Re: Quality Cast Iron Wedge Block
[Re: mprhound]
#1770726
03/05/15 09:57 AM
03/05/15 09:57 AM
Posts: 731 NY
XXHEMI
NY
Weight is my biggest problem! Does anyone now how much heavier the world block is over stock block?
Lee do you know how much weight you actually removed from your car? My car weighs 3360 and the 320 for the driver??? Basically a tank! Car and driver.
[Re: XXHEMI]
#1770727
03/05/15 11:17 AM
03/05/15 11:17 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
The World blocks are around 80-100 lbs. heavier than a stock block. For your car/class I'd think that'd be a big problem. Unless someone has a CNC lightening program for them. I have a World Hemi block in the garage and that thing is F'n heavy! It was really heavy before we bored 1/4" out of each cylinder, lol. Your best option is gonna be finding someone w/ an older MP megablock they are selling.
[Re: XXHEMI]
#1770728
03/05/15 01:54 PM
03/05/15 01:54 PM
Posts: 75,088 A Banana Republic near you.
JohnRR
Ed is FAST allowing siamese bore blocks now where not originally available ?
[Re: JohnRR]
#1770730
03/05/15 02:48 PM
03/05/15 02:48 PM
Posts: 409 Texas
mprhound
Texas
look in the big block for sale section. factory cross bolt wedge block.
There was never a factory crossbolt wedge block.
[Re: mprhound]
#1770733
03/05/15 06:32 PM
03/05/15 06:32 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Cast iron siamesed 440 blocks were available from Chrysler in the mid 90s.Lenny Davis has one of the last ones I had in the shop.
440-cross-bolt-P5249347 440-cross-bolt-long stroke clearence-P5249388
We still have one that needs repaired in the shop.
[Re: JohnRR]
#1770734
03/06/15 01:04 AM
03/06/15 01:04 AM
Posts: 731 NY
XXHEMI
NY
John I did get the green light on a world block. To be honest I was against the block rule all along!
Funny thing nobody got any faster?
[Re: B G Racing]
#1770735
03/06/15 03:21 AM
03/06/15 03:21 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Cept nobody said anything about MP blocks.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: an8sec70cuda]
#1770736
03/06/15 11:59 AM
03/06/15 11:59 AM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
I agree....The megablock would be a better choice
the production stock block in that Maxie was already a pretty thick wall(I used the best one I could find), and has a tall fill...While I never weighed it, in ready to assemble state, it was pretty heavy..Heavier than any 440 based build I have had through here..
Adding weight, especially over the nose, is never "good" but neither is a block that doesnt have wall integrity...
I think its working pretty good for what it is..Its never gonna be easy to compete with a Hemi headed motor with an antiquated, inline valve wedge headed offering..
Block idea is great, and maybe some effort to get it to hang in there a bit more up top...Thats where the race is won with the engines that have better head designs..No secret there...
MB
[Re: Von]
#1770738
03/06/15 02:54 PM
03/06/15 02:54 PM
B G Racing
Eighty Four, PA
Last time we looked,MP stood for Mopar Performance a division of Chrysler Corp.factory engineered performance parts with Mopar logo,casting numbers and part numbers.We consider those blocks to be factory parts.We understand that they were not available in production built cars,but so was a lot of parts that could be bought across the counter just like any replacement blocks.
[Re: B G Racing]
#1770739
03/06/15 03:10 PM
03/06/15 03:10 PM
JohnRR
Bob that was in the 90's and I know of them, but did Chrysler put together max wedges in 1963 with crossbolt blocks?
Ed is racing in a class that required the engine to look stock on the outside, a crossbolt block would not look stock in a maxie, and until recently they didn't allow siamese bore blocks.
[Re: B G Racing]
#1770740
03/06/15 03:13 PM
03/06/15 03:13 PM
JohnRR
It has nothing to do with an MP block and more to do with the class rules and Ed has said those were changed so it's now a moot point.
I was asking and answering his questions as I knew of how the rules were , I'm out of doing any F.A.S.T. class racing so I didn't know of the rule change.
[Re: HPMike]
#1770741
03/06/15 03:17 PM
03/06/15 03:17 PM
JohnRR
MB
Mike what is failing on the block , cylinder intergrity or the main webbing?
If the block is ok to use maybe look for an MP 500" wedge shortblock ? Crossbolts and siamese bore , run a lightening program on it in the valley and that would help lose some of the extra weight ???
[Re: JohnRR]
#1770742
03/07/15 01:00 AM
03/07/15 01:00 AM
Von
NE Oklahoma
So a MP aftermarket block is considered a factory part??
[Re: JohnRR]
#1770743
03/07/15 09:49 AM
03/07/15 09:49 AM
B G Racing
Eighty Four, PA
There were no crossbolted blocks for the 63 max wedge,however in late 63,early 64 Chrysler Chrysler had a limited run of crossbolted blocks for NASCAR.Some found there way into a few noted drag racers hands.These were at the begining of the hemi release and had a large casting bulge that could be machined for the top 5 bolt holes of the wedge or 4 valley bolts of the hemi.A lot of the casting had to be machined off for pushrod clearence for the wedge.AS hemi production went into full swing this unique feature was eliminitated as was the max wedge production.After the success of the hemi and it being outlawed by NASCAR some enterprizing racers like the Pettys reconfigured the hemi block to accept the wedge heads.Some of these blocks still exist today. In the 90s Chrysler produced a limited run of max wedge 426 blocks that were legal for NHRA but were only two bolt mains,P4529851
[Re: B1duster]
#1770745
03/07/15 03:56 PM
03/07/15 03:56 PM
B G Racing
Eighty Four, PA
There is a cross bolted factory wedge 63-64 block forsale either here or on forabodiesonly. I'll take a look, came across it yesterday
Check it very carefully,if it is a real one it's rare as we understand only 50+- were produced.Make sure it's not a after cast custom setup like ProGram or other.We have only seen 2 or 3 and that was long ago.There are a few of the Petty conversions around.I had 6 and the last one was sold to Ron McCelland at Beaverdale Auto.
