Re: Hemi #4 cam groove (GEN 2)
[Re: rickseeman]
#1765419
03/01/15 03:09 PM
03/01/15 03:09 PM
Posts: 3,397 Pa
Hot 340
Pa
I wouldn't put it in.
You wouldnt put the cam in or the groove in?
[Re: Cab_Burge]
#1765420
03/01/15 03:12 PM
03/01/15 03:12 PM
Posts: 3,397 Pa
Hot 340
Pa
I make sure all my roller cam motors oil the rockers full time I will restrict them as needed Oiling the rockers full time helps a bunch on cooling the valve springs
Cab, why open it up just to restrict it back down? How do you restrict it? Carb jet tapped into galley somewhere?
[Re: Hot 340]
#1765421
03/01/15 03:17 PM
03/01/15 03:17 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
To maintain oil pressure to the bearings...
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#1765422
03/01/15 03:25 PM
03/01/15 03:25 PM
Posts: 3,397 Pa
Hot 340
Pa
I get that. Im just asking why open it up to close it back off. Does not having the groove starve the valve train and grooving the cam over flood it?
[Re: rickseeman]
#1765425
03/01/15 05:46 PM
03/01/15 05:46 PM
Posts: 3,397 Pa
Hot 340
Pa
Wouldn't put in a cam without the groove. Hemi's have the groove. Have had for 50 years. Let's not try to make this harder than it is. Hemi's have the groove. If your cam doesn't, have them make you one right.
My thinking too. Thanks ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Hot 340]
#1765429
03/02/15 04:51 PM
03/02/15 04:51 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
This cam DOES have oil holes through the #4. Did hemi cams use a combination of them both?
Yes it should have both , take it to a machine shop and have the groove added , not a big deal.
But with that said , Hi RPM Hemis can suffer spinning rod bearings on the rods fed by #4 main. The better thing to do is the block the ports at the cam bearing and make it full time oiling in the lifter valley by feeding the oil passages to the head from the main galleys and then restricing the amount of oil to the head.
