5.7 hemi blocks #1768956
03/02/15 01:10 AM
03/02/15 01:10 AM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
can new 5.7 blocks be bought? like pre-vvt blocks?
i searched for a part number but found nothing
Re: 5.7 hemi blocks [Re: mcat4321] #1768957
03/02/15 02:55 AM
03/02/15 02:55 AM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
Is there a difference between the VVT blocks and the blocks in M/T cars?Honest ?
Re: 5.7 hemi blocks [Re: ksj] #1768958
03/02/15 05:03 PM
03/02/15 05:03 PM
Plano, TX
StricNine Offline
StricNine  Offline
Plano, TX
The manual transmission cars (2009+) have VVT, but no MDS (block has the MDS ports plugged in the lifter valley).
There are differences between the pre-VVT and VVT blocks. One I'm pretty sure of is the VVT engines 1st cam bearing bore size has a larger diameter. Probably oil passage differences are well to feed the cam phaser. I think there are other differences as well.
StricNine
79 Li'l Red Express, 15.04 @ 89.57
09 Challenger R/T, 11.95 @ 115.92
Re: 5.7 hemi blocks [Re: StricNine] #1768959
03/02/15 06:13 PM
03/02/15 06:13 PM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
Thanks.Hope someone can help Dustin out on finding one.
Re: 5.7 hemi blocks [Re: mcat4321] #1768960
03/02/15 08:21 PM
03/02/15 08:21 PM
San Angelo, Texas
Cevidicus Offline
Cevidicus  Offline
San Angelo, Texas
I went through this a few years ago. All I could find was a replacement short block. At the time they were $1400-$1500. I searched high and low for a new bare block without vvt for about a year. No luck. I could get used ones in the $300-$600 range.
Maybe someone else has a different experience.
Good luck man.
Re: 5.7 hemi blocks [Re: Cevidicus] #1768961
03/03/15 12:43 AM
03/03/15 12:43 AM
IL
knyech1 Offline
knyech1  Offline
IL
I found several non VVT 5.7 blocks for about $400 a pop when I was into the gen3 Hemis. Most were std bore that only needed a hone. Let me know if you need one and I'll see what I can do.
knyech1- '71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph "Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B. '03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
Re: 5.7 hemi blocks [Re: knyech1] #1768962
03/03/15 03:48 PM
03/03/15 03:48 PM
Ohio
john55 Offline
john55  Offline
Ohio
I'm looking for a vvt 5.7 or 6.4 block
The Plymouth Win You Over Beat Goes On
Re: 5.7 hemi blocks [Re: john55] #1768963
03/04/15 02:35 AM
03/04/15 02:35 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Dustin, what are you building? I noticed you sold some stuff I wish I had the money to buy.
Re: 5.7 hemi blocks [Re: john55] #1768964
03/04/15 10:09 AM
03/04/15 10:09 AM
gregsdart Online content
gregsdart  Online Content
I spotted this link about blocks and thought some would like the info. It might be worth thinking about a 6.1 new block if your project is like mine, delayed for a while.
http://www.lxforums.com/board/showthread...551#post4740551
Re: 5.7 hemi blocks [Re: gregsdart] #1768965
03/04/15 12:15 PM
03/04/15 12:15 PM
Ohio
john55 Offline
john55  Offline
Ohio
Thanks!!
