Re: How to remove Crankshaft Bolt
[Re: duckblind]
#1768143
03/01/15 12:21 PM
03/01/15 12:21 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
Pretty much any impact will take it off, Including my electric harbor freight one. Otherwise you're going to have to wedge it at the transmission end of the crank.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: dogdays]
#1768158
03/04/15 06:10 AM
03/04/15 06:10 AM
Posts: 25 Groningen, the Netherlands
4doorSatellite
Hey, that's right. I've done that on a front wheel drive car to replace the timing belt.
R.
I once accidentally did that on a French car (Forgot the socket wrench was still on the crank ).
After that it was time for some new valves, because apparently this car didn't have a woodruff key on the crank timing belt pulley
A breaker bar with a hammer worked fine for my 318 also.
[Re: Supercuda]
#1768159
03/04/15 03:40 PM
03/04/15 03:40 PM
Posts: 4,179 California
mickm
California
put a breaker bar with a socket on the bolt. forget that it's there. attempt to start the car.
believe me, this will loosen the bolt!
Missed the part about it being on the stand did we?
oh, yes, we did. NEVER MIND!!!!
