Re: BB Cam thrust button
[Re: CHAPPER]
#1771980
03/05/15 05:15 PM
03/05/15 05:15 PM
Posts: 223 California
70Drop
California
I use the nylon ones. I've had the roller ones let the little bearings into the oil pump,,,NOT good!!
Ouch! I hadn't thought about that.
[Re: 70Drop]
#1771981
03/05/15 08:13 PM
03/05/15 08:13 PM
Posts: 8,881 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I bought an Indy cast front cover
Don't know WTF they were thinking when they designed that POS ... they don't fit under a stock or aftermarket aluminum water pump!!
Nothing wrong with nylon buttons and nothing wrong with your current setup - especially if you already have the proper clearance.
[Re: 70Drop]
#1771982
03/05/15 08:24 PM
03/05/15 08:24 PM
Posts: 52,972 Romeo MI
MR_P_BODY
When I use to run BB I used the roller one. had it in for years without any issue.... and I know hundreds of guys using the roller one right now... MANY on this board use it... will the nylon work.. sure but over time it wears.. no big deal if you open up the engine once in a while
