Re: ? for the painters: When to replace air hose?
[Re: HemiStan]
#1769307
03/02/15 05:28 PM
03/02/15 05:28 PM
Posts: 240 Shingle Springs Ca
haddixj
Shingle Springs Ca
I would buy one from the local body supply store or on amazon you can get a devilbiss brand hose that is good
70 duster 25.1E,73 barracuda, 70 gran coupe, 71 cuda
[Re: haddixj]
#1769308
03/02/15 05:54 PM
03/02/15 05:54 PM
Posts: 110 So. Illinois
bronze69
So. Illinois
Once you use a Flexzilla air hose, you will not want to use anything else.
68 Gold Met. 383-4spd Roadrunner
69 T5 Hemi 4-spd Roadrunner
70 Limelight 440-6 Auto Superbird
[Re: bronze69]
#1769312
03/02/15 07:30 PM
03/02/15 07:30 PM
Challenger 1
Cincinnati, Ohio
Thanks for the post, might try one.
[Re: Challenger 1]
#1769313
03/02/15 10:59 PM
03/02/15 10:59 PM
Posts: 2,655 western PA
mopar4ya
western PA
Just a word of caution. I had a older air hose cause me to wet sand the clear coat off twice before I figured out it was contamination coming from the hose that was causing my problem. This was also the same hose I had just used to lay down the black base that looked just fine . Dan.
