Finally !!! Daytona moves under its own HEMI power #1775290
03/09/15 10:08 AM
03/09/15 10:08 AM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Well, Saturday the day finally came to put the Daytona on the ground and take it for a spin around the block. If weather is better this week, I'll take her out and about. But, it gave me a good opportunity to take pictures next to its racing cousin, my '70 T/A..
http://youtu.be/Bj-4zjGEZNQ
Troy
Houston Mopar Connection Club
Re: Finally !!! Daytona moves under its own HEMI power [Re: hemi68charger] #1775291
03/09/15 10:12 AM
03/09/15 10:12 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Sweet!! Both awesome cars!! Enjoy! Sounds great too!!
Re: Finally !!! Daytona moves under its own HEMI power [Re: hemi68charger] #1775292
03/09/15 10:12 AM
03/09/15 10:12 AM
Houston, Tx
Houston, Tx
Engine:
Bill et al,
I reference the replies and FSM and believe I have both the ft/rear carb's in sequence with the linkage and the tranny kickdown adjusted properly. I did notice however that the vertical rod for the kickdown wasn't long enough and I had to fabricate an extension in order for the ball/socket connection to fit with the tranny pressure arm fully forward down on the transmission.
Troy
Re: Finally !!! Daytona moves under its own HEMI power [Re: hemi68charger] #1775293
03/09/15 10:13 AM
03/09/15 10:13 AM
Houston, Tx
Houston, Tx
some more..
Troy
Re: Finally !!! Daytona moves under its own HEMI power [Re: hemi68charger] #1775294
03/09/15 10:14 AM
03/09/15 10:14 AM
Houston, Tx
Houston, Tx
T/A side..
Troy
Re: Finally !!! Daytona moves under its own HEMI power [Re: hemi68charger] #1775295
03/09/15 10:27 AM
03/09/15 10:27 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Wow! Car looks SWEET! The wheels set it off really nice
Re: Finally !!! Daytona moves under its own HEMI power [Re: ScottSmith_Harms] #1775296
03/09/15 11:00 AM
03/09/15 11:00 AM
Houston, Tx
Houston, Tx
Thanks Scott. I believe I have the carbs dialed in. She's running about 850-900 rpm with 13" of vacuum and about 750 in gear without any loading up or stain to stay running ( 2400-2800 stall convertor ). The proof will be when I take her out and about. I think I'm also zeroing in on the choke adjustment. It doesn't stick anymore, so now it is just a function of the positioning of the black dashpot and the setting on the fast-idle cam..
Troy
Re: Finally !!! Daytona moves under its own HEMI power [Re: ScottSmith_Harms] #1775297
03/09/15 09:34 PM
03/09/15 09:34 PM
Puttin' on the foil in Charles...
not_a_charger Online mad
Mr. Big Shot Moparts Moderator
not_a_charger  Online Mad
What kind of wheels are those? They kinda look like LRE chrome slots re-done in black. They look nice on the car.
Earning every penny of that moderator paycheck.
DBAP
Re: Finally !!! Daytona moves under its own HEMI power [Re: not_a_charger] #1775298
03/09/15 09:57 PM
03/09/15 09:57 PM
Houston, Tx
Houston, Tx
The wheels are from Bart Wheels. They made the Grand National wheels back in the day and are still in business. These are from the later '71 and on seasons. They do look great, but not correct for 1970 and earlier. The only drawback is the 15x8's can only be made with a 4" backspacing, hence the sidewall is REAL close to the wheel well opening and I have to be careful. Otherwise, I have to jack up the torsion bars for clearance, then I loose the look I'm going for,,
Troy
Re: Finally !!! Daytona moves under its own HEMI power [Re: hemi68charger] #1775299
03/16/15 03:26 PM
03/16/15 03:26 PM
Houston, Tx
Houston, Tx
Finally Part2, cruise to the local Saturday Night cruise-in !!!!!
I was able to get her out and drive to a show ( local Nifty50ees Saturday Night gathering place in Northwest Houston area ). Got there a little early to give myself time in the event something would happen. Drove her all the way there, regular stop-n-go traffic, lights, etc. She didn't get above 190-ish it appears. RIght now I have no thermostat in it. Did that initially to promote the leak sealant solution to work through the system. I will change out to a high flow 160 thermostat from JEGS soon. I still have some tweeking to do of course, mostly on the distributor and its timing characteristics. Other than that, she did great. I was pleased...... Crowd loved the car and the open headers... Love the QTP electric dumps...
Troy
Re: Finally !!! Daytona moves under its own HEMI power [Re: hemi68charger] #1775300
03/16/15 03:26 PM
03/16/15 03:26 PM
Houston, Tx
Houston, Tx
Engine...
Troy
Re: Finally !!! Daytona moves under its own HEMI power [Re: hemi68charger] #1775301
03/16/15 03:27 PM
03/16/15 03:27 PM
Houston, Tx
Houston, Tx
says it all...
Troy
Re: Finally !!! Daytona moves under its own HEMI power [Re: hemi68charger] #1775302
03/16/15 03:28 PM
03/16/15 03:28 PM
Houston, Tx
Houston, Tx
cool shot
Troy
Re: Finally !!! Daytona moves under its own HEMI power [Re: hemi68charger] #1775303
03/16/15 04:03 PM
03/16/15 04:03 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
How did you resolve your starter 'issue'???
Re: Finally !!! Daytona moves under its own HEMI power [Re: RSNOMO] #1775304
03/16/15 04:57 PM
03/16/15 04:57 PM
Sweden
71redcuda Offline
71redcuda  Offline
Sweden
This car is so good looking, super nice!
Re: Finally !!! Daytona moves under its own HEMI power [Re: RSNOMO] #1775305
03/16/15 06:00 PM
03/16/15 06:00 PM
Houston, Tx
Houston, Tx
As it turned out, it was really my torque converter ring gear. The first time it happened, the broken teeth were at the top of the converter and hence I didn't see the broken teeth. The second time I addressed it, thinking that I had a bad starter, it happened again. This time, the borken teeth were visible because they were at the bottom of the converter...... So, I went ahead and just got a completely new converter since I didn't trust the one I had in there...
Troy
Re: Finally !!! Daytona moves under its own HEMI power [Re: hemi68charger] #1775306
03/23/15 10:39 PM
03/23/15 10:39 PM
Houston, Tx
Houston, Tx
Crankin' the 426 Hemi up:with QTP electric dumps...
https://youtu.be/fA_UlCW07Eo
Troy
Re: Finally !!! Daytona moves under its own HEMI power [Re: hemi68charger] #1775307
03/23/15 11:03 PM
03/23/15 11:03 PM
Massachusetts
LYNCHROAD69.5 Offline
Massachusetts
Crankin' the 426 Hemi up: https://youtu.be/fA_UlCW07Eo
Wow...that sounds bad #%@&*. Open exhaust?
Re: Finally !!! Daytona moves under its own HEMI power [Re: LYNCHROAD69.5] #1775308
03/24/15 09:28 AM
03/24/15 09:28 AM
Houston, Tx
Houston, Tx
QTP electric dumps....
Troy
