Page 2 of 3 1 2 3
Re: My 318 is a dog, Need to make a change ! [Re: RapidRobert] #1773503
03/06/15 10:46 PM
03/06/15 10:46 PM
IN
ahy Offline
ahy  Offline
IN
With low compression, you have to go pretty deep into the engine to get it healthy... at that point the used 5.9 magnum looks pretty good. Better heads, decent compression and more cubes.
Re: My 318 is a dog, Need to make a change ! [Re: MileHighDart] #1773504
03/07/15 12:40 AM
03/07/15 12:40 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
If you do anything to the engine, compliment the rest of the power/drivetrain package with a quality/tweaked-to-your-combo torque converter and some deeper gears. It'll be a whole new car.
My 318 wasn't very complicated and managed a 13.6...not too shabby. Get the engine where you will be comfortable with it, and tune the rest of the driveline to work together.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: My 318 is a dog, Need to make a change ! [Re: MileHighDart] #1773505
03/07/15 01:29 PM
03/07/15 01:29 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I guess it would depend on how much time and money you got. AND how bad you want to break the motor down. Before I went crazy and started tearing stuff apart I'd get a set of headers, a better intake and top that w/ a holley 650DP, then try a set of 1.6 roller rockers. As mention advance it some more. And you really should step up to 3.55's unless you do a ton of hwy driving.
Coming soon!!!!
Re: My 318 is a dog, Need to make a change ! [Re: Mr.Yuck] #1773506
03/07/15 02:03 PM
03/07/15 02:03 PM
Lyons, CO
MileHighDart Offline OP
Lyons, CO
Good suggestions so far, except for the 440 talk, those guys must not have seen the part about the budget.
Anyway, changing the gears to 3;55 or 3:91, probably would help wake it up, but that's not happening. I'd say 90% of my driving is on the highway.
I live in a small town, and although driving around town with 3:91's would be fun, driving around town in Lyons takes about 5 minutes max.
It I want to go do something I either have to hit the highway for 15 miles to Boulder, or 12 miles to Longmont. I'm not going to do that with the engine screaming along at 3000rpm. So until I get an overdrive, steeper gears are out.
Re: My 318 is a dog, Need to make a change ! [Re: MileHighDart] #1773507
03/07/15 02:29 PM
03/07/15 02:29 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I drive mine 51 one way to the track. 90% hwy w/ a 3800 stall and 3.91's. Not a big deal 3k isn't screaming. I missed that part about altitude... I know you think Feets is crazy but a simple small turbo would give what you need w/ tearing the engine apart.
Re: My 318 is a dog, Need to make a change ! [Re: MileHighDart] #1773508
03/07/15 04:17 PM
03/07/15 04:17 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
best bang for the buck will be a higher stall torque converter.
Cylinder pressures for this altitude are not too bad. Cam, intake, carb, exhaust are OK.
A set of the newer magnum type heads with smaller chambers will flow better and increase the compression ratio. Check Hughes Engines for the EQ (Iron Ram) heads for the LA engine block.
Re: My 318 is a dog, Need to make a change ! [Re: 451Mopar] #1773509
03/07/15 04:39 PM
03/07/15 04:39 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
EQ heads cost as much as a low mile JY 5.9
Re: My 318 is a dog, Need to make a change ! [Re: HotRodDave] #1773510
03/07/15 05:00 PM
03/07/15 05:00 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Not a bad choice either. I got a JY 6.1 Hemi with trans for $4k, but it is not an easy swap.
Re: My 318 is a dog, Need to make a change ! [Re: 451Mopar] #1773511
03/07/15 05:24 PM
03/07/15 05:24 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
At that altitude your engine is screaming for forced induction. Flip the exhaust manifolds buy an ebay turbo for $350. Spend a couple hundred more for plumbing, mod your carb for a blow through application and your done.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: My 318 is a dog, Need to make a change ! [Re: 451Mopar] #1773512
03/07/15 05:25 PM
03/07/15 05:25 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
From an earlier post (I am sorry) I forgot who it was
"At the very least I would stroke a fresh 318 to 390ci or so and put either 302 or 308 iron heads on it with a cam designed for your combo at that elevation. Or as others have said TURBO on a good healthy engine."
There are several shops out there that have either a steel or a cast crank package with high compression pistons and good rods for $1200 to $1500 Leave the rest of the combo alone. I am planning that same deal for a truck 360 that already is .030 over for my D100. I may have to go lower on the compression because I live @ 600' (at the foot of Mt. Rainier) and you can get away with more. Good LUck
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: My 318 is a dog, Need to make a change ! [Re: HotRodDave] #1773513
03/08/15 01:45 AM
03/08/15 01:45 AM
Illinois
StrkrDart69 Offline
StrkrDart69  Offline
Illinois
Magnum 360
Air gap intake
360 oil pan
Keep the serpantine set up get a cheap in line fuel pump and it will walk all over your current combo. Your current combo is terrible. A piston swap only gets you more compression, magnum heads help power all around but you got to buy different PRs and the heads and still have a flat tappet cam. The best part is you can do it in a weekend VS how long will machining a block have you engine down? You don't even know you can just stick pistons in till you tear it down, the rings on the KB167 go higher up the bore.
Re: My 318 is a dog, Need to make a change ! [Re: StrkrDart69] #1773514
03/08/15 06:58 AM
03/08/15 06:58 AM
PA
Sir Valiant Offline
Sir Valiant  Offline
PA
Personally I would just try a gear change. I have a 318 in my 64 Valiant vert and it still has the original 7 1/4 which seems to be a pretty low ratio and the car did 14.5's in the 1/4 even with a huge vacuum leak!
If you were closer you could try my spare 3.91's.
Re: My 318 is a dog, Need to make a change ! [Re: MileHighDart] #1773515
03/08/15 02:11 PM
03/08/15 02:11 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
I agree with a turbo setup,requires some fab work but well worth it and can stay under or at budget.
A magnum swap is a good direction,will need some work,computer work or induction/electronics,can stay around budget limit.
A pair of closed chambered heads,1.88/1.60 valves,some head work,thin head gaskets,convertor and gears,headers,advance the cam,it will stay under budget also.
Re: My 318 is a dog, Need to make a change ! [Re: moparborn] #1773516
03/08/15 06:21 PM
03/08/15 06:21 PM
Central TX
roe Offline
roe  Offline
Central TX
I just replaced a mild LA 360 with a 408 magnum stroker. Kept the serpentine belt, performer rpm airgap, holley 3310. The power on tap is amazing, I couldn't be happier. Also, I had a 8.75 with 3.55 SG installed. And a year or two prior I had the trans rebuilt with low gear set, factory high stall converter, and transgo TF2 shift kit. I love the performance of the old pile of bolts.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: My 318 is a dog, Need to make a change ! [Re: Steve Bryant] #1773517
03/08/15 06:35 PM
03/08/15 06:35 PM
It will exceed your budget by a couple thousand
Oh thats the story of my life
Re: My 318 is a dog, Need to make a change ! [Re: roe] #1773518
03/08/15 08:00 PM
03/08/15 08:00 PM
Lyons, CO
Lyons, CO
What is the stall speed on the "factory high stall converter"?
And do you have a p/n, or where would I get one ?
Re: My 318 is a dog, Need to make a change ! [Re: MileHighDart] #1773519
03/08/15 09:00 PM
03/08/15 09:00 PM
Central TX
roe Offline
roe  Offline
Central TX
I dont have a part#, I just had the builder order it. IIRC it was somewhere around 2200-2300 or so. But since its behind a much stronger motor it stalls higher than its rating. I havent played with the car enough to nail it down say its right around 26-2800 or so
Re: My 318 is a dog, Need to make a change ! [Re: MileHighDart] #1773520
03/08/15 11:18 PM
03/08/15 11:18 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
A factory replacement "CR8H" is supposed to stall between 1900 and 2400 rpm according to the transtar catalog. I don't know the pricing, but I'd expect around $100?
Contact Information
Transtar Industries
Denver, Colorado Branch
12330 East 46th Avenue, Suite 700
Denver, CO 80239
(303) 307-1999
(800) 525-9096
(right off I-70 and I-225)
If you need a higher stall then might have to go aftermarket or ask Transtar above. I got a heavy duty version (better sprag, I think roller?) of a factory high stall 727 converter and it was less than $200.
Fax (303) 307-0999
Re: My 318 is a dog, Need to make a change ! [Re: 451Mopar] #1773521
03/09/15 01:36 AM
03/09/15 01:36 AM
Lyons, CO
Lyons, CO
Thanks for the info 451Mopar
Re: My 318 is a dog, Need to make a change ! [Re: MileHighDart] #1773522
03/09/15 01:46 AM
03/09/15 01:46 AM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
Also call Don over at Ajax Auto Parts in Arvada, 303.420.3696. Chances are he probably has a good used one for dirt cheap. Let him know I sent you.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Page 2 of 3 1 2 3
