Page 1 of 3 1 2 3
My 337 MW intake....(updated w/pic) #1774972
03/08/15 09:34 PM
03/08/15 09:34 PM
Weddington, N.C.
Streetwize Offline OP
Weddington, N.C.
I took my Virgin MP 337 Max Wedge intake manifold over to Hollis at HP Engines on Friday to have ( 35 year NASCAR engine legend) Larry Smith work it over. Super Nice guy and worked for both Penske AND Evranham on the Dodge motors....can't wait to get it back
Thinking I might let have to let him work on my Victor 340 some more too.
WIZE
In Car:
Re: My 337 MW intake.... [Re: Streetwize] #1774973
03/08/15 11:30 PM
03/08/15 11:30 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
Bobby, please post some pics when you get it back. Is he doing plenum work too?
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: My 337 MW intake.... [Re: Old School] #1774974
03/08/15 11:42 PM
03/08/15 11:42 PM
Weddington, N.C.
Weddington, N.C.
Hey buddy!
Long time, no hear!!
Larry is gonna make the chips fly all the way through it. Either Hollis or I will post up some pics.
Really excited to have this level of talent working on in.
WIZE
In Car:
Re: My 337 MW intake.... [Re: Streetwize] #1774975
03/10/15 04:11 AM
03/10/15 04:11 AM
FT Campbell, KY / Clarksville,...
The Cuda Guy Offline
Street what are you going to be this intake on? What kind of power you think its going to make?
Don
Street/Strip 73 Barracuda
Re: My 337 MW intake.... [Re: The Cuda Guy] #1774976
03/10/15 04:28 AM
03/10/15 04:28 AM
SHELBY TWP,,MICHIGAN
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
I have this Vintage NOS Edelbrock intake for a low deck motor which I hear they only made a few years..Id like to put it on a 512 stroker build for my 63 to keep with a max wedge theme..Ive heard bad stories about blowing the lid open on these intakes from poor flow and fuel puddling..I would like to know if your guy could give me any help bullet proofing this intake..??
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: My 337 MW intake.... [Re: 72N96RR] #1774977
03/10/15 10:49 AM
03/10/15 10:49 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Add a couple pop off valves. If you want to avoid drilling holes in the lid (I wouldn't drill a nice original lid) just add some spacer plates under the carbs and add holes to the sides of the plates.
Re: My 337 MW intake.... [Re: ScottSmith_Harms] #1774978
03/10/15 11:00 AM
03/10/15 11:00 AM
Weddington, N.C.
Weddington, N.C.
It's going on my 517 Low Deck (Chapman Stage VI Max Wedge Heads )in place of my ported Indy dual plane.
https://www.youtube.com/watch?v=lN9uEzqzdA0
WIZE
In Car:
Re: My 337 MW intake.... [Re: Streetwize] #1774979
03/10/15 03:49 PM
03/10/15 03:49 PM
Weddington, N.C.
Weddington, N.C.
@ 72N96RR
Call HP Engines at (704) 474-0109
hpengines.net
Ask for Larry Smith
WIZE
In Car:
Re: My 337 MW intake.... [Re: 72N96RR] #1774980
03/10/15 03:53 PM
03/10/15 03:53 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
simpler method would be just run chokes on the carbs and that wont happen. I went 140mph with edles with chokes.
Re: My 337 MW intake.... [Re: 72N96RR] #1774981
03/10/15 04:27 PM
03/10/15 04:27 PM
Cab_Burge Online work
Cab_Burge  Online Work
If you run Holleys on it use soft slip on rubber caps on the PCV tubes on the throttle plates as a blow off valve A friend of mine did that on his stock M.W. Mopar crossram using Holley 650 D.P. carbs because he had heard the same thing about them The best solution on start up is to make certain you have the primary throttle blades open 1/4 to 1/3 of the way open every time you start it in case it does try to sneeze so the pressure has a way out of the manifold
Re: My 337 MW intake.... [Re: Cab_Burge] #1774982
03/10/15 10:02 PM
03/10/15 10:02 PM
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
Excellent information from everyone thank you..This was my (Scotts) first solution..1/2 inch spacer with 140 psi pop off valves inserted into the pcv holes..These with rubber caps on the holley throttle plates should be enough insurance in case of a hiccup.. whaddya think??
Re: My 337 MW intake.... [Re: 72N96RR] #1774983
03/10/15 10:56 PM
03/10/15 10:56 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
I think the pop off valves are too small. you need volume and actuation at much lower pressure. if you want I can mod those with a custom plate. I would drill 3-4 holes per side about 1/2" each. held closed with a 1/4 in plate held down with two smaller springs.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: My 337 MW intake.... [Re: Jerry] #1774984
03/10/15 11:38 PM
03/10/15 11:38 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Agreed. Way too small.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: My 337 MW intake.... [Re: DusterDave] #1774985
03/10/15 11:53 PM
03/10/15 11:53 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
FWIW I have messed around with multiple Xram setups using dual 3/4" pop offs over the years (30 or so years), most were Hemi's and small blocks. To date I've never had an intake crack when it "sneezed", the valves did their thing. Having said that, a larger opening with a plate, or more valves, wouldn't hurt any, the more pressure relief and the faster, the better.
Re: My 337 MW intake.... [Re: ScottSmith_Harms] #1774986
03/11/15 12:39 AM
03/11/15 12:39 AM
Weddington, N.C.
Weddington, N.C.
And now back to our regularly scheduled broadcast
Larry is done with the manifold ( the one without a pop-off valve, lol) I'll try to post pics in a day or 2
WIZE
In Car:
Re: My 337 MW intake.... [Re: ScottSmith_Harms] #1774987
03/11/15 12:40 AM
03/11/15 12:40 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Why the 140PSI valves, waaaay to much, IMO. The manifold is normally under vacuum .
I don't think I would want any more then +50 PSI in that intake.
Re: My 337 MW intake.... [Re: Streetwize] #1774988
03/11/15 12:45 AM
03/11/15 12:45 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Oh yeah, I forgot this was your thread.
I saw your vid before of your 512ci charger. It does sound mean as hey.
I forget, what cam and comp, do you have in that beast that makes it sound like that.
Re: My 337 MW intake.... [Re: Sport440] #1774989
03/11/15 01:41 AM
03/11/15 01:41 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I meant to comment on that....To clarify, I didn't customize his intake, I just offered him the idea. I am also a proponent of a very soft valve, because, as you pointed out, the intake is under vacuum, no need for a high pressure opening valve.
Re: My 337 MW intake.... [Re: Streetwize] #1774990
03/11/15 10:08 AM
03/11/15 10:08 AM
an8sec70cuda Offline
Bobby... if you don't mind me asking, what does it cost to have him port a manifold? Wonder if he's ever whittled on a Barton hemi manifold? You can PM me w/ cost if you want. I've always wondered if there is any real benefit to having the manifold fully ported. Not flow bench results, but timeslip results.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: My 337 MW intake.... [Re: an8sec70cuda] #1774991
03/11/15 12:41 PM
03/11/15 12:41 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Chip, every intake I have ever run gets ported. Since I ported Nesbitt's intake he can't control wheelstand issues. I put in 2 hours work on Terry Shaw's intake just trying something that I thought would help and he picked up 1 mph and it will pick up more because it was very lean and his heads are stock.
Nesbitt's intake
Page 1 of 3 1 2 3
