Re: Leaking brake line at the banjo bolt. GRRRRR!
[Re: convx4]
#1768715
03/01/15 11:20 PM
03/01/15 11:20 PM
moparpollack
Lil Herman
Lil Herman
85086
Try dubbing up the copper washers on that side.
Doing this cured the same leak I had.
The shim washers are so thin I have never got them to seal any other way.
[Re: cudadoug]
#1768718
03/01/15 11:24 PM
03/01/15 11:24 PM
moparpollack
Lil Herman
Lil Herman
85086
Dubbing?? You mean like Dubbing wax?
Doubling them up.
[Re: moparpollack]
#1768719
03/01/15 11:26 PM
03/01/15 11:26 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Ran into this years ago with reman calipers. Ended up going to Pep Boys and looking thru their copper washer selection till I found thicker ones of the right diameters cause the supplied ones were too thin. What's happening is the bolt is bottoming out before the washer seals.
[Re: Supercuda]
#1768722
03/01/15 11:29 PM
03/01/15 11:29 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
Yes, these are thin!
[Re: Supercuda]
#1768723
03/01/15 11:41 PM
03/01/15 11:41 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
I too had this problem but my kit had two different washers of different thickness. I could not get the thin one to seal so I tried the thicker washer and it sealed.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#1768724
03/01/15 11:48 PM
03/01/15 11:48 PM
Posts: 21,081 Niles , Ohio
therocks
Niles , Ohio
Most of the new washers are crap.I almost always used the old ones to seal.Seems the new ones almost always leaked.Ive use ones that were worse than that and no leaks.Rocky
Chrysler Firepower
[Re: AndyF]
#1768726
03/02/15 12:43 AM
03/02/15 12:43 AM
cudadoug
Might have better luck if you buy OEM washers. Should still be available at the dealer. The OEM washers are thick and might be a softer grade of copper.
Never thought of that, thank you Andy! I went to two REAL parts stores and what they have are thin AND a smaller diameter than the serrations are.
In hindsight, SHOULD have probably went with the Wilwoods!
