BB Cam thrust button #1771978
03/05/15 10:03 AM
03/05/15 10:03 AM
California
70Drop Offline OP
70Drop  Offline OP
California
I'm getting ready to put in a bigger cam (solid roller), and I thought I'd upgrade my current cam thrust setup. Right now I have a steel timing cover with a thick washer welded onto it so it fills up the space between the timing cover and the water pump housing. On the end of the cam I have a Comp Cams nylon button that I've ground just a bit to achieve cam endplay. I want to do something more substantial and less hokey, so I bought an Indy cast front cover and now need to select a button. I'd like to use something rollerized, just because that looks like a trick setup. I see that some come with shims to get the correct endplay. What do you guys use?
Re: BB Cam thrust button [Re: 70Drop] #1771979
03/05/15 11:53 AM
03/05/15 11:53 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I use the nylon ones. I've had the roller ones let the little bearings into the oil pump,,,NOT good!!
If you like drag racing, support your local track.
Re: BB Cam thrust button [Re: CHAPPER] #1771980
03/05/15 05:15 PM
03/05/15 05:15 PM
California
70Drop Offline OP
70Drop  Offline OP
California
Ouch! I hadn't thought about that.
Re: BB Cam thrust button [Re: 70Drop] #1771981
03/05/15 08:13 PM
03/05/15 08:13 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Don't know WTF they were thinking when they designed that POS ... they don't fit under a stock or aftermarket aluminum water pump!!
Nothing wrong with nylon buttons and nothing wrong with your current setup - especially if you already have the proper clearance.
Re: BB Cam thrust button [Re: 70Drop] #1771982
03/05/15 08:24 PM
03/05/15 08:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
When I use to run BB I used the roller one. had it in
for years without any issue.... and I know hundreds
of guys using the roller one right now... MANY on
this board use it... will the nylon work.. sure but
over time it wears.. no big deal if you open up the
engine once in a while
