Leaking brake line at the banjo bolt. GRRRRR! #1768713
03/01/15 11:05 PM
03/01/15 11:05 PM
Between a rock & a hard place
cudadoug Offline OP
cudadoug  Offline OP
Installing a Disc conversion kit and have a minor headache.
Can you see the flaw in the serrations in this pic?? At 9:00, two of serrated edges have flat spots, like it was nicked in production or shipping.
You think this cause a leak with THREE different sets of crush washers?? First two attemps, torque was 25 ft lbs. Third attempt I tried 30 ft lbs. Drip, drip, drip.
It's the only thing I can see that's wrong, the other side sealed up first time.
Re: Leaking brake line at the banjo bolt. GRRRRR! [Re: cudadoug] #1768714
03/01/15 11:12 PM
03/01/15 11:12 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
Try dubbing up the copper washers on that side.
Doing this cured the same leak I had.
Re: Leaking brake line at the banjo bolt. GRRRRR! [Re: convx4] #1768715
03/01/15 11:20 PM
03/01/15 11:20 PM
85086
moparpollack Online penguin-006
Lil Herman
moparpollack  Online Penguin-006
Lil Herman
85086
The shim washers are so thin I have never got them to seal any other way.
Re: Leaking brake line at the banjo bolt. GRRRRR! [Re: cudadoug] #1768716
03/01/15 11:22 PM
03/01/15 11:22 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Is that a pin, or slider caliper?
Re: Leaking brake line at the banjo bolt. GRRRRR! [Re: moparpollack] #1768717
03/01/15 11:23 PM
03/01/15 11:23 PM
cudadoug Offline OP
cudadoug  Offline OP
Dubbing?? You mean like Dubbing wax?
Re: Leaking brake line at the banjo bolt. GRRRRR! [Re: cudadoug] #1768718
03/01/15 11:24 PM
03/01/15 11:24 PM
85086
Lil Herman
Lil Herman
85086
Doubling them up.
Re: Leaking brake line at the banjo bolt. GRRRRR! [Re: moparpollack] #1768719
03/01/15 11:26 PM
03/01/15 11:26 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Ran into this years ago with reman calipers. Ended up going to Pep Boys and looking thru their copper washer selection till I found thicker ones of the right diameters cause the supplied ones were too thin. What's happening is the bolt is bottoming out before the washer seals.
Don't be the exception.
Re: Leaking brake line at the banjo bolt. GRRRRR! [Re: moparpollack] #1768720
03/01/15 11:27 PM
03/01/15 11:27 PM
cudadoug Offline OP
cudadoug  Offline OP
Oh...DUBB-LING them up. I get it.
I'll give it a whirl, thanks. BACK to the auto parts store...
Re: Leaking brake line at the banjo bolt. GRRRRR! [Re: 71birdJ68] #1768721
03/01/15 11:28 PM
03/01/15 11:28 PM
cudadoug Offline OP
cudadoug  Offline OP
Slider.
Re: Leaking brake line at the banjo bolt. GRRRRR! [Re: Supercuda] #1768722
03/01/15 11:29 PM
03/01/15 11:29 PM
cudadoug Offline OP
cudadoug  Offline OP
Yes, these are thin!
Re: Leaking brake line at the banjo bolt. GRRRRR! [Re: Supercuda] #1768723
03/01/15 11:41 PM
03/01/15 11:41 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I too had this problem but my kit had two different washers of different thickness. I could not get the thin one to seal so I tried the thicker washer and it sealed.
Re: Leaking brake line at the banjo bolt. GRRRRR! [Re: YO7_A66] #1768724
03/01/15 11:48 PM
03/01/15 11:48 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Most of the new washers are crap.I almost always used the old ones to seal.Seems the new ones almost always leaked.Ive use ones that were worse than that and no leaks.Rocky
Chrysler Firepower
Re: Leaking brake line at the banjo bolt. GRRRRR! [Re: cudadoug] #1768725
03/02/15 12:08 AM
03/02/15 12:08 AM
AndyF Offline
AndyF  Offline
Might have better luck if you buy OEM washers. Should still be available at the dealer. The OEM washers are thick and might be a softer grade of copper.
Re: Leaking brake line at the banjo bolt. GRRRRR! [Re: AndyF] #1768726
03/02/15 12:43 AM
03/02/15 12:43 AM
cudadoug Offline OP
cudadoug  Offline OP
Never thought of that, thank you Andy! I went to two REAL parts stores and what they have are thin AND a smaller diameter than the serrations are.
In hindsight, SHOULD have probably went with the Wilwoods!
Re: Leaking brake line at the banjo bolt. GRRRRR! [Re: cudadoug] #1768727
03/02/15 09:10 PM
03/02/15 09:10 PM
BDW Offline
BDW  Offline
As mentioned, look through the help packs.
Re: Leaking brake line at the banjo bolt. GRRRRR! [Re: BDW] #1768728
03/30/15 03:33 AM
03/30/15 03:33 AM
cudadoug Offline OP
cudadoug  Offline OP
HELP #66272 solved the problem. Results: Hard pedal and a dry garage floor!
Thank you guys!!!
Re: Leaking brake line at the banjo bolt. GRRRRR! [Re: cudadoug] #1768729
03/30/15 12:18 PM
03/30/15 12:18 PM
Urbana, MD
bordin34 Offline
bordin34  Offline
Urbana, MD
One thing you can also do easily is anneal the copper washers to make them softer and seal better.
