 08:02 PM
MR_P_BODY
Here is a very easy solution. Use an aluminum fuel line and make a couple of coils in it before you run it out your trunk floor.
Kind of works like a sink trap.
It works great.
The loops catch liquid but vapor will still travel through the loops.. if he has a vapor issue there is ONLY one way to kill it and thats the canister.. being I worked in the fuel lab for 30+ years I have played with this a LOT... if it is coming through the braided line then he would have to change the line to either viton lined or teflon lined to elininate the permeation through the line... even a Jass or other manufacturer plastic tanks will permeate vapor through it but most likely the bulk of the vapor is going out the vent and thats where the canister will help big time... I dont know of any fuel cells that have a permeation barrier made into them
[Re: Aspen7695]
#1776856
03/13/15 12:55 AM
03/13/15 12:55 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Wouldn't the charcoal canister 'self purge' as fuel is used up, sucking fresh air back into it as it pulls in air to replace the fuel the car burns?
**Photobucket sucks**
[Re: 70Cuda383]
#1776857
03/13/15 02:17 AM
03/13/15 02:17 AM
MR_P_BODY
Thats if you keep it hooked up.. being a race car I would pull it off and just use it when parked
[Re: Aspen7695]
#1776858
03/13/15 02:21 AM
03/13/15 02:21 AM
MR_P_BODY
Mr. P Body Here in Arizona it is over 105* all summer long and I have not had a problem in 10 years.
Raul
Yeah I know how hot it gets there.. I tested fuel systems out in Phoenix for 20 years+ out at the test track.. I'm glad it worked for you
[Re: MR_P_BODY]
#1776859
03/13/15 10:20 AM
03/13/15 10:20 AM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
Empty the fuel tank when in storage . Problem solved ......works for me.
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
[Re: Al_Alguire]
#1776860
03/13/15 05:38 PM
03/13/15 05:38 PM
Posts: 1,883 Northern OH
rapom
Northern OH
I agree with the fuel leaching through the lines. I had to replace mine with teflon lined braided lines and fittings. I used 3 loops at about 8" in diameter and I have a fuel filter at the end before exiting the trunk. I also have the loops above the fuel cell so no fuel can slosh into them.
It does work and it's cheap so if it doesn't work try the charcoal canister.
[Re: rapom]
#1776861
03/17/15 11:51 PM
03/17/15 11:51 PM
Posts: 768 Fla
birdboy
Fla
pump gas, braided line, emptying not a option as when at the track the trailer has living qtrs , I really dont want to drain it just to park it overnight. thanks for the ideas
