71 charger brake lights #1772404
03/05/15 04:50 PM
03/05/15 04:50 PM
New Jersey
FC7 cuda Offline OP
FC7 cuda  Offline OP
New Jersey
I have blinkers and hazzards but no brake lights .I have power going up to the column on the white wire on both sides of the switch..
Re: 71 charger brake lights [Re: FC7 cuda] #1772405
03/05/15 04:54 PM
03/05/15 04:54 PM
New Jersey
FC7 cuda Offline OP
FC7 cuda  Offline OP
New Jersey
Pic
Re: 71 charger brake lights [Re: FC7 cuda] #1772406
03/05/15 05:43 PM
03/05/15 05:43 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Silly question Is the hazard switch in the OFF position????
Re: 71 charger brake lights [Re: TJP] #1772407
03/05/15 06:01 PM
03/05/15 06:01 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Check fuses. Also check the brake light switch located under the dash with a plunger that rests on the brake pedal arm. when the pedal is pushed to apply the brakes the plunger releases and electrical circuit is completed.
Re: 71 charger brake lights [Re: TJP] #1772408
03/05/15 06:10 PM
03/05/15 06:10 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
When the Brake pedal is depressed it closes the switch and sends the 12v power to the turn signal / hazard switch which the distributes the signal depending on the TS Hazard switch position.
First thing is to test the BL switch. Then follow the power through the column connector to the T/S switch. If the power is getting there next likely culprit is the T/S or hazard switch itself.
Once you have verified the Brake switch power at the switch, you can jumper it to the brown and green wires which are the output to the high filaments or Brake lights. MAKE SURE THE T/S switch is in the CENTER POSITION AND THAT THE HAZARD switch is OFF
Re: 71 charger brake lights [Re: FC7 cuda] #1772409
03/05/15 07:00 PM
03/05/15 07:00 PM
(1) pink wire (think hot pink) at brake pedal switch should be hot all the time & if it ain't then check brake light fuse (2) white "out" wire from pedal switch to dangling connector under column should be hot when pedal is depressed (the switch closes) (3) seperate the ts/brake dangling connector halves under the column & on the col half there should be continuity between the white "in" wire and the 2 "out" wires with the stalk in neutral. www.mymopar.com will have the colors but with your meter on ohms there should be continuity between the white wire and 2 others only. this'll confirm or deny that the TS switch assy/pigtail is functioning or not. EDIT always a good idea to pull a batt cable BEFORE switching the meter to ohms
Re: 71 charger brake lights [Re: RapidRobert] #1772410
03/05/15 10:35 PM
03/05/15 10:35 PM
FLA
JohnnyBee Offline
JohnnyBee  Offline
FLA
You need to ground the tail lights. Some tail lights (R/T) have a ground on the back of the tail lights that is grounded to the bumper mount and to both sides of the trunk side marker lights. The ground wire is on the left had side.
If not the (R/T) style, still Ground to side marker
Re: 71 charger brake lights [Re: JohnnyBee] #1772411
03/05/15 11:10 PM
03/05/15 11:10 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
If it has flashers then it has the grounds.
Like stated before check the fuse and brake light switch. Could be the EM flasher switch. That switch interrupts the brake light circuit and transfers the brake lights to the EM flash circuit. Those switches do wear out. I just changed one on a 71 Charger a couple months ago and fixing to change one on a 67 Chevelle. Have changed several over the years.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 71 charger brake lights [Re: moparmarks] #1772412
03/06/15 01:48 AM
03/06/15 01:48 AM
New Jersey
FC7 cuda Offline OP
FC7 cuda  Offline OP
New Jersey
where is the em flasher located and how does it look?
thanks
Re: 71 charger brake lights [Re: FC7 cuda] #1772413
03/06/15 03:34 AM
03/06/15 03:34 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
The thing that sticks out right behind the ignition switch.
Re: 71 charger brake lights [Re: FC7 cuda] #1772414
03/06/15 09:35 AM
03/06/15 09:35 AM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
thanks
Been a while but IIRC, it's clipped under the edge of the dash near the ashtray.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: 71 charger brake lights [Re: I_bleed_MOPAR] #1772415
03/06/15 10:16 AM
03/06/15 10:16 AM
moparmarks Offline
moparmarks  Offline
thanks
Tim
The EM flasher is on the pedal housing in front of the fuse box
The T/S flasher is on the right side of the ashtray housing.
The EM flasher switch is on the column between the steering wheel and the ignition switch.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 71 charger brake lights [Re: FC7 cuda] #1772416
03/06/15 12:08 PM
03/06/15 12:08 PM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
Check under the mat in the left side of the trunk and see if any of the wires going into the connector have been broken by objects moving around inside the trunk over the decades.
Re: 71 charger brake lights [Re: 71charger] #1772417
03/09/15 02:14 AM
03/09/15 02:14 AM
Riverside, California
ghostrider Offline
ghostrider  Offline
If I remember correctly from my 71 Sebring, the brake lights are powered through a wire that also goes into and out of the radio connector. Been a long time so that might have been the flashers and not the brakes. Mine had a cutoff radio connector and when I put that back on I had the lights again.
Must remember... my humor doesn't work on forums.....my humor doesn't work on forums. Former Mopars include 69 Super Bee, 71 Sebring, 68 Charger, 69 Charger, 78 D150, 67 300, 71 Road Runner clone, 79 T-top Doba, 67 Barracuda, 91 TC by Maserati, 68 Town & Country
