Thumper Carbs? #1771224
03/04/15 03:43 PM
03/04/15 03:43 PM
Bad Axe,MI
E
EDDIEB Offline OP
EDDIEB  Offline OP
E
Bad Axe,MI
Any new feed back,results ,good or bad?
Thanks EDDIE B
Re: Thumper Carbs? [Re: EDDIEB] #1771225
03/04/15 04:33 PM
03/04/15 04:33 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Haven't got mine installed yet. Car in trailer, snowy/cold/rainy/sleety/yuky out, garage full of work.
If you like drag racing, support your local track.
Re: Thumper Carbs? [Re: CHAPPER] #1771226
03/04/15 05:03 PM
03/04/15 05:03 PM
fresno ca
mikeysmopars Offline
fresno ca
Mine will be tested the 14th and i cant wait!
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Thumper Carbs? [Re: mikeysmopars] #1771227
03/04/15 07:56 PM
03/04/15 07:56 PM
fullmetaljacket Offline
waiting for the thaw and a window of time to install. It looks good so far.
L.
Re: Thumper Carbs? [Re: mikeysmopars] #1771228
03/16/15 03:26 PM
03/16/15 03:26 PM
fresno ca
fresno ca
Finally got to test the new Thumper Carb and wide band set up this weekend and out of the box with. First hit around 9:30 in the morning and went 10.02 with 1.38 60 @ 133 mph. Set the gopro on the guages and showed 12 to 13 wot. Very encouraging for first pass! Next three runs went to crap and went 10.40s & 50s??? checked the plugs and looked lean which that has never been the case with my engine. Did a compression chech, All cylinders were 170 range. scratching my head i poped the dist cap and noticed the screws holding the plate were loose. Tighened them back up,checked timing and was at 24 degrees,went from 95 jets to 97 fixed timing, got one more run and by that time it was afer 3 oclock and 90 degrees and effective altitude as around 2500 feet. Car went 10.07 with 1.39 60 at 132.99
very encouraging just need to do a little more tuning.
Re: Thumper Carbs? [Re: mikeysmopars] #1771229
03/16/15 04:17 PM
03/16/15 04:17 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Got mine on. Waiting on my fuel pump filter to get here. Fuel system is cleaned and ready for fuel when the pre-filter gets here. Weather is looking better here.
Re: Thumper Carbs? [Re: CHAPPER] #1771230
03/16/15 04:19 PM
03/16/15 04:19 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Better than this anyway...
Re: Thumper Carbs? [Re: CHAPPER] #1771231
03/16/15 06:14 PM
03/16/15 06:14 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
What is your previous best in the same conditions ?
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Thumper Carbs? [Re: deaks] #1771232
03/16/15 06:34 PM
03/16/15 06:34 PM
fresno ca
fresno ca
Best my car ran in real good air was 9.98 and 1.38 60 @ 135.Most of my runs have been 10.0 cool air to 10 teens in the heat with 1.40 to 1.44 60 foots.
I have since added 20 lbs with exhaust and diaper.
I only got two decent runs out of 5 but i'm sure i can get a tenth with knowing where my tune is for sure now. Keep in mind i'm not much of a tuner and i litterally put that carb on, set the idle and ran it as is. What is hard for me is the addition of the pipes for the 02 sensor, Sounds like i have a miss to me.
As my friend said after the TNT yesterday, We really need to find a chassis dyno if we want to dial them in right
Re: Thumper Carbs? [Re: mikeysmopars] #1771233
03/16/15 06:41 PM
03/16/15 06:41 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
How much exhaust was added. IMO, any car making enough powet to run a 10.0 will be hurt by an exhaust system unless its 3.5 or bigger
Re: Thumper Carbs? [Re: sixpackgut] #1771234
03/16/15 06:44 PM
03/16/15 06:44 PM
fresno ca
fresno ca
Added 18 in extensions with turnouts and they are 3.5
Re: Thumper Carbs? [Re: mikeysmopars] #1771235
03/16/15 06:49 PM
03/16/15 06:49 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Ok nice
Re: Thumper Carbs? [Re: mikeysmopars] #1771236
03/16/15 06:52 PM
03/16/15 06:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
How much exhaust did you put on.. since you put that on
your not apples to apples here... if you put collector
extensions on that in itself can make for the 60'
(how long is your collector now)
Re: Thumper Carbs? [Re: MR_P_BODY] #1771237
03/16/15 07:12 PM
03/16/15 07:12 PM
fresno ca
fresno ca
MR P i'll take some pix when i get home and post them, Only reason they are on there is for the 02 sensor. I wanted to put them in the collectors but everyone said i needed the extensions so the sensor would read correctly
Re: Thumper Carbs? [Re: mikeysmopars] #1771238
03/16/15 07:30 PM
03/16/15 07:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Without knowing your engine the proper collector length
would be in the 16"-18" to make max torque.. so your
extensions might have given you the decrease in the 60'..
just saying
Re: Thumper Carbs? [Re: EDDIEB] #1771239
03/16/15 11:15 PM
03/16/15 11:15 PM
Mine is now on the car, but too busy for the moment to fire up, check for leaks, fine tune, idle etc. Will be firing up and fine tuning real soon.
Re: Thumper Carbs? [Re: fullmetaljacket] #1771240
03/17/15 12:54 AM
03/17/15 12:54 AM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
Mine is on the car and running great. Need to get to track now.
Re: Thumper Carbs? [Re: MR_P_BODY] #1771241
03/17/15 01:11 AM
03/17/15 01:11 AM
fresno ca
fresno ca
just saying
[/quote
Here are the pipes, 18 inch with the turn outs.
Engine combo is 470 B block with little EZ heads
Assume it makes 700 HP.
02 Sensor is on the right side and 12.5 inches past the collector.
Headers are typical hooker 1 7\8 with 3.5 collectors.
Carb is 1150 dominator.
Re: Thumper Carbs? [Re: mikeysmopars] #1771242
03/17/15 01:13 AM
03/17/15 01:13 AM
fresno ca
fresno ca
Right side
Re: Thumper Carbs? [Re: mikeysmopars] #1771243
03/17/15 01:15 AM
03/17/15 01:15 AM
fresno ca
fresno ca
Engine
