hemi & 6bbl vapor separator #1768990
03/02/15 03:47 AM
03/02/15 03:47 AM
California
mickm Offline OP
mickm  Offline OP
California
who makes these? want to find a good quality one.
thanks!
Re: hemi & 6bbl vapor separator [Re: mickm] #1768991
03/02/15 01:06 PM
03/02/15 01:06 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Call Frank, or Roger Gibson, theirs has the screen inside, but nobody has the correct one with the .060 hole in the return nipple. I took a bolt, and cut the head off, and drilled the hole, and just put it inside the rubber hose, so it does the same thing.
Re: hemi & 6bbl vapor separator [Re: 71birdJ68] #1768992
03/02/15 02:04 PM
03/02/15 02:04 PM
California
mickm Offline OP
mickm  Offline OP
California
what's with the hole being the wrong size? this only allows vapor from the separator to return to the tank, yes?
Re: hemi & 6bbl vapor separator [Re: mickm] #1768993
03/02/15 02:09 PM
03/02/15 02:09 PM
New Berlin,Wi
Firepowerflyer Offline
New Berlin,Wi
When the hole is too large it sends the fuel back to the tank.My 440 in my 69 GTX would be fine in first gear and part of 2nd then it would fall on it's face. It would run out of gas on full throttle runs. I soldered mine shut and redrilled it to .060 works perfect now.
Re: hemi & 6bbl vapor separator [Re: mickm] #1768994
03/02/15 02:11 PM
03/02/15 02:11 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
What year of car are you putting it on? On a 71 the hole restricts the flow back to the tank, if you don't have it your fuel pressure could be low. The service manual talks about on a 71, maybe the earlier models as well. Also, a lot of the repo's don't have a screen, which Franks does.
Re: hemi & 6bbl vapor separator [Re: Firepowerflyer] #1768995
03/02/15 02:18 PM
03/02/15 02:18 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
At one time there were at least 2 companies making them( not sure if that is still the case )
Anyway the good one had the wording IN and OUT stamped in the can like OE. ( The junk was blank ) There are internal differences but thats the easiest way to tell them apart.
But even the good one the return orfice was a touch to big. In 'most' cases it will be fine, Unless you hammer on the car and stay in high rpms for any length of time.
The ones selling the good ones are
Randy at Dixie Restoration supplies.
Richard at Restoration Parts and materials
Jamie at Megaparts
Or call Dave at Restoration Specialties , his wife owns the company making the good ones.
Anybody else would be suspect of quality ,,,IMO
Re: hemi & 6bbl vapor separator [Re: gtx6970] #1768996
03/02/15 02:20 PM
03/02/15 02:20 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Frank, and Roger have the good one's also.
Re: hemi & 6bbl vapor separator [Re: 71birdJ68] #1768997
03/02/15 02:36 PM
03/02/15 02:36 PM
California
mickm Offline OP
mickm  Offline OP
California
ok, sounds good.
no problem setting that to the right size. i want to run 3/8" line from the pump, (actually have regulator hanging directly off the pump) up to the tee, (i have a 3/8" in, 5/16" out tee). i was planning on cutting off the 5/16" inlet and outlet on the separator, and then welding 3/8" nipples on in their place.
Re: hemi & 6bbl vapor separator [Re: mickm] #1768998
03/02/15 11:49 PM
03/02/15 11:49 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
Lots of bogus ones out there and I got one. Could not get the car started - all the fuel was going straight back to the tank because there was no orifice in the return line
Cut it open and just short stub lines inside and no screen!!
The return line needs a 0.040" to 0.060" orifice.
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: hemi & 6bbl vapor separator [Re: RealWing] #1768999
03/02/15 11:50 PM
03/02/15 11:50 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
This is what it should look like
Re: hemi & 6bbl vapor separator [Re: RealWing] #1769000
03/03/15 01:22 AM
03/03/15 01:22 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Was also used on 440-4bbl too.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: hemi & 6bbl vapor separator [Re: RealWing] #1769001
03/03/15 03:19 AM
03/03/15 03:19 AM
California
mickm Offline OP
mickm  Offline OP
California
i ordered one from frank badelson. i assume i'll get a good one, and modify it for 3/8" from there...
Re: hemi & 6bbl vapor separator [Re: mickm] #1769002
03/03/15 10:27 AM
03/03/15 10:27 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I know everyone want's 3/8" but 5/16" is plenty after the fuel pump. I just want to go on record and say this.
Re: hemi & 6bbl vapor separator [Re: Challenger 1] #1769003
03/03/15 03:50 PM
03/03/15 03:50 PM
California
mickm Offline OP
mickm  Offline OP
California
you are right, i'm just doing this for fun, really, since i have the parts.
Re: hemi & 6bbl vapor separator [Re: mickm] #1769004
03/03/15 09:54 PM
03/03/15 09:54 PM
PA
Jack Zupan Offline
Jack Zupan  Offline
PA
I bought mine from Mancini and had the same troubles. I was pumping most of the fuel back through the return line. I put a clamp on the rubber fuel hose between the return line and vapor separator which seemed to solve the problem. Of course I am defeating the purpose of the thing in the first place.
Re: hemi & 6bbl vapor separator [Re: Jack Zupan] #1769005
03/03/15 10:30 PM
03/03/15 10:30 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I put a pressure gauge on mine and watched it drop about 2-2.5 psi after I had clamped down on the return line then open it back up again. The Carters carbs, I've always heard, are a bit sensitive to pressure. After some research here on some older Moparts threads I found that the trick was to restrict the return line as even the factory .060" was a bit fat. Recommended was closer to .030". I soldered the return line tip closed then drilled it to .032" because that was the closest drill bit I had at the time. My pressure drop is now around .5 PSI. Even with the smaller hole it still passes plenty of gas. I rigged up some clear tubing for several weeks but rarely saw any bubbles.
Re: hemi & 6bbl vapor separator [Re: 68jim] #1769006
03/04/15 03:44 PM
03/04/15 03:44 PM
California
mickm Offline OP
mickm  Offline OP
California
good to know. i will set mine around .030 and go from there.
