How to remove Crankshaft Bolt #1768142
03/01/15 12:18 PM
03/01/15 12:18 PM
Louisiana
duckblind Offline OP
Louisiana
I need to break my 440 down to a short block in order to bring to get rebuilt. I have the engine on a stand with the heads off and am trying to determine how to keep the engine from spinning so that I can remove the bolt holding the harmonic balancer on. Any tips would be appreciated.
Re: How to remove Crankshaft Bolt [Re: duckblind] #1768143
03/01/15 12:21 PM
03/01/15 12:21 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
Pretty much any impact will take it off, Including my electric harbor freight one. Otherwise you're going to have to wedge it at the transmission end of the crank.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: How to remove Crankshaft Bolt [Re: duckblind] #1768144
03/01/15 12:22 PM
03/01/15 12:22 PM
MarkMcDonald Offline
Get out your 1/2 impact!
Re: How to remove Crankshaft Bolt [Re: MarkMcDonald] #1768145
03/01/15 12:32 PM
03/01/15 12:32 PM
IN
ahy Offline
ahy  Offline
IN
You can make a holding fixture for the crank flange end or flywheel/flex plate. A heavy piece of strip steel drilled to match opposite crank flange or flywheel/flexplate holes. Flywheel/flexplate is best as less possibility to mess up the crank flange. With matching bolts and washers for spacers it will work...
That said, an impact is a lot easier.
Re: How to remove Crankshaft Bolt [Re: ahy] #1768146
03/01/15 12:42 PM
03/01/15 12:42 PM
Louisiana
Louisiana
Thanks. Will try to borrow an impact.
Re: How to remove Crankshaft Bolt [Re: duckblind] #1768147
03/01/15 12:51 PM
03/01/15 12:51 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Don't you mean you're going to take it to get rebuilt, not bring it to get rebuilt?
Re: How to remove Crankshaft Bolt [Re: duckblind] #1768148
03/01/15 01:44 PM
03/01/15 01:44 PM
AndyF Offline
AndyF  Offline
http://arengineering.com/home-page/tools/
Several different tools are made for that task. If you have the engine on a stand then the strap works the best. If it is in the car the you use the tool that bolts to the damper.
Re: How to remove Crankshaft Bolt [Re: duckblind] #1768149
03/02/15 01:09 AM
03/02/15 01:09 AM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
..... pan off ? ... just jam a short piece of 2x4 in there
Re: How to remove Crankshaft Bolt [Re: dOOc] #1768150
03/02/15 01:53 AM
03/02/15 01:53 AM
Ding ding ding I do believe we have a winna. You're obviously stripping it down to a bare block. As said am impact would work fine but since you dont have one you dont need to borrow one (time is money). If the pan wasn't coming off I'd bolt a piston stop across a bore to lock the assy
Re: How to remove Crankshaft Bolt [Re: RapidRobert] #1768151
03/02/15 03:42 AM
03/02/15 03:42 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I usually block the crank at a counterweight with a mallet-handle. Then take my breaker-bar to the crank-bolt.
Re: How to remove Crankshaft Bolt [Re: duckblind] #1768152
03/02/15 11:30 PM
03/02/15 11:30 PM
missouri
ragin sonny Offline
ragin sonny  Offline
missouri
no one's used the old shadetree trick,cram a cylinder full of rope during the compression stroke.wouldn't try it on a good engine though
Re: How to remove Crankshaft Bolt [Re: ragin sonny] #1768153
03/03/15 02:18 AM
03/03/15 02:18 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
I used a flywheel turner to hold it
Re: How to remove Crankshaft Bolt [Re: duckblind] #1768154
03/03/15 02:17 PM
03/03/15 02:17 PM
dogdays Offline
dogdays  Offline
Get the right socket on a stiff breaker bar. Pull on the breaker bar until all the slack is out of the assembly.
Hit the breaker bar sharply with a dead blow hammer. It may take a few hits but the bolt should start turning. The inertia/friction of the shortblock assembly will resist turning enough to allow the bolt to loosen.
This is the manual version of an impact wrench.
I just did it on my last 318.
R.
Re: How to remove Crankshaft Bolt [Re: dogdays] #1768155
03/03/15 04:39 PM
03/03/15 04:39 PM
California
mickm Offline
mickm  Offline
California
put a breaker bar with a socket on the bolt. forget that it's there. attempt to start the car.
believe me, this will loosen the bolt!
Re: How to remove Crankshaft Bolt [Re: mickm] #1768156
03/03/15 08:30 PM
03/03/15 08:30 PM
dogdays Offline
dogdays  Offline
Hey, that's right. I've done that on a front wheel drive car to replace the timing belt.
R.
Re: How to remove Crankshaft Bolt [Re: mickm] #1768157
03/03/15 08:33 PM
03/03/15 08:33 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Missed the part about it being on the stand did we?
Don't be the exception.
Re: How to remove Crankshaft Bolt [Re: dogdays] #1768158
03/04/15 06:10 AM
03/04/15 06:10 AM
Groningen, the Netherlands
4doorSatellite Offline
R.
I once accidentally did that on a French car (Forgot the socket wrench was still on the crank ).
After that it was time for some new valves, because apparently this car didn't have a woodruff key on the crank timing belt pulley
A breaker bar with a hammer worked fine for my 318 also.
Re: How to remove Crankshaft Bolt [Re: Supercuda] #1768159
03/04/15 03:40 PM
03/04/15 03:40 PM
California
mickm Offline
mickm  Offline
California
oh, yes, we did. NEVER MIND!!!!
Re: How to remove Crankshaft Bolt [Re: mickm] #1768160
03/05/15 05:34 PM
03/05/15 05:34 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
Here is the best bang for the buck IMHFO. I don't know how many times it has made it all the more easier to remove the crank bolt. Even if you only use it once it more than pays for itself...
http://www.ebay.com/itm/MOPAR-Crankshaft...f58&vxp=mtr
Re: How to remove Crankshaft Bolt [Re: CR8CRSHR] #1768161
03/05/15 05:39 PM
03/05/15 05:39 PM
AndyF Offline
AndyF  Offline
Now that is a clever idea!
